Question about GE DVL223EBWW Electric Dryer
My dvl223ebww makes a scratching noise whenever I use it. Any idea what the problem might be?
  • GE Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Sep 10, 2010
My Whirlpool Cabrio just started making a clicking noise. It's only a year old. Any ideas?
is it a noise like nails on a chalk board if so your heating element could be hitting the back side of your dryer and making a clicking noise or scratching sound does it heat and dry the same
Jun 27, 2011 | Whirlpool WED9200SQ Electric Dryer
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed.
Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Sep 06, 2010 | GE DVL223EBWW Electric Dryer
Disk eject
The disc might be scratched or incompatible with the PS3.
Jul 27, 2010 | Sony Playstation 3 (PS3) Console
Dryer does not start
Sounds like your motor has gone bad...
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 17, 2010 | GE DVL223EBWW Electric Dryer
Xbox makes a motor noise whenever theres a game in it
Hi, the optical lens assembly is misaligned for some reason. this assembly will need to be replaced asap.
It is best to replace the entire DVD drive in this case.
Jun 18, 2009 | Microsoft Xbox 360 Console
Tub making noise. How do I get to the pulley/ belt to oil the thing?
is this a gas unit or electric?...the pulley is normally accessed through the front. if you go here www.techray.com and click on the repair man on the left side they will have the information you need on accessing and replacing the parts needed please rank
Jun 14, 2009 | GE DVL223EBWW Electric Dryer
Clacking noise hard drive on HP Pavilion dv2700 Laptop
Laptop hard drives can be a bit louder than the new desktops and because you're closer may be more noticable. The sound from that youtube is about normal - this video is the sound of the heads crashing - mechanical drive failure. http://www.youtube.com/watch?v=LRj6dP1Pi1Q
Just to be safe - BACKUP your important data and if you don't have the install disks, make a set.
Feb 28, 2008 | HP Pavilion dv9000z Notebook
Panasonic AG-455 Problem
The noise is most likely bad bearings in the video head assembly. No longer available from Panasonic. The b/w recording problem is most likely caused by a bad video board inside the camera. Unfortunately, the video board is also no longer available.
Oct 27, 2007 | Panasonic AG-455 Camcorder
GE DVL223EBWW Electric Dryer Logo
82 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
