Question about Linksys Wireless-G Broadband Router
After working for 2 days it will not allow us to connect to the internet then after i unplug the power then hook back up it works
  • 1,218 Answers
In order to set wireless printer in Windows 7-based PC, you need to position it in a central location away from metal objects. Now, find out if it a Bluetooth or Wi-Fi as most new printers are equipped with either Bluetooth or Wi-Fi technologies. After, that enables the sharing of your printers by informing computer’s operating system about adding printer to its network. Also, install drivers for the same. Hence, in this way you can set up wireless printer on Windows 7-based system. You can also set up other computer systems in the network for using wireless printer get more information for Set Up Wireless Printer on Windows 7 .
Posted on Sep 07, 2010
I cannot get the TV to connect to the internet any more. One day it was working and the next it was not. I have rebooted the entire system to factory settings, taken out the power cord, rebooted the...
Error 1106 is an indication that the Domain Name System (DNS) was unable to resolve. Follow the steps to check the Internet connection: 1. Check the Network Connection. 1. Using the supplied remote, press the Home or Menu button. 2. Select Network Setup . 3. Select View Network Status . 4. Select Check Connection . If any of the connection settings fail, verify that the TV is properly connected to an active Internet connection. Follow these steps, if the error continues to appear: 2. Unplug the TV and wait 60 seconds. 3. Power on and off all of the networking equipment, including the modem and router. 4. Allow the Networking equipment to reset after powering them of and on. Test that the connection is active by using a computer. 5. If the issue continues, wait and try viewing the content later.
Sep 18, 2011 | Televison & Video
Connecting to matchmaker server is not working
Try resetting your modem and PS3's internet connections..
Turn off PS3 system..
1: Reset your modem by unplugging it from the main power source.
2: After a few minutes, plug modem power back into modem. Allow all connections to configure
3: Turn on PS3 system.
4: Go to "Settings" then scroll all the way down to "Network Settings"
5: Make sure that the "internet connection" (the second menu) is "Enabled"
6: Go to "Internet Connection Settings" and go through the motions again.
Good luck.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
The playstation was turned off while playing online and now the online connection is not working.
Good luck.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Unable to connect to internet through Linksys WRT160N router. Can unplug it and internet is fine. Tried power cycling the modem and router. Linksys comes up with all lights flashing and will not...
If I understand your problem correctly, you are able to connect to the Internet when you hook the computer directly to the modem, but not when the router is connected to the modem.
If this is the case, then you need to do a power drain on the modem. Power cycling the modem is not enough to clear the NVRAM of the MAC address of your computer. You have to unplug the power cord of the modem for 15 to 20 minutes in order for the NVRAM to reset and allow the modem to recognize the MAC address of the router.
After the modem has been unplugged for 15 to 20 minutes, disconnect the power cable from the router and then connect router to the modem using the Ethernet cable.
Next with the router power cord still disconnected, plug in the power cord of the modem and allow the modem to sync to the network.
Once the modem is finished with its start-up, plug-in the power cord of the router and let it sync to the network.
After the modem has completed its start-up, it should now be connected to the internet.
Good Luck
Dec 30, 2010 | Linksys WRT160N Wireless Router
I have a used ps2 system (its in good condition), i love splinter cell games, i have splinter cell pandora tomorrow. The first time i got it it worked fine, all i just needed was to hook up the internet....
more than likely you need to reset your modem.
turn off the power on your modem. unplug the power wire from your modem and unplug the coaxial wire to your
modem.
wait a minute or so and
first hook up coaxial cable to modem
then plug modem back in try it again and hopefully you will be back on line.
You just have to reset your modem connection.
This has happened to me before too.
If you have a router do the same thing.
If it does not work try the same procedure one more time.
it should work.. Good luck
leave a good rating if you appreciate my help.
Mar 27, 2010 | Sony PlayStation 2 (PS2) Console
I moved my computer - unhooked the modem and wireless router and
Powerdown the PC, router, and modem then start the modem first then the router and finally power-on the computer... That should do it! Hope it helps!
-- Joshua79
Apr 04, 2009 | Belkin (F5D7230-4) Router (587009)
Can't connect Motorola sb5100 to a Linksys wrt54g
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please Rate
Jan 29, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Router worked. Modem quit. Now it won't work with new modem
Ok in this case the problem is more than likely a generic one for all modems. All modems like to bind themselves to whatever device you have initially plugged in when you plug in the power cable for the modem. My guess is you had the pc hooked up directly to the modem and then plugged in the poewr cable to the modem.
To fix this you need to unplug the router and modem cables for 2 minutes. Plug in the modem with it being hooked up to nothing but the wall [Power Cable and Internet Cords hooked up only; no pc yet]
Your router is probably not need to be bridged so there should be a small hole somewhere on the router normally on the back or bottom saying reset. Press and hold that button with the router only plugged into the power no internet or pc [Although it doesnt matter if the pc is hooked up to the router] for at least 10 seconds. This will cause the router to reset to the factory default settings undoing the bridge. After this time the modem should say it has internet and whatever else except a activity light and similar things.
What you want to do now is unplug the router from the power and hook up the modem to the router and then plug the power cable back into the router.
After all this you should be able to go into the pc and access the router and set up the settings you like or need for the router if you want. Otherwise you should have internet again.
Jan 13, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G Broadband Router Logo
48 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
