Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
I travel a lot and the the washing machine was left closed for a few months. I now have an odor that I can't get rid of even though I have run cycles with bleach and now leave the door open when I will be away for extended periods. Any ideas how I can get rid of the musty/mildew scent in my Kenmore H3 front loading Elite washing machine?
  • 4,340 Answers
There is a special deodorizer available for this issue, try that...it is a common issue.
Posted on Sep 06, 2010
Lots of mold around rubber gasket; unable to clean off; odor from mold; water in detergent trays; maybe some water leaking from washer; washer bought in 2008
Use a s.o.s pad to remove mold there will still be staining but it will gey the bulk of.Now to get rid of the smell ( this has been a mixture I have used for about ten yers works every time) put the washer on hot heavy wash start when done filling drain what you want to do is make sure the water is the hottest it can be. now start washer again on hot wash when you see water in bottom of tub stop machine to open door ADD two cups of dish washing power( brand does not matter I tell most people to buy cheap stuff at walmart) start machine let it run till you see powder disolve then stop washer and add 1 cup bleach. let unit go through complete cycle..If your washer has a clean cycle use that instead of the heavy or normal cycle. The most I ever had to do this treatment was 2 cycles and it worked every time.Note all front load washers the door must be left open to pervent odor/bellows should be wiped clean after each use/and a good cleaning at least once a month. anyhow if this helped please vote if you need more help please ask
NOTE the dish soap is the stuff for a dish washer
Feb 09, 2011 | Frigidaire GLTF2940ES Front Load Washer
My front loading washing machine has a musty odor. what can I do?
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle(on hot water cycle). Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
  • Additionally, inspect the door gasket for gunk or mold. Clean the gasket well. This is another gathering spot of bacteria and mold growth.
Jun 28, 2010 | Kenmore Washing Machines
Washer has ordor
run a cycle with a heathy amount of bleach on hot. Odor is usually due to bacteria or somehting left behind. Is there any filter that can be cleaned??
Jer
Jan 16, 2010 | Kenmore HE2 Plus Front Load Washer
Sewer smell when I use the front load washer
try rid-x see if that helps pour down drain pipe for washer then add water you may also want to pour rid-x through toilet as well and bleach out washer
Dec 15, 2009 | Frigidaire ATF6000ES Front Load Washer
My washing machine has a musty smell. How do I clean it?
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Dec 04, 2009 | LG Washing Machines
My machine has such a strong smell when the door is left open that is goes thru my whole house. I have black mold in the rubber ring - my machine is only 2 yrs old. Is LG helping their consumers?
Nov 09, 2009 | LG WM2688HWM TROMM SteamWasher
Rotten Egg Odor from washer
NOTE(Follow the procedure correctly as stated. If the issues persist, this may lead to a deceased rodent, or small mice that has crawled into the unit to die. This is highly uncommon, but possible)
Nov 02, 2009 | Whirlpool GHW9100L Front Load Washer
Washing machine smells like stagnant water...making clothes smell bad as well. No visible water laying anywhere
Oct 31, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Clothes dont smell clean after washing them
Oct 25, 2009 | Maytag Washing Machines
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
77 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
