Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Removing the rear tire to repair a flat. i don't know how to get the plastic cover off the axle shaft to get to the axle nut
    Problem Solver:
  • 3 Answers
Pull off the rubber cap. Make a tool by bending a piece of wire or preferably metal and pull the cap towards you until it slides off.
Posted on Nov 09, 2010
How do I change back tire on a Toa Toa 50 cc scooter?
A single bolt with a cotter pin holds the rear wheel on the axle, covered with a plastic dust cap. Remove the cap, Remove the pin, then use a pry bar to hold the wheel in place while you undo the axle nut. Once removed, tap the end of the axle with a rubber mallet or use a piece of wood and a hammer until the wheel comes loose. Remove, use motorcycle tire tools to remove tire, replace tire, and remount wheel. Use a new cotter pin.
Sep 28, 2014 | Motorcycles
What is the foot pounds for the front wheel bearings on a 1995 chrysler cirrus
Hello, If you Chrysler has replaceable wheel bearings and seal. This is the way it goes---pack the wheel bearing with new grease-install the bearing in the wheel nub--install new back wheel seal--coat the axle shaft with grease lightly, thing coat-----install wheel hub on to axle shaft...be careful here don't damage the rear hub seal------------insert front race washer---install axle shaft nut--tighten nut down wheel nut until it is firm with water pump pliers----spin the hub/with tire mounted.
(the wheel and hub will turn but not freely)----take the pliers and back off the axle nut 1/4 turn----now spin the wheel and axle hub, it should spin freely---now if doesn't spin freely---back off the axle nut about 1/16 or 1/32 (or just a little bit)-----now, spin the wheel and hub and if turn freely------------Now grab the top of the wheel/tire and move it back and forth.-----if there is some movement ---try tighten the axle nut just a little little bit, unit the one can barely feel some little movement in the wheel/tire and hub.-----------Now, spin the wheel/tire and hub and it should also turn freely.
If it does----install new and correct size of cotter pin and bent the ends around the axle nut.----
coat the inside of the hub cup with grease. Now, use an rubber or plastic hammer to install the cup on the wheel/tire hub. You are finished with one wheel bearing maintenance. Now do the other side.
I really don't know if you Chrysler Cirrus has replaceable wheel bearing. All the auto/trucks have replaceable hubs, that means that the replacement is total hub with axle shaft, sealed bearings, and seals. This is bolt to each wheel steering hub. This work to remove these one unit hubs.
Four bolts hold the axle hub to the steering hub. Hear is the problem!! it has rusted to the steering hub. Also, these hubs cost more than replacing bearings, races, seals to cool turn of $180 to $250+ I wish you luck in your replacement of wheel bearing on your Chrysler. GB..stewbison
Sep 24, 2011 | Chrysler Cirrus Cars & Trucks
1998 ford explorer 2 wheel drive rear wheel bearing replacement
what about it?
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear 1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s) swn~us~en~file=st1514a.gif~gen~ref.gif Axle Seal Replacer
T83T-1175-A swn~us~en~file=st1283a.gif~gen~ref.gif Axle Wheel Bearing Puller
T83T-1225-A swn~us~en~file=st1322a.gif~gen~ref.gif Axle Wheel Bearing Replacer
T83T-1225-B swn~us~en~file=st1326a.gif~gen~ref.gif Driver Handle
T80T-4000-W swn~us~en~file=st1185a.gif~gen~ref.gif Impact Slide Hammer
T50T-100-A
Removal
  1. Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft Removal
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
    Loosen the lug nuts (1012).
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
    1. Remove the lug nuts.
  1. Remove the axle housing cover (4033).
    1. Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
    1. Remove the axle housing cover bolts.
    1. Remove the axle housing cover.
  1. Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-rings in the U-washer grooves.
    Remove the U-washers (4N237).
    1. Push the axle shafts inboard.
    1. Remove the U-washers.
  1. Reinstall the differential pinion shaft.
    1. Install the differential pinion shaft.
    1. Install the differential pinion shaft lock bolt finger-tight.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal (1177).
    Remove the two axle shafts.
Installation
  1. Lubricate the lip of the inner wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal.
    Install the two axle shafts.
    Install the U-washers.
    1. Position the two U-washers on the button end of the axle shafts.
    1. Pull the axle shafts outward.
    1. Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
    1. Install the differential pinion shaft lock bolt.
  1. Install the rear disc brake rotors; refer to Section 206-04 .
  1. Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub and mounting surfaces.
  1. Install the tire and wheel assembly.
    1. Position the tire and wheel assembly.
    1. Install the lug nuts and lower the vehicle.
    1. Tighten the lug nuts.
    1. Install the center cap.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time.
    NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris.
    Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
  1. Lubricate the new rear wheel bearing.
    1. Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
  1. Lubricate the lip of the new axle shaft oil seal.
  1. Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
  1. Install the axle shaft; refer to Axle Shaft in this section.
May 18, 2011 | Ford Explorer Cars & Trucks
How do I remove the rear axle
The rear axle shaft?? Or the entire axle? I'm going to go with the axle shaft. Secure the vehicle. Loosen the lug nuts. Jack it up. Take the wheel and tire off. Remove the caliper and/or bracket. Remove the rotor. Place a pan under the rear differential cover. Remove the rear differential cover. Spin the axle shaft to reveal the center pin. Locate the 8mm-5/16 bolt that holds the center pin in place. Remove that bolt. Slide the center pin out, BUT DON'T TURN THE AXLE SHAFTS WHILE ITS OUT! Push the axle shaft in from the outer portion (where the wheel goes). A "C" clip will fall out inside of the differential. Pull the axle shaft out. Slide the center pin back in. Replace the 8mm-5/16 locking bolt and spin it a few times to keep everything in place.
Feb 23, 2011 | 2000 GMC Jimmy
I have a 1998 gmc 1/2 ton 4wd pickup, Its making whirling or growling noise in the rear end. I put new u-joints on and drained the oil out of the rear end and found a magnet in the bottom of the gear case...
checking the bearings is a great place to start. to take the axles out you will need to remove the tires and axle cover in side there is a center pin with a single bolt holding it in. remove the bolt and gently pull the pin out DO NOT ROTATE THE AXLES after you remove the pin this will cause the spider gears to fall out of place. once you have the pin out push the axle in towards the ring and pinion and ther will be a c clip to pull out i use a magnet. installation is just in reverse just be careful not to turn the axle sometimes lining the spider gears back up can be a pain. hope this helps
Jan 30, 2011 | Chevrolet Chevy Cars & Trucks
I need to remove my front axel on my 1989 toyota camry
Jack up car and apply e-brake. car will roll if one of the front tires leaves the ground. remove tire , spindal nut and lower ball joint bolts. remove axle from hub then use a prybar to pop it out of trans. the passenger side will have a braket holding axle to engine , remove bolts from braket or squeeze snap-ring to rmove axle from braket.
Jan 11, 2011 | 1989 Toyota Camry
Need specs for changing rear and front tires for 2002 royal star venture including torx specs
I'll include the obvious, since I'm not sure exactly what you need:
Front tire - 150/80-16 Dunlop D404F or Bridgestone G705, recommended inflation 36 p.s.i.
Rear tire - 150/90-15 Dunlop D404 or Bridgestone G702, recommended inflation 36 p.s.i., 41 p.s.i. with passenger or load.
The front tire can be removed (motorcycle on lift) without loosening calipers or any other parts once axle shaft has been withdrawn; after the tire has been changed and the wheel and axle shaft is back in place, torque for the axle nut is 58 ft.-lbs (78 nm) and the pinch nut is 14 ft.-lbs. (19 nm).
The rear tire requires removal of the right saddlebag and brake caliper, as well as the axle shaft. During reassembly, the torque for the axle nut is 110 ft.-lbs. (150 nm), for the pinch nut on the swing arm 17 ft.-lbs (23 nm). Bolts for the caliper should be torqued to 30 ft.-lbs. (40 nm).
It's a good idea to lubricate the drive splines in the rear wheel and the mating shaft in the final drive while the rear wheel is out.
Apr 15, 2010 | 2002 Yamaha Royal Star Venture
How do i get the back tire off my 1982 vf 750 sabre??
put bike on support stand or jack up rear wheel. remove small plastic cover on the left side swing arm and remove nut that anchors brake drum housing to the swing arm support. remove the rear brake linkage from the rear drum. remove the axle nut and slide out axle shaft from axle housing. Be careful to notice the position of the spacer and washers. the installation is the same as removal. be sure to re-adjust the rear brake linkage. If adjusted properly prior to removal it might help to mark the position of the nut on the linkage before removing.
Mar 30, 2010 | 1982 Honda VF 750 S
How do you change a wheel seal on a mercury mountaneer 1998 rear end
Axle Vent
NOTE: If the vent cannot be cleared, it must be installed new.
A plugged vent will cause excessive seal lip wear due to internal pressure buildup. If a leak occurs, check the vent. Make sure the vent hose is not kinked. Remove the hose from the vent nipple and clear the hose of any foreign material. While the hose is removed, pass a length of mechanics wire or a small diameter Allen wrench in and out of the vent to clean it. Connect the hose when done. The vent is located on the drivers side top of axle housing.
If you plan on doing most repairs yourself I would suggest buying a Haynes or Chilton manual for your particular vehicle. Or there are some data disks on e.bay($12-$15) For a cost of under $25, you can almost do any repair yourself with these manuals.Also there are online manuals like the site called ALLDATA where guides can be viewed for a fee. All these solutions will save you time and money, and give peace of mind over correct repairs. I can post you some procedures here also.
  1. CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
  2. Loosen the lug nuts (1012).
  3. Remove the center cap.
  4. With the weight of the vehicle on the wheels, loosen the lug nuts Raise and support the vehicle. .Remove the wheel and tire assembly.
  5. Remove the lug nuts.
  6. Remove the wheel and tire assembly. Remove the axle housing cover (4033).
7.Remove the rear disc brake rotors You will have to remove the brake caliper to get rotor off.
8. CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
9.
1.Remove the differential pinion shaft lock bolt. 2.Remove the differential pinion shaft. 4fd1df0.gif 10.CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Remove the U-washers (4N237).
  2. Remove the U-washers.
    11.Reinstall the differential pinion shaft.
      12.CAUTION: Do not damage the inner wheel bearing oil seal (1177). Remove the two axle shafts. 1848771.gif
CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time. NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris. Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
0ffed5b.gifAxle bearing puller end..
Installation
  1. CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  2. Remove the differential pinion shaft.
  3. Remove the differential pinion shaft lock bolt.
  4. Remove the differential pinion shaft.
    CAUTION: Do not damage the inner wheel bearing oil seal. Install the two axle shafts. CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Install the U-washers.
                                                            Install the rear disc brake rotors; Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant
                                                            WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control. Clean the wheel hub and mounting surfaces. Install the tire and wheel assembly.
                                                            Position the tire and wheel assembly. Install the lug nuts and lower the vehicle. Tighten the lug nuts. Install the center cap. 6a78fd6.gif WHEW Hope this can help you
                                                            Mar 21, 2010 | 1998 Mercury Mountaineer
                                                            Need to know how to change rear wheel bearing in a 95 suburban
                                                            jack & support vehicle. remove rear axle cover drain fluid, removeleft rear tire drum/rotor brakes, remove bolt in axle housing that holds the 3/4 inch pin in place pull pin , push left axle shaft inwards and remove c clip from inside axle case,slide out axle shaft,remove seal,remove bearing and install in revers
                                                            Jan 16, 2009 | 2003 GMC Sierra
                                                            Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
                                                            133 people viewed this question
                                                            Top Craftsman Garden Experts
                                                            Wade Mobley
                                                            Wade Mobley
                                                            Jim Parker
                                                            Jim Parker
                                                            Dennis Key
                                                            Dennis Key
                                                            Are you a Craftsman Garden Expert? Answer questions, earn points and help others
