Question about DeLonghi Pinguino PAC-02 Air Conditioner
I have a k 900 and after a power serge it comes up with 8.8. when you plug it in and then goes to dd..that is all it will do..any suggestions
I have a samsung washing machine, a error message came up on the screen. 3e. we were advised to contact our after sales. we did, we were told by a service eng; the mother board was dud can you please...
Switch off the power/reconnect and try again, try unplugging power cord for two minutes, if problem persist follow instructions at the end of user manual to call service
Jul 24, 2008 | Samsung Washing Machines
Poor accelleration take off
Hi, Anonymous and the usual suspects are:
1. Throttle cables misaligned or misrouted.
2. Damaged or restricted fuel tank venting system.
3. Inlet system air leak.
4. Vacuum piston malfunction.
5. Accelerator pump leaking or no output.
6. Plugged bowl vent.
7. Fuel level in bowl too low.
8. Restricted fuel supply passages.
9. Plugged jets or passages.
10. Worn or damaged needle or needle jet.
12. The enricher valve not seated or leaking.
For more information about your issue please visit the websites below. Good luck and have a nice day.
https://dl.dropboxusercontent.com/u/35177464/Tornado/900%20Tornado/Tornado%20workshop%20Manual.pdf
https://dl.dropboxusercontent.com/u/35177464/Benelli/TornadoWiringDiag.pdf
https://dl.dropboxusercontent.com/u/35177464/Tornado/900%20Tornado/TORNADO%20User%20Guide.pdf BENELLI TORNADO 1130 2003 2014 Review
Benelli Tornado 900
Feb 02, 2014 | 2005 Benelli Tornado Tre 900
How do i get the bike started
Check the start relay
Jan 23, 2014 | 2006 Sym DD 50
Everlast ev800 manual
I would suggest either contacting Everlast or Impex (I believe they manufacture Everlast's home gyms). I also found an assembly manual for EVE-900, which may be similar. You can find it here: http://catalog.impex-fitness.com/images/eve-900%20manual.pdf
Everlast
Phone: 800.821.7930
(Monday - Friday 8:00 a.m. - 5:00 p.m. CST)
Live Chat: (Monday - Friday 8:00 a.m. - 5:00 p.m. CST)
Email: orderpro@everlast.com
Fax: 800.480.0348
Mailing Address:
Everlast Customer Service
1900 Highway DD
Moberly, MO 65270
Impex
Tel: (800) 999-8899
Fax (626) 961-9966
www.impex-fitness.com
info@impex-fitness.com
Nov 09, 2013 | Everlast Exercise & Fitness
My HV DD gives a "motor overloaded" code after the power went out in the middle of it embroidering
if there is a reboot option it should be in the instruction manual
if it doesn't show there, contact the one you bought the machine
from to see what they suggest.
you said you had the machine plugged into a serge protector
I also suggest a battery back up you can get them at different stores
like wal mart or best buy, that way if the power goes out the battery
back up will kick in and keep the embroidery project going, the
battery back ups have different time amounts on them, we have 2
battery back up, one for our desk top pc and the other for our
daughters pc for her school work and they do come in handy.
Dec 03, 2012 | Sewing Machines
When HP laptop is pluged into power source screen goes dim
Right click on the battery icon in the taskbar, go to Power Options or something similiar. Change the plan settings for the power plan you're currently in. Check the brightness ratio for both battery and plugged in mode. This problem might come if you or someone had tinkered with the settings.
Jun 20, 2009 | HP Pavilion dv6000z Notebook
Saab 900 Automatic (not starting)
Your Neutral Safety Switch is bad.
Apr 08, 2009 | 1996 Saab 900
SmartParts SP1100B 11'' picture frame won't turn on
sounds like there was a power serge.  One of the suggestions would be to make sure you use the "safely Remove Hardware" tab on the tool bar.  The USB cable actually has power that goes through the line and can damage the flash memory in the picture frame.
your one hope would be to try another USB cable.
Mar 18, 2009 | Computers & Internet
Power serge
ok First question does the led continue to blink after 70 seconds after u plug it in. it is common for a cuircit board called the dm(digital module) to go bad in these units. this set has a keyboard lockout feature. Press menu for 10 seconds on front panel. if that does not release control then u more than likely have a problem with dm module. there are several bullitens about this and several things a tech can do to repair this set
Jan 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
DeLonghi Pinguino PAC-02 Air Conditioner Logo
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
