Question about Singer Confidence 7463 Computerized Sewing Machine
Bobbin rattles as I am sewing. I have cleaned it with a brush. I can see it throught the plastic that it is rattling/loose.
    Genius:
  • 1,788 Answers
I think that your have the wrong size bobbin inserted, try a metal SA156 or a 15J. Check with Joann fabrics and see what the right size is. You can also call Singer at 1-800-4singer and they can assist you.
Posted on Sep 13, 2010
I recently had my New Home 7500 serviced. It now has a rattle in the bobbin area as it sews. Sewing is fine unless I speed up then it might thread jam.
contact the one who serviced it and tell them that the machine is making rattling noise which it didn't do before and see what they say
Dec 08, 2014 | New Home Sewing Machines
Bobbin case
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Sep 28, 2013 | Janome Sewing Machines
Janome makes rattle when I sew
try changing the bobbin and see if that helps
but if it doesn't help the the machine needs to be checked to see if
there is something wrong with the hook and hook race
Jan 01, 2013 | Janome Sewing Machines
My bobbin is rattling around in the case and making a terrible noise. I have cleaned the casing and made sure I've put it back correctly and I'm using the correct bobbin - help!
if changing the bobbin doesn't help then the hook and hook race
needs to be checked to see if there is a problem with them
Dec 16, 2012 | Sewing Machines
Rattle in the bobbin area.
also make sure the bobbin fits securely in the bobbin case
does the bobbin case fit securely in the machine?
the bobbin case could be getting old & might need to be replaced.
Apr 12, 2012 | Sewing Machines
It makes a rattling sound when I sew. It has been
If its an older singer featherweight it should sound pretty quiet but if its a newer 221 it has plastic or nylon gears and they can make a "barking" sound
Jul 16, 2009 | Singer Featherweight 132Q Mechanical...
Singer 9410 Bobbin
Update:  Today I took my machine in to get serviced - they replaced the metal bobbin I was using with a plastic one, that was a little less rattley inside the bobbin case, replaced the needle with a new, universal one, and changed out the thread with something a little higher quality.  They also adjusted the spring holding the bobbin case slightly, and now it seems to work fine.  I'm not sure how long it will last, but for now I'm good.
Oct 02, 2008 | Sewing Machines
Singer Confidence 7463 Computerized Sewing Machine Logo
164 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
