Question about Roper REX4634KQ Electric Dryer
Dryer squeaks loudly when running with heat on
  • Roper Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other connections.
Remove the lint filter screws and filter.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
Please rate me
Posted on Sep 07, 2010
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer drum has an intermittent squeak when running
there is a belt tension'er it might need to be replacing or temp fix greasing or drum bearing replacing or temp fix greasing to do this you will have to remove the drum
May 28, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
My dryer is making a loud squeaking noise when it
All dryers have to have a way of allowing the tumbler (that's the thing you put the clothes in) to turn freely, not all of them are the same tho,some use bearings, some use slides,others use rollers. Over time these rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise, The rear bearings will then start to make their way to china and cause the tumbler to rub into the heating element and OUCH! These things will cause the motor to prematurely DIE! Its best to examine the dryers, rollers, and slides when you first hear the noise, but who does?
Dec 27, 2009 | Dryers
My dryer squeaks loudly when running. I have
Yes .I would say its the jockey pulley @ fault..
Nov 22, 2009 | GE DVL223EBWW Electric Dryer
Dryer turns and heats, but makes a very loud squeaking (or should I say, SCREECHING) noise. The heavier the load, the louder the squeaking.
Does it sound like a belt ?
Or does it sound like metal ?
Might need to replace the drive belt..
Or - it could be the bearings..
Hope this helps !!
Rate me good ;o)
Jul 13, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Magic Chef Dryer runs fine but Squeaks loudly
this sounds like a drum guides that need replacing soon.
Jun 17, 2009 | Magic Chef CYG4000AWW Gas Dryer
My Amana dryer LEA30AW makes a loud knocking noise while running and then shuts down. There is heat. It seems to be worse with a larger load. Any ideas??? Thx
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fo
Jun 08, 2009 | Amana NDE2330AY Electric Dryer
Makes loud squeaking noise, cuts off after a few minutes
heatman101
bxx
Dec 02, 2008 | Maytag Neptune MCE8000AY Electric Dryer
Roper REX4634KQ Electric Dryer Logo
46 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Roper Dryer Expert? Answer questions, earn points and help others
