Question about Sony CDXGT240 Xplod for your Car Car CD MP3 Player
Installed the receiver according to the directions, but it will not power up.
I have a week signal can yu tell me why please
Hi
Assuming your location receives an average signal strength from the transmitter, a weak signal reception, could be due to:
- Wrong location of your aerial.
- Is it obstructed by vegetation or other buildings?
- Is the aerial pointing in the right direction?
Check the internet for your nearest transmitter or repeater station in relation to your location so you can align you aerial properly (one trick is to look at the direction other aerials around you are pointing and follow accordingly)
Have you installed a good quality cable and connectors?
Have you checked the cable is not shorted or damaged in any way?
Do not introduce kinks of more than 90 degrees
If you live in a weak signal area:
Have you installed a high gain multi-channel aerial?
If you install a good quality cable with good quality connectors and aerial you should have no problems receiving digital TV signals.
Hope this helps
Sep 30, 2014 | Televison & Video
On my 03 accord no power to a/c clutch
The a/c clutch circuit is controlled by the PCM on your Accord. It receives all necessary inputs from the car, and the driver's requests, using odvious buttons, switches, pressure switches, and several engine inputs to determine whether or not to engage the comp. Engine load/accel, temp., ambient temp, etc will all affect this. Also, if all seems normal, I have run into two of this generation Accords that had the control circuit drivers inside the PCM burned out by sloppy a/mrkt alarm system installers. These guys wreak havoc on most newer cars, because they aren't trained to properly isolate/disconnect sensitive electronics that can be damaged easily by shorting wires, or tapping into a circuit that should not be used for this purpose, etc. Good luck! And the security/immobilizer systems in the newer vehicles have NO NEED for additional security add-ons. If someone tries to sell you on them, they are scamming you for money, PERIOD.
Mar 30, 2014 | 2003 Honda Accord
How do i get my car stereo to work even though we have installed it properly?
a) stereo is not installed correctlyorb) stereo is defectiveorc) stereo is not being operated correctlyord) problem in wiring harness
Dec 22, 2011 | Car Audio & Video
Htddw7600, brand new, sub amp is not working, only way to get any bass sound is to unplug the sub cable from back of main amp and touch it on side of sub out port.
H?,
You have a very good system...one of the best of SONY..SUB does not get activated automatically especially on STEREO mode.DIRECT STEREO Notes • No sound will be output from the subwoofer.
.your system has Dedicated Power Amplifier for 2 Externally Driven Sub-Woofers (200W RMS x 2)..in order to activate the sub woofer amplifier you need to make a selection on the surround modes while you are switching the modes of the surround you will see the speaker position on the display of receiver as well..if you do not see the sub woofer it wont be activated..Sound Field Program (A.F.D) is a good example to test it..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Additionally please follow the instruction on your user manual to activate the SUB ,as is follows..
BASS-OUT
Low-frequency (bass) signals can be directed to the
subwoofer and/or the front left and right speakers
according to the characteristics of your system. This
setting also determines the routing of the LFE (low-
frequency effect) signals found in Dolby Digital or DTS
sources.
Choices: SWFR (subwoofer), FRONT, BOTH
• Select SWFR if you connect a subwoofer. LFE and
low-frequency signals from other channels are directed
to the subwoofer according to the speaker settings.
• Select FRONT if you do not use a subwoofer. LFE and
to the front speakers according to the speaker settings
(even if you have previously set the front speakers to
SML).
• Select BOTH if you connect a subwoofer and you want
to output low-frequency signals from front channels to
both the front speakers and subwoofer. LFE and low-
frequency signals from other channels are also directed
to the subwoofer according to the speaker settings. Use
this function to reinforce low-frequency signals using
the subwoofer when playing back sources such as CDs.
Jun 23, 2011 | Audio Players & Recorders
Sigma bc500 sensor will not pick up wheel rotation...just received new unit installed according to directions (which aren't very good, just pic diagram). I have the one sensor on the spoke and it is...
You have to have the magnet on the wheel VERY close to the sensor on the fork leg. Also play around with moving the sensor up and down the fork leg, all the while keeping the magnet VERY close to the sensor.
Dec 26, 2009 | Sigma Bc 906 Computer
Let me be more specific on our problem. We installed the reciever according to directions. The 2 questions are: first, we have Dish Network. Isn't it possible to watch tv with the Yamaha reciever off with...
Look towards the back of the manual. You go into setup. Choose HDMI. Then there is another setting that you have to activate. The receiver must be set to the HDMI input that you want, before the receiver is turned off. I just installed my receiver last night and followed that procedure. Works great.
Oct 11, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
New Badger 5 insinkerator garbage disposal just installed 3/4 hp
I would definitely return this item to the store and get a new one. Not a good sign. good luck
Jan 20, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
New installed W.Bosch Greenstar 30CDi with DT20RF programmer. Have been getting intermittent cut out of heating when in progress as indicated on the programmer display by flashing green heating led and...
one of my customers had the same fault recently. We tryed to reset the radio connection but, the appliance still did not respond.
The receiver was disconnected for the evening to prove boiler and system functionality which was ok.
Next day we installed new receiver & followed set up. customer has had no symptoms for 2 mnths.
Hope this helps.
Oct 17, 2008 | Heating & Cooling
Yamaha RX-V995 no power no audio [dead]
sounds like a short in the cpu of the unit
Mar 02, 2008 | Yamaha RX-V995 Receiver
Sony CDXGT240 Xplod for your Car Car CD MP3 Player Logo
19 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
