Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Recording Issues In Vista
Heya..Im pretty new to vista and tbh im about to throw this laptop out the window.. for my uni course i have to record my guitar..i need to hear it at the same time,,In XP pro my set up worked..
In vista i cant hear any thing in play back..i have tried the hiden device's in the sound devices..none showed...seached the system reg..nothing..
i have checked all the volume controls in speaker/mic playback etc..
i have nothing else to fink of...
the driver for audio is : Conexant HD Audio.. version - 4.36.7.60 (04/03/2008)
so the drivers are the latest..
System Basic Details..
HP G6000XX Laptop.
Vista Home (no service pack installed)
AMD Athlon 64 X2 Mobile TK57
2 Gb Memory..
any help would be amazing..
i have searched everywhere..
or is the only answer to wipe all an install XP Pro..its that serious.
  • 5 more comments
  • josh_gib May 13, 2008
    I normaly use the Emulated headphones out output on the guitar amp straight into the mic port using an mini jack cable..
    audacity i use to record then import the guitar tracks to Reason 3.0..
    I have used the same system for the past 5 years with no problem and amazing sound..
    well the output on the amp can be either..with a switch at the back..yes this is a new laptop..and it came with Vista pre-installed. I have done a few tests and it will record the sound..but the levels are all over the place and you cant hear wot you are doin...also i noticed its out of sync..the laptop only has a mic input and headphones...this has never been a problem before, even in my old comp.
    There is only the software to change any settings is the standard vista settings..theres no other software.
    full spec as follows:
    Operating System: Windows Vista™ Home Premium (6.0, Build 6000) (6000.vista_gdr.070627-1500)
    System Manufacturer: Hewlett-Packard
    System Model: HP G6000 Notebook PC
    BIOS: PhoenixBIOS 4.0 Release 6.1
    Processor: AMD Athlon(tm) 64 X2 Dual-Core Processor TK-57 (2 CPUs), ~1.9GHz
    Memory: 1918MB RAM
    Page File: 704MB used, 3356MB available
    DirectX Version: DirectX 10
    Sound Devices
    Description: Speakers (Conexant High Definition SmartAudio 221)
    Default Sound Playback: Yes
    Default Voice Playback: Yes
    Hardware ID: HDAUDIO\FUNC_01&VEN_14F1&DEV_5051&SUBSYS_103C30EA&REV_1000
    Manufacturer ID: 1
    Product ID: 100
    Type: WDM
    Driver Name: CHDRT32.sys
    Driver Version: 4.36.0007.0000 (English)
    Driver Attributes: Final Retail
    WHQL Logo'd: n/a
    Date and Size: 3/4/2008 02:32:00, 188416 bytes
    Other Files:
    Driver Provider: Conexant
    HW Accel Level: Basic
    Cap Flags: 0x0
    Min/Max Sample Rate: 0, 0
    Static/Strm HW Mix Bufs: 0, 0
    Static/Strm HW 3D Bufs: 0, 0
    HW Memory: 0
    Voice Management: No
    EAX(tm) 2.0 Listen/Src: No, No
    I3DL2(tm) Listen/Src: No, No
    Sensaura(tm) ZoomFX(tm): No
    Sound Capture Devices
    Description: Microphone (Conexant High Definition SmartAudio 221)
    Default Sound Capture: Yes
    Default Voice Capture: Yes
    Cap Flags: 0x0
    Format Flags: 0x0
  • josh_gib May 27, 2008
    In playback tab there is only the level for the mic..which makes no difference full or not..u cannot hear back at the same time its plugged in...
    anyone? im really really really annoyed about this..every forum everywhere i do its a dead end...there must be someone?
    please? x
  • Anonymous Mar 10, 2009
    Same problem..I have went through everything. There is absolutely no option for a mic/line in volume control. I can record..just cant hear it.
  • RaisAhmed Apr 28, 2009
    I have the same problem with HP G-60. That internal Microphone (a little hole next to webcam) does not seem to work. I have tried everything posted on this forum and as well on HP forum but so far no luck.... if any one has the solution plz do post it.
    Thanks
    Raees
  • Niels Boehme May 11, 2010
    In vista, if you right click the speaker icon in the system tray, then select recording devices, you each device. You can select it and hit properties. Then check the level.
    Why do you use the mic input instead of line in? The mic input is usually a mono input, and the ring might be a bias for the mic. The line in is a stereo input. Is the headphone output on your guitar amp mono? Unfortunately, I am not familiar with your audio hardware and the software.
    Perhaps a simple test with the sound recorder would verify the laptop is ok. Was your setup in XP Pro on a different computer, and this laptop is new?
    How are you attempting to record the sound?
    Which software, Sound Recorder for Accessories?
    Which input are you using, line in?
    P.S. I don't recommend wiping Vista until you make sure they have all the drivers for XP. I tried that on a G9xxx and had no audio, video and specialty drivers. Ended up ordering the restore dvd because I didn't backup the drive.
    Scholar:
  • 67 Answers
Microsoft moved the particular option that you need to enable since Windows XP, and have also changed its default to MUTE.
To hear what is playing through MIC IN...
  • Go to Control Panel and select "Sound"
  • Under the "Playback" tab, double click on your enabled speakers.
  • Select the "levels" tab, and look for "Mic In Volume".
  • Click once on the speaker icon that is muted to un-mute it.
I really hope that this has solved your problem, if it has not, please let me know and I will do my best to help you further. Good Luck!
Posted on May 15, 2008
These problems are NOT solved by unchecking a mute button, they do not have the option! only options for them are volume for mic and speakers. they are alot of people with the same problem, does anyone else have a positive solution rather than "unclicking mute"?
Posted on Sep 17, 2008
Same here, heard about regedit tweaks but havent found for this soundcard :(
Posted on Aug 30, 2008
That is what I don't have "Mic In Volume" under Playback/levels
Posted on Aug 26, 2008
I have also bought a G6000 HP with vista... on my previous laptop i could play music via soundcard by changin settings on steroe mixer... yet on this machine it doesnt seem to be there..
After following instructions on other sites i tried going to sound properties and right clicking and selecting to show diasabled devices... problem is once i choose this im still not getting any other options...
is there a download or anythin i can use to enable to stereo mixer??
Posted on Sep 16, 2008
I have logitech cam MN:V-UAM27A the software wont work for recording video , im using windows vista
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Jan 05, 2013 | Computers & Internet
I am using samson c03u to record songs using magix music maker, never had problems with it until i fell pregnant and gave birth so i stopped using it for a while. now that im back to record songs again, i...
When recording turn off things like antivirus as they hog massive amount of CPU time. Also turn off wireless links and any other background tasks that will cause audio overruns. Alsoverify you do NOT have inout echo turned on. This would cause feedback that might sound like reverberation.
Jul 15, 2012 | Samson C03U Professional Microphone
Trying To Hear Audio Through Headphones While Recording.
There are a lot of people having the same problem with Vista. Check this link for some ideas. I think there is a new on Microsoft update that addresses this issue under audio drivers that gives you more controls in the playback devices tab. Here is the first link:http://forums.techarena.in/vista-hardware-devices/865259.htm Here is another:http://social.answers.microsoft.com/Forums/en-US/vistamedia/thread/217c4402-6668-4592-bd5e-9234247c788f and finally the one that was easiest to understand:http://www.roemersoftware.com/vista-recording-problem.html My son has the same problem with his Compaq laptop and I am truly glad I stuck with XP. Please let me know how you make out.
Nov 30, 2009 | Audio Players & Recorders
Dell inspiron 6400 Soundcard Microphone
sorry for the delay in responding:
for Vista system ... use the following picks:
Start ....Control Panel,...... Hardware and Sound, .... Manage audio devices....Recording......Line in ...try the advanced features to control the computers auto adjustment etc.
Hope this helps
Apr 05, 2009 | Dell Inspiron 6400 Notebook
Compaq Presario Vista Line In Recording Distortion
I was having similiar issues with my Vista system, upgrading the audio driver resolved the issue for me.
Feb 03, 2009 | Compaq Presario Notebook
Distortion In Recording On Windows Vista
check your buffer speeds. take them from the highest and lowest on sample rates. make sure your ram fits the bill.
Jan 30, 2009 | Tascam FW-1884 Firewire Audio / Midi...
I cant get any sound to go into my interface or come out, and when we are pl im running windows vista with calkwalk recording softwear
The only support I found for your brand product is via e-mail.Sorry You need to reinstall the audio device ferom the install CD or get it again from the company.
http://www.lambda-gb.com/public/productsupport.aspx
Jan 23, 2009 | Lexicon Lambda Usb Desktop Recording...
Volume control on windows mixer
have you check which input the system is selected for recording it mite be site for the mic not the line in
check this in xp by going to the mixer
click options
click properties
check the box recording
now it should show the recording sliders (check marke the mark the following boxs to see the sliders)
Line in press ok
Put a check in the Linein slider and make sure it selected and turn erup
i also use wave labs and forge and quick basic test if you can record from the mic then its selected as the input
make sure other inputs are down as you will also get feedback from the builtin mic
Oct 08, 2008 | Computers & Internet
Not responding
you might want to downgrade to xp because vista uses alot of ram to run it. you could also get more ram. you need about 1gb and a half to 2 gigs to run most recording softwares and interfaces. i personally use vista cause i lost my xp disk and i got 2 gbs of ram and everything runs great, but if you really want to get into recording do what im doing and save up and buy a mac.
sincerely
andy kastrinelis
owner of addex recording inc.
Oct 13, 2007 | Tascam US-144 Sound Card
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
1,066 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
