Question about Sport & Outdoor - Others
I HAVE A 1997 SEA DOO SPORTSER JET BOAT , HAS NOT BEEN USED MUCH IN THA LAST 3 YEARS, IS CUTTING OFF WHEN RIDING IT, TO THE POINT THAT WILL NOT START ANY MORE, HAS 1/2 TANK OF GASS, BATTERY IS OK, IS CRAKING BUT WILL NOT START ANY MORE, I KNOW THE FUEL IS OLD BUT HAS BEEN MIXED WITH NEW FUEL, THIS JUST HAPPEN YESTERDAY, HAN 2 NEW SPARK PLUGS WHAT IS THE PROBLEM?? TONY
  • tonymtz127 Sep 06, 2010
    I DO NOT HAVE A LOT OF EXPERIENCE WITH THIS ENGINE WHERE EXACTLY DO I SPRAY THE STARTING FLUID?? DO YOU HAVE A DIAGRAM THAT YOU CAN PROVIDE?? , , A COUPLE OF MORE QUESTIONS, WHERE IS THE FUEL FILTER,LOCATED I LOOKED IN THE ENGINE COMPARTMENT AND I CAN NOT FIND IT , NOW ON THIS TYPE OF ENGINE IS IT NECESARY TO CLEAN INJECTORS OR CARBURETOR?? . , OR IS THERE ANY OTHER TYPE OF MAINTENANCE NEEDED TO KEEP IT RUNNING PROPERLY??
  • tonymtz127 Sep 07, 2010
    I AM NOT SURE IF MY QUESTIONS WENT BACK TO YOU. WHERE IS THE FUEL FILTER LOCATED?? I ON THE FUEL SYSTEM IS THER E ANYTHING ELSE THAT HAS TO BE FLUSHED OR CLEANED??
    President:
  • 2,050 Answers
Gas that sits that long will clog up jets in the carburators. The best thing to do now is completely remove all of the gas in the tank and fuel lines and remove the carbs and get them thoroughly cleaned. This means taking out all removable jets, floats, and needles and making sure all passageways are clear. Make sure the carb clean is done carefully, so you don't have to repeat it.
Fuel stabilizer will help in the future, but it's usually good for one year.
Good Luck!
Posted on Sep 07, 2010
  • 2,299 Answers
If you spray a small amount of starting fluid in the air filter, does it start? If it starts then I would say that the old fuel is the problem. Or maybe plugged up the fuel filter.
Posted on Sep 06, 2010
  • Rodney Clark
    Rodney Clark Sep 07, 2010
    I am not real familiar with the engine either. There is a rubber tube on top of the engine that goes to a small box. The box will have small clips on it to open it. Or some have large screws. It will be a rectangular box. That is where you want to spray the starting fluid. Don't spray a bunch. Won't take much. As far as the fuel filter goes. Find the fuel tank and it should have two lines coming from it. Follow the lines. They will go to the engine. Somewhere in those lines there will be a filter. As far as maintenance goes. You need to change the spark plugs once a year. And you can run injector cleaner in the fuel once a year also.
2003gti Sea-Doo will start and stay running but that all
Hey Rob,
Has this machine been sitting up? It won't rev up? ... If so, the carbs have probably become clogged/blocked due to the great gas we have now -evaporating inside the carbs,, it leaves deposits that clog the jets/valve and passages. Get a professional to clean and set them, put in a new set of spark plugs.. you should be running great!!
Jun 11, 2017 | Boating
Sea doo won t start
take it back to dealer ss warranty !!
Jul 27, 2014 | Sea-Doo US 2013 RXT -X aS 260
What do I need to do after 10 years of storage.To put a 1992 Sea Doo in water?
Change fluids, Check hull for bouyancy flaws, replace plugs, clean carbs or rebuild them. Most old engines get gummed up after long term storage if the fuel was not completely drained. Another possibility is that the bearings may be damaged from years of condensation and and drying. It happens sometimes and sometimes you just get lucky. Had a ducati paso 750 that blew the race on the bearings because they were deteriorated after years of storage in climate controlled space. Was fine then one day the bearings came apart in the engine and chewed it up.
Jul 18, 2014 | WSM 1992-1996 Sea Doo Gts 580cc Jet Ski...
How do I remove an impellar from a 2002 sea doo GTI LE ?
You need to have the Impeller removal tool. I found one on ebay at the following link: http://www.ebay.com/itm/SeaDoo-Kawasaki-PWC-Jet-Boat-Jet-Pump-Repair-Impeller-Removal-Wrench-Tool-/390828336861
I found a great start to finish rebuild of your impeller on you-tube. Its a 5 part video. Click the link I provided and scroll down to the impeller videos. http://www.youtube.com/channel/UC8ecHS-HG-eQpel1r-DZnuw
Here is a link for schematic and parts list of your jet pump: http://www.seadoopartshouse.com/oemparts/a/sea/500d79f2f8700209082580e0/propulsion-system
If you are replacing the impeller, here is a page of what.. IF anything you can do as far as performance improvements: http://www.pwctoday.com/showthread.php?t=309226
The stock specs for your impeller are dual pitch 9 / 20 and 155mm diameter.
Jul 14, 2014 | Sport & Outdoor - Others
96 seaboo will not go full speed in water, but full rpm out of water
carbs need cleaning and check the pulse jet that squirts fuel on set off , fuel pump diaphrams ok ?
Sep 08, 2013 | Sea-Doo US Seadoo sea doo cdi ignition...
Jet ski
too rich, adjust thehigh idle screw
Jul 06, 2008 | 1997 Chevrolet Cavalier
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
