I am trying to connect my ps3 to the internet so i can update the software. it is asking for a WPA key to be typed in manually. i cannot find this
    Guru:
  • 689 Answers
Look on th back of your router for a sticker,enter this number either that or connect to an unsecured network.
Posted on Sep 06, 2010
Hello, i am having problems connecting to the internet with my Ps3. i select easy at network setting, then i select my routers SSID name, after that i type in the WPA key. but then it tries to connect...
Probably its a problem between the router keys and playstation's. Try to reset the router and let it with no password (just for a moment, dont worry hehe). Now try to connect. If it works, try to replace the security for WEP. should work.
Good luck
Mar 07, 2011 | Sony Playstation 3 (PS3) Console
Says need to update encryrtion key
It sounds like you changed the password for your router's WEP or WPA security key. You need to go into the Network Settings on your PS3 and set up a new internet connection. Once you do that it will ask you for your new WPA or WEP security key.
Hope this helps.
Jan 05, 2011 | Sony Playstation 3 (PS3) Console
How do i connect to internet with ps3, wireless, what is a wpa key?
WPA stands for Wi-Fi protected access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over WEP (Wired Equivalent Privacy) standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
You can correct this problem by entering the WPA Key into your PSP's Network Settings. But before you do that you need to know what your WPA Key is...
Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long.
For minimal security, you can choose 8 characters key, like "iN/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBDm+oMp$nrXj5XPVRTvVA5fpwGSGIRVz4RdQ7V3yl$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
Jan 02, 2011 | Video Game Consoles & Games
The PS3 will not play the new (BD) dvd I just hired .And i have never had this problem befor. Its askin me to renew my encryption key and says something about system software up date. I am not connected to...
All Blue Ray players need to be updated from time to time to keep up with the growing technology of Blue Ray. PS3 is the same way. It is asking you to update your PS3 in order to play the disc. On the back of the PS3 is a Ethernet port (looks like an over sized phone jack) connect this to your internet (modem) and it will update your encryption key and software needed to play Blue Ray discs. Here is a link for that as well.
http://manuals.playstation.net/document/en/ps3/2_60/video/aacs.html
Nov 02, 2010 | Video Game Consoles & Games
I have scanned for my internet and connected to it by typing in my wpa key. but when it comes to connecting the connection my ip address fail. do i type in my ip address manually? if so, where can i find...
First, make sure that DHCP is enabled.
Second, Don't use the pass phrase use the key.
  • For example, if you setup WEP to use a pass phrase like ROSEBUD, use the generated key code under it which would look something like AA34578E9...
Mar 08, 2010 | Sony Playstation 3 (PS3) Console
Tryig to connect my ps3 over wireless connection to my belkin f5d8236-4...its asking for a wpa key
Hi Johnny,
Please follow the below steps,
1.type 192.168.2.1 in the internet explore
2.you will be able to see the Belkin router setup
3.in your left hand side,you will see the menu "security below wireless"
4.it will ask for password leave it blank and click on submit
5.now you will be able to see the WPA key,
if it shows in dots,then uncheck the "obscer PSK" box now you will be able to see the WPA key.
Regards,
Ayyasam
Dec 30, 2009 | Belkin F5D8236-4 Router
I HAVE A WIRELESS ROUTER HOW DO I HOOK UP THE INTERNET T0 MY PS3
in the main menu go to the left side of it and choose settings ok then go down to network setting now inside the network settings go to the internet connection setting ok till now, it will ask to continue YES or NO, u chose YES now u will be signed out of network and 2 choices will appear askin u whats the type of inter connection ur using u Wired or Wireless u go with wireless okkk when u chose wireless it will be BOLD wireless NOW use the Arrow and press on the Right Arrow > another menu will appear choose Scan also press the Right Arrow > u will see ur Wireless name there maybe u will see other Wireless Internet connections but u have to choose ur OWN connection ok. now after choosing ur Wireless connection press X then Right Arrow now if u have a security key then u have to already know what type it is { WEB, WPA-PSK(TKIP), WPA-PSK(AES) or if u dont have a security key at all the choose none} okk try to use WEB while setting ur Wireless settings up its much easy to deal with and try to use an easy key like 12345678 or something like that any way after choosing it click Right Arrow u will see an Empty text area press X and u will see the PS3 keyboard right down ur wireless key then press start also press the Right Arrow keep pressing Right Arrow till u finally in a menu telling u to test ur internet connection press X and u will have ur PS3 connected through Wireless, ** maybe this seems to be a very hard thing to do but i swear its so EASY dot wury u will managed to make it work** have FUN man
Dec 10, 2009 | Sony Playstation 3 (PS3) Console
Ps3 error code 80711008 and wpa
OK for your WPA you can check the security key by accessing the router http://192.168.1.1 .. password is by default "admin" and username is blank...go to the "wireless" tab and check the ssid...under "wireless security" check the security key...if you have "wep" check the numbers in "key 1"....
now make sure that you connect to your own ssid and type the correct key...
and you are right , you need wlan to connect to the internet wirelessly...however , first make sure that you have internet working through the router..if not you will have to configure the router and for that you a computer connected to the router...
As for your IP address simple use this site http://www.ip-adress.com/ should be everything you need
May 30, 2009 | Sony Playstation 3 (PS3) Console
My PS3 is asking for a wpa key code so I can go online?
If you dont know your wpa network key try to reconfigure your wireless network again.
Access the configuration page of your router.
>Type on the address bar 192.168.0.1
>On login type Admin leave password blank. if you set up a password or the login page use that one.
>Once inside the Dlink Page
>Clik Setup and on the left side click wireless setting.
>If given the option to click on manaul wireless connection setup click on it.
>Once you have the wireles window
>try to change the network name to a new one and scroll down
>Under security choose WPA security (enhanced)
>Scroll down and under the Passphrase type in your new network password or security key and confirm it.
>Click on Save Settings
>If it asks you to reboot then reboot it, if not, its ok.
Jan 26, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
David Payne
David Payne
