Question about Frigidaire Electric Dryer
The heat is not turning on and it quits after around 10 to 15 mins
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
WHAT SHOULD THE heat anticipator BE SET AT ON A MODEL COAT066BDA COLEMAN EVCON FURNACE
The typical starting point for heat anticipation is .4 amp. If you do not have a clamp-on ammeter, adjust it to .45 and observe operation for a few days. If not quite right and still short cycling slip it to .5. Then keep doing this until you are satisfied cycle time is correct.
If you have an amprobe or can borrow one, remove the stat and take a single loooooong thermostat wire. Attach it to the R or Rh and wrap it around the clamp on ammeter ten times then attach the other end to the W terminal. The furnace will initiate the heat cycle at that point. Observe the amp reading on the amprobe when full heat is on, DIVIDE that reading by ten (for the wraps of wire) and adjust the heat anticipator to THAT setting.
Feb 05, 2015 | Coleman Heating & Cooling
I don't know whats the matter with my 2000 hyundia elantra i can turn in on for 10 mins and then it will just turn off and then later on that day it will turn back on.
ignition control modual is going bad, They last about 10 yrs . when they heat up ,they short out and quit operating until they cool down..Go to the auto parts store and check prices before you purchase it. They are a non returable part because they are electrical, so check around before you buy one.Get the best price and warranty..They are not that hard to change out,if you can handle a screwdriver you can do this.If you take it to a shop, then no more than 30 min. repair...max....
May 26, 2011 | Hyundai Elantra Cars & Trucks
Ltv30w2 what part needs replacement when audio/video just quits after about 10 min. ? signed; rod. ( used to repair black and white t.v. 's before color was invented ) <...
Hello Friend,
This issue seems to be due to over heating of power transistor in the power supply unit. Try replacing them. Also replace main big capacitors which could be leaky around that transistor . your issue should be resolved with this.
Thanks,
Shiva
Dec 19, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Model ace184xro quits running on heat about 20 min after turned on. Will not reset.. any solutions
Check your heating sensor. May be defective or misplaced. And also check your temp setting +8 degree from your room temp.
Dec 14, 2010 | Whirlpool ACE244XS Air Conditioner
2007 Pontiac G6 GT radiator fan keeps running after engine is turned off. Runs for another 4-5 mins after engine is turned off.
Heat sensor keeps blowing air thru radiator until it cools, then cuts off. Some auto do this. If it bothers you let the engine idle a few min. after you drive it and then turn car off. When you drive your car and the engine is hot it heats up even more when you turn it off because the water has quit circulating. The fan will run til it cools. It's supposed to do that.
Sep 03, 2010 | Pontiac G6 Cars & Trucks
My 2000 lincoln Ls Over Heating
bleed all the air out.....
Jun 15, 2010 | 2000 Lincoln LS
My 2001 case 586e forklift will just quit running
check the fuseable links arround the starter
somtimes they seperate when they over heat and the ruber contracts when they cool down
if they are cooked they will pull apart fairly easily when hot
Sep 16, 2009 | Milwaukee Tool Case Heat Gun
Frigidaire  Electric Dryer Logo
41 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
