Question about Nintendo NES Console
How do i properly connect my nintendo nes sytem to my direct tv. when i use the av cables i just get a blue screen. can u give me step by step to connect correctly.
  • Nintendo Master
  • 424 Answers
Note: This type of connection is not possible with the newer-style NES.
Installation Steps:
Locate the Audio/Video inputs on the back of the TV.
Place the yellow end of the AV cable into the Video "in" on the back of the TV. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
On the other end of the AV cable, plug the yellow end into the "Video" (yellow) input. Plug the white or red end into the "Audio" (red) input, on the back of the NES.
After the system is connected to the TV:
Insert the Game Pak firmly into the Control Deck.
Plug the Controller(s) into the front of the system. Use the far left port for player one.
Plug the AC Adapter into the back of the system . Plug the other end into a wall outlet.
Press the Power button in on the front of the NES.
Turn on the TV and locate the input select. It is often called: TV/Video, input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The game image should now be displayed on the screen. You are ready to play!
If after following these directions you are not able to view the game (for instance, if the red power light flashes off and on), try our Troubleshooting Tips.
Installation Steps:
Place the yellow end of the AV cable into the Video "in" on the back of the VCR. Connect the white or red end of the cable to Audio "in" ("left" or "mono"). Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
After system is connected to the VCR:
Plug the Controller(s) into the front of the Control Deck. Use the far left port for player one.
Plug the AC Adapter into the back of the Control Deck. Plug the other end into a wall outlet.
Set the VCR's TV/VCR button to VCR. You can put a movie in the VCR, press play, make sure you see the movie on the TV, then press stop. This puts your VCR into VCR mode.
Turn on the NES by pressing the Power button on the front of the Control Deck.
Turn on the VCR and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
The Game image should now be displayed on the screen.
Recording Game Play
Set up the NES to play a game.
Insert a videotape and press Record. You can now tape your video game playing for posterity!
Posted on Nov 02, 2012
  • 47 Answers
SOURCE: Nintendo NES Repair
Hi sounds like your console has a weak connector pin and is lsing contact with your game. I fixed mine buy purchasing a new connector pin from www.gameoz.com.au and it included step by step instructions with photos and a few tips on how to clean NES cartridge games as their is no use in installing a new 72 pin connector if you dont properly clean the NES games because installing dirty games into a new connector pin will result in console blinking flashing again.
Posted on Mar 29, 2010
  • 14 Answers
SOURCE: instructions for NES nintendo console
Nintendo Entertainment System (NES) Instruction Manual
I hope this helps.
Posted on Jan 07, 2009
  • 6 Answers
SOURCE: just bought a super nintendo but doesnt have tv
U R AN IDIOT!!!! GO BUY THE CABLE ON EBAY!!!! ITS PROBABLY LIKE $4
Posted on Jun 19, 2009
  • 4 Answers
SOURCE: Nintendo Wii AV Cables not work
The AV cable that came with the Nintendo Wii is not designed for high-definition TV (HDTV) or enhanced-definition TV (EDTV) to view 480p progressive output. If you are connecting to a 480p TV, you will need a Wii Component Video Cables (maybe like the Gamestop cable you have).
Posted on Jul 27, 2009
dropndeal
  • 134 Answers
SOURCE: how do i get my nintendo nes to work through a
Use the RCA AVI outlets on the side of the NES and not the RFI (cable) outlet on the rear of the unit. Tune your TV to the appropriate Video Input channel.
If still no signal, try another set of AVI cables.
Try the console on another television.
If no output from the NES, then it will require refurbishment. Click here for more information.
Please let me know how I may assist further.
Posted on May 07, 2010
Why arn't i getting a picture on my snes
Make sure your system is hooked up correctly. This is the number one reason for a blank screen. To ensure all hookup connections are firm and correct, remove the AV cables and reinsert them with a slight twisting motion (this will help fully seat the connections). For more information about connecting the system, check the following hookup steps:
Audio/Video Cable to a TV
Audio/Video Cable to a VCR
Make sure you are using all licensed accessories with your system. Unlicensed products are not fully compatible with Nintendo systems and may not work correctly.
Make sure the system has power. If not, go to the No Power Light instructions.
Slide the Power Switch on the Control Deck to the OFF position. Remove the Game Pak and re-load it, pressing firmly to ensure it is locked in place. Slide the Power Switch on the Control Deck to the ON position.
Important Note: Inserting the game with the Power ON may result in a blank screen. Always turn your system OFF before inserting or removing Game Paks
There may be a problem in one of your hookup cables and not your system. Try purchasing a new connection cable (where to buy). You can also try borrowing the cable from a friend to see if it solves your problem before purchasing a new item.
If the above troubleshooting doesn't fix the problem, click here.Note: pictured above is the redesigned Super NES. The original Super NES uses the same hookup steps listed below.
Installation Steps:
Place the yellow end of the Stereo AV cable into the Video "in" on the back of the TV. Connect the red end of the cable to Audio "in" Right. Connect the white end of the cable to the Audio "in" Left. Use a slight twisting motion when inserting each cable and ensure the cables are firmly pressed into the input.
Note: If you have a mono television with only one Audio input, click here for a diagram of how the hook-up will look. The Y-adapter pictured is optional; you can also simply leave the white cable disconnected instead.
Connect the rectangular (gray) plug of the Stereo AV cable into the "multi out" connector on the back of the Control Deck.
Slide the Power Switch on (toward Game Pak).
Turn on the TV and locate the input select. It is often called: input select, AUX (auxiliary), Line, Line In, Input, Source, Select, In, or EXT (external). Switch the input select to show the Nintendo game.
If after following these directions you are not able to view the game, try our Troubleshooting Tips.
Mar 29, 2013 | Nintendo Super NES Console
No audio video
NES AV to TV Hookup
Installation Steps:
Jun 05, 2012 | Nintendo NES Console
I have a super nintendo but not sure if i have the right cords i was woundering if you would know the numbers that are on the back of the cables or the power cable thanks
Installation Steps:
Mar 10, 2011 | Nintendo Super NES Console
Wii powers up doesnt have a picture or sound tv screen.
    • With the yellow, white, and red AV cables that came with your system:
      • Did you have to use the red/green/blue inputs on your TV because it doesn't have the standard (yellow) AV inputs? If so,click here for complete information on doing this type of hook up.
      • If this is your first time hooking up the Wii console or have you moved it to another TV, please click here to review our step-by-step connection guide. Our experience shows that many times this issue can be solved by double-checking your connection and finding the correct Input Select for your TV or VCR.
    • With the blue, green, white, and red component cables (sold separately):
      • Review our step-by-step Wii Component Cable connection guide to make sure the cables are properly inserted and that your TV is set to the proper input.
    If you have verified the connection is correct, and are still receiving a blank or black and white screen when powering on your Wii console, then the problem is likely with the system and it will need to be repaired. Please call 1-800-255-3700
Dec 29, 2010 | Nintendo Wii Console
I found a SuperNintendo that has been in our attic for many years, however when I conect it upo my TV cannot find the output from the SuperNintendo when it does a search. What frequency or channel does it...
Locate the TV's VHF IN [ANT, CATV, or 75(ohm)] or Cable Connector.
Disconnect the existing cable wire from the TV's VHF IN.
Connect the short, thick wire from the RF Switch (labeled ANT) to your TV's VHF IN.
Reconnect the existing cable wire (disconnected in step 2) to the silver post labeled ANT on the RF switch.
Connect the thin wire of the RF Switch (labeled Control Deck) to the back of the Super NES (labled RF Out).
On the back of the Super NES, set the 3/4 switch so that it matches the channel of the TV.
Note: The RF Switch does not produce stereo sound. To get stereo sound, connect your Control Deck to your TV or VCR using the Stereo Audio/Video Cable.
Plug the controller(s) into the front of the Control Deck. Use the far left port for a one player game.
Plug the AC Adapter into the back of the Control Deck. Plug the other end of the cord into a wall outlet.
Slide the Power Switch to the On position.
Turn on the TV and set it to the appropriate channel (3 or 4.)
The game image should now be displayed on the TV screen. You are ready to play!
If after following these directions you are not able to view the game, try our Troubleshooting Tips. Note: pictured above is the redesigned Super NES. The original Super NES uses the same hookup steps listed below.
Installation Steps:
Nov 27, 2010 | Nintendo Super NES Console
I bought a ac adaptor to my super nintendo, because the adaptor that I'd is a fuckin' fail, so when I bought a new super nintendo adaptor, but I can't see anything on my tv. The conexion is ok. What's up!?
Installation Steps:
Oct 10, 2010 | Nintendo Super NES Console
The screen is fuzzy - i'm wondering if it has something to do with the coaxial connection from the system into the TV. I have an LCD TV.
Well instead of using the rf switch you could use the av cable for NES instead or
the 3 in 1 rf switch then.
images?q=tbn:and9gcrbnoq7qlvo_fto5sm2x54uajxwba26o69iusfmp54v5znt00o8ehqopj8 images?q=tbn:and9gcracbkpnp2t4htfajea_1tmjifpnwacluvc7urvlramcabqhv8aurfvvq If you are using a digital tv instead of a CRT style tv use the av cable instead then.
Sep 01, 2010 | Nintendo NES Console
I HAVE A NINTENDO NES IT PLAYS FINE IF SOMETHING BUMPS THE AV CABLE THE SCREEN GOES BLURRY AND WE HAVE TO TWIST THE CONNECTION TO THE NINTENDO TO GET THE SCREEN RIGHT BUT IT DOESNT LAST LONG WHAT CAN I DO
Not so sure, I still have mine, but it is messed up. What I did is i went out and bought a FC Twin. Its a system that can play NES and SNES games. It is so cool and easier. You could try to get an FC Twin or go online and buy a new cord. Hope that helps.
Jan 19, 2010 | Nintendo NES Console
I cant tune in my nintendo do you know what its meant to be set too
Hi your NES should have on it's right hand side 2 Audio Video inputs have you tried connecting it to your TV via Audeo Video Cable and selecting Video channel on your TV dont worry about using the old RF switch they are for older TV Units. Here is a picture of what the AV Cables look like http://www.gameoz.com.au/store/nintendo-entertainment-system/nes-accessories/nintendo-nes-audio-video-cable-no-more-tuning.html
Jan 16, 2010 | Nintendo NES Console
My screen on my nes is blurry how can i fix that
If your screen shows a blurry image it can be a few possible things (and only these things).
1. The first and most obivous problem is being on the wrong channel - for example, if you are on Channel 3, but the switch on the back of your system is set to channel 4, you'll see a VERY fuzzy picture; simple switch to the other channel and it will come in clear.
2. Now...assuming you are on the correct channel, does your television receive other pictures clearly (for example if you change to a normal broadcasting station and it is still blurry, then it is a problem with your TV and not your NES system). Another way to test is to simply switch TVs and see if the same picture problem occurs.
If 1 and 2 are not the problem, them we know the problem is with your NES system and this should be an easy fix.
If you are using an RF Switch, then it is most likely the pin on either end of the switch has become bent (or was bent and now is bent back) and will no longer give a clear picture. The easiest way to test this is find a set of AV cables (any av cables - these are the red, white, and yellow cables that often hook DVD players to television). Find a set and just take one of those ends and connect it to the side of the NES system into the circle that says VIDEO and take the other end of that same color and put it into your TV into the circle that says VIDEO (note that the colors don't always match up on the newer TVs, just make sure that if you are using the yellow end of the AV cable and plug it into the video on the NES that you plug the other yellow end of the av cable into whatever color on the TV says VIDEO! Then change your tv to the cannel for that AV slot (usually AV 1 or INPUT 1). Turn the nintendo back on and see if the picture comes through clearly - if it does, it means you had a bad RF switch and you can either get a new one, or just use AV cables instead!
One of the above problems IS the problem - I've repaired over 1000 NES systems and 95% of the time it's just a bad RF switch (so the AV cable test works best)
Jan 14, 2010 | Nintendo NES Console
Nintendo NES Console Logo
121 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
