Question about Whirlpool Calypso GVW9959K Top Load Washer
Wash does not drain. Code reflects FL Do not know how to remove front panel
    Brigadier General:
  • 8,619 Answers
Thanks for using FixYa. Error LF or FL means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
Hoshizaki am-25ae. We have inherited a AM-25AE with the lodge we bought and it works just fine. We do want to give it a very good clean inside and disinfect the whole water 'way' to ensure the ice won
Cleaning Instructions:
Water System
1) Dilute approximately 5 fl. oz. (148 ml) of recommended cleaner Hoshizaki " Scale Away" or "Lime-A-Way" ( Economics Laboratory, Inc) with 1 gal. (3.8 lit) of water.
2) Remove all ice from the Evaporator and the storage bin. Note: To remove cubes on the evaporator, remove the front panel ( Lower), move the control switch on the control box to the "OFF" position and move it back to the "ICE" position after 2 minutes. The harvest cycle starts and the cubes will be removed from the evaporator plate.
3) Move the control switch to the "OFF" position. Close the water supply line shut-off valve.
4) Remove the water tank to drain the water. Refit the water tank in its correct position.
5) Slowly pour the cleaning solution into the water tank.
6) Move the control switch to the "WASH" position.
7) After circulating the cleaner solution for about 30 minutes, move the control switch to the "OFF" position.
8) Remove the water tank to drain the cleaning solution. Refit the water tank in its correct position.
9) Open the shut-off-valve.
10) Move the control switch to the "WASH" position to circulate clean water for about 5 minutes.
11) Move the control switch to the "OFF" position and immediately back to the "WASH" position to rinse water.
12) Repeat the above rinse procedure three more times to rinse thoroughly.
13) Dilute approximately 0.5 fl. oz. (14.8 ml) of 5.25% sodium hypochlorite (Chlorine bleach) with 1 gal. (3.8 lit) of water.
14) Move the control switch to the "OFF" position. Close the water supply line Shut-off-valve.
15) Remove the water tank to drain the water. Refit the water tank in its correct position.
16) Slowly pour the sanitizing solution into the water tank.
17) Move the control switch to the "WASH" position.
18) After circulating the sanitizing solution for about 15 minutes, move the control switch to the "OFF" position.
19) Remove the water tank to drain the sanitizing solution. Refit the water tank in its correct position.
20) Open the shut-off valve.
21) Move the control switch to the "WASH" position to circulate clean water for about 5 minutes.
22) Move the control switch to the (OFF) position and immediately back to the "WASH" position to rinse water.
23) Repeat the above rinse procedure two more times to rinse thoroughly.
24) Move the control switch to the "ICE" position, and start the automatic ice making process. Refit the front panel (LOWER) in its correct position. abut do not forget to wash and sanitize the ice bin.
Sep 01, 2014 | Kitchen Appliances - Others
Whirlpool front load washer is giving a FL CODE
Hello Tresea , it sound like a FL code has cause this following problem at best FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed. Are you using a HE type soap? If not you must reduce the amount being used. Is the pump draining? let us know.
May 04, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Machine stoped after wash cycle tub did not drain and reads F L kenmore elite calypso model #22064 100 type 170 cannot get it to start at all it keeps beeping and reads FL
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%#@$
Feb 09, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
What is error code flashing Fl represent? Can you just fill the tub with water from an external source and expect the machine to go into wash cycle by preesing start? Does the tub have to fill throug pump...
Flood Condition:
Jan 07, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My bosch classix 1200 fl wont spin or drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Oct 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Kenmore Front Load Washer filling up and giving LF warning
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!##@
Oct 15, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Calypso SM9710976A has "FL" on front panel. Whats wrong?
Flood Condition:
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^!!$#
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
Code FL, won't empty tub on last cycle
FL = Flood condition
This problem i see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
May 04, 2009 | Kenmore Elite 45986 Front Load Washer
FL error on my Whirlpool washer
Flood Condition:
Dec 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso fl error
Look along the seam in the front of the washer where the top meets the front panel. About two inches in from each side is a retaining clip. If you take a putty knife and push in on the clip while lifting up on the top, the top of the washer should open up. You may need the assistance of another person and use two putty knives at the same time. It can be a bit tricky sometimes, but the top does open in this manner. Once you have the top open, carefully rest it against the wall behind the washer. There will be a screw holding the front panel on at each top corner. Once you remove the screws, the front panel should come off exposing all the internal components of the washer. You can also remove the back panel for additional access. I hope this helps you.
Sep 08, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
111 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
