Question about Maytag Neptune MAH5500B Front Load Washer
Our maytag washer model# MAH5500BWW serial# 74966260AC seems to be stuck on the spin cycle and will not spin nor drain. I pulled the back cover off and it appears that the drain motor where 2 hoses are connected with a plastic covered electrical connector is plugged in is making a clicking sound. What is my problem?
  • Maytag Master
  • 3,361 Answers
Disconnect power.
Remove the drain motor and check for debris stuck in the motor.
Posted on Sep 06, 2010
Maytag Neptune washer, front loader, won't drain all the water so washer can spin. Model #MAH5500BWW. Please help!
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CCMQtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Dk3pV6Rp61gI&ei=2YHTVODfK6ac7gbI_oGwCQ&usg=AFQjCNH3zxME3yck3QsxS7Q5X9CRO4tsMg&sig2=dqSNvtE2ttsbm1GMtTBuVQ
Feb 05, 2015 | Maytag Washing Machines
I have a Maytag Neptune washer (model MAH5500BWW) that won't completely drain. It goes through the normal cycles but, but water still remains in the tub. Could the pump be out and how can you tell if...
Check the pump out flow of the drain hose, is it a good strong flow or does it seem weak and restricted. If the drain is slow the machine will stop before it is empty. Also if the drain hose is not vented, mounted too high in the air, or has a piece added on making it longer, it may degrade performance.
Mar 14, 2012 | Maytag Washing Machines
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer will wash but not spin
Sounds like the control board is bad. take the back panel off the control panel and look at the R11 resistor and see if it burnt. If it is replace the control board and the door wax motor (in the locking mechanism)
Nov 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
All my washer will do is spin no matter were In set it
The timer contacts have welded together. Replace the timer.
Jan 11, 2008 | Maytag MAV7600 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
252 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
