Question about Fisher Paykel EcoSmart GWL15
The tub inside fell down and will not spin or drain.
  • Fisher Master
  • 713 Answers
Hi Cabbygirl, just read your posting.Now from the information in your posting when you lift the lid and look at the bowl where the clothes are put, the bowl has fallen down.Is this correct?Is the bowl leaning to one side?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Posted on Sep 07, 2010
Hose from the tub to the pump is blocked, how can i clean it?
I think that you will need to go in either through the back or base and I think the base is more likely. Just bear in mind that there's only limited access so it's going to be tight in there. Also, although you may be able to get the hose off it may be considerably more difficult to get it back on. You may also think about getting a technician to look at it - but get a quote first.
Jul 24, 2015 | LG WM0742HGA Front-Load Steam Washer with...
Front load washer wont spin
Check for drain obstructions. Might be something caught up in or near the drain pump. If water drains out of unit with no problems, check the belt. Motor could be issue as well. If you reach inside the tub where you put your clothes in, and grab one of the paddles, see if the tub itself moves back and forth and up and down. If you have a lot of free play or movement with the tub test, sounds like your spin bearing may have failed. If it is the spin bearing, not worth fixing.
Feb 18, 2015 | GE Washing Machines
Maytag Model #MAT13MNAGW When the machine gets to the spin cycle it doesn't spin but makes a buzzing sound. Something like the buzzing sound that a welder makes when the rod sticks.
this means that there is something stuck inside your drain pump.if you still have water in the machine you can use a wet/dry shop vac and attach it to the end of the drain hose and remove all the water in the tub.
once that is done check your drain pump for obstructions if there is no obstruction look at the hose that comes down from the bottom of the tub to the drain pump
Feb 08, 2010 | Washing Machines
Ftf2140es3 won't completely drain or do final spin.
I have one that does the same thing at times. remove the bottom front panel. You will see a black boot that comes down from the tub. Loosen the clamp on top of the boot. You should be able to pinch the boot and feel something hard inside the boot. Pull the boot down from the tub and put your fingers down inside the boot and pull up the coin collector. It may be full of junk, coins ect. Clean it and replace the boot and clamp. This should help you.
Jul 16, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Kenmore Elite Top Load does not spin on spin cycle
Hi, If the inner tub has dropped down, you will need to change the block that holds the tub to the shaft. Remove the agitator cap and then use a 7/16" socket to remove the bolt holding the agitator in.
Lift the agitator out and look at the block holding the inner tub. There should be two slots with two tabs sticking up inside them. You will probably see metal shaving as well.
If this is what you see, please let me know and I can direct you on further repair.
Thanks
Vic
May 30, 2009 | Washing Machines
Eco smart won't drain, smells hot
hi
you commented on hearing water in the machine after the wash , i know that f&p spin bowls have a liquid inside the actual spin bowl system i think it aids in the spin operation of the machine, but if you had something in the drain network then that will stop the machine from emptingout as it all works on a time basis check and see that you are not getting any leaks from the bottom of the machime as your new pump won't last long if it gets wet also if there is water leaking that can be the main seal on the motor shaft failing
cheers grant
Oct 19, 2008 | Fisher and Paykel GWL11 Top Load Washer
Frigidaire Gallery Model FWT449GFS1
There is an obstruction in the drain pump. The only way to clear the obstruction is to remove the lower panel at the front by removing the 2 screws at the lower edge. This will allow the front panel to drop down. You will need to unplug the machine for the next part.
Now this will get a little messy... Be sure to have a lot of towels nearby to sop up the water. On the lower right hand side there is a pump with a black bellows attached which is also attached to the bottom of the tub. This black hose is clamped to the front of the pump if you unclamp the hose the remaining water in the system will spill out. You will have to reach inside the bellows and remove whatever obstruction is inside. some models will have a trap inside which may have to be removed from the top of the hose assembly by unscrewing the clamp on the bottom of the tub.
The hose will have to be reattached in the reverse manner. It can be quite tricky to do so... Once the machine is back together you can run a rinse and spin cycle, it should go into the full spin when all the water drains.
This procedure may have to be repeated a couple of times to completely remove all of the carpet fibres.
Aug 07, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Motor cuts out after spin cycle engages
yes the pulley system needs replacing theres a kit available that has all the washers etc you may have refitted in the wrong order.hope this helps.
Mar 26, 2008 | Maytag Performa PAV2200
Drain/spin cycle want start
open the cover on the pump, lower left. Make sure machine is unplugged take your finger and fell inside the holethat goes toward the tub and see if there is a clog.
Dec 01, 2007 | Bosch WFK 2401
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
35 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
