Question about Maytag MAH6700AWW Neptune Front-Load Washer
Maytag Washer Drum is broken, how do we remove it properly and replace with new one??
The link does not work. It appears that the service manual has been removed from almost every site I have searched. Any suggestions?
Posted on Aug 04, 2013
  • David Aug 04, 2013
    Somehow managed to think we were talking about a gas dryer, since this is the result of my search for such. I have posted my question independently, please ignore my idiocy here. Thank you!
  • Maytag Master
  • 3,361 Answers
Model numbers help us tremendously.
I believe this Factory Service Manual covers your machine.
If not,give a model number for a more specific manual.
cut and paste this link:
http://www.servicematters.com/maytag_library/docs/16023110.pdf
Posted on Sep 06, 2010
My maytag washer model #sav5710aww shakes badly and
if its a neptune front load washer you need new tub lip seal and bearings for the drum as the seal is leaking water into the bearings that hold the inner drum,it will only get worse,you need to remove the inner drumto replace the seals and bearing it takes from 2 to 6 hours depending how hard the old bearings come out of the race
Apr 02, 2010 | Washing Machines
MY SERVICE CENTRE SAY DRUM NEEDS TO BE REPLACE,
Drum can break , it is not unusual.
Remove rear cover, and looknunderneath the drum, you will probably see where it has broken, and it would be better to buy new washer if it has brokem.
Happy new year.
Jan 01, 2010 | Indesit WA 125 Front Load Washer
Progressively louder on spin maytag neptune model# MAH5500BWW serial#C8028996LC
You have a bad rear drum bearing ( unfortunantly , so do I ) . This involves removing the inner drum and outer drum . The complete rear of the outer drum , has to be replaced , due to the bearing is already installed in the new one . Very expensive to have done and very time consuming to do yourself . You probably should invest in a different washer . Front load washer manufacturers , have not come up with a way to support the front of an inner drum as well as supporting the rear also . Until this happens , rear bearing problems and excess expense for repair , will continue to be the downfall of front loading washers .
Nov 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO
Hi...you can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=LSE7800ACW&mfgModelNum=&fkMfgID=1
Hope this helps
Sep 29, 2009 | Maytag Dryers
Drum seems out of balance does not allow water to drain because water pump hose kinks
Hi, you will have to open machine, and check spring, maybe one of your spring are broken, or strain, first lift top, and remove sides of machine, put hands on tub and rock complete assemble back until tub centers, if tub is tilted left, spring on opposite side, is loose or broken, if broken, replace, but most time they slip out, this is cause, if machine are overloaded, or not level properly, when washers are not properly leveled, when they reach spin cycle, they could go outside and come back in, just making a point, check you machine level before you start. good luck.
Aug 07, 2009 | Maytag PAV3240A Top Load Washer
Frigadaire front load washer, drum is very low in
Is the drum bouncing around?
Remove the front lower panel and the top from the cabinet. Replace the shocks and/or tub support springs if they are broken.
If the spin is noisy, there might be a problem with the inner basket or the tub bearing.
Mar 05, 2009 | Frigidaire Washing Machines
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
Maytag Neptune Broken Tub Support Arm
ummm yea your int market for a new washer. why cahnce epoxying a tub thats holding water doesntsound like a viable option. ( not worth the chancing the flood )
Mar 16, 2008 | Maytag Neptune MDE5500AY Electric Dryer
My washer will not spin off the water
Check the drain hose and make sure it is not plugged or kinked. Check as well that pumps spins. Good luck
Aug 19, 2007 | Maytag Legacy Top Load Washer
Maytag Top Loader Washing Machine Legacy Series
The drum should be on center. It sound like a damper pads issue. The damper pads are located beneath main support housing on base's machine. Check that they are on place and not broken. Good luck !
Jan 22, 2007 | Maytag Legacy Top Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
133 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
