Question about Magellan RoadMate 1440 Car GPS Receiver
Magellan 1440 Roadmate only shows screen showing me to connect it to a computer but when i do that it doesnt change anything. It just keeps showing that screen and i cant do anything else on it? Is there a way to fix it?
  • 1111 Answers
SOURCE: hi,
if you havent updated it yet, you can go here for the update for your model..just look up your model on the right side and download your update (you must register on magellangps.com to be able to download)
Posted on Jul 08, 2009
  • 4090 Answers
SOURCE: magellan roadmate 1430 no sat signal
replace the or recharge the battery to capacity and see if that helps usually low battery, incorrecty baud rate or port out cause no satellite connection, unless you are under a thick concrete or tin roof. take it outside and show it some sky and see if that help
Posted on Jul 26, 2009
  • 5 Answers
SOURCE: my magellan roadmate 1440 will not turn on? Is
get a new one.. no way to fix unless u get a new battery
Posted on Dec 18, 2009
  • 184 Answers
SOURCE: reset button for a magellan
Hi allen,
Magellan RoadMate models 1340, 1440, and 1470 are normally reset as follows:
The reset button is located on the right side of the unit. Press a blunt object like a long-shaft ballpoint pen or a cut off toothpick
into the small hole and hold for approximately 15 seconds. The unit should do a fresh reboot. Sometimes these GPS units can be reset by holding the Power button down for 10-15 seconds to completely shut the unit down. Then, do the same procedure for 10-15 seconds again, to power it back on.
Also, here's another procedure you really only try as a last resort, if the unit is on, but acting up with various menus and functions. Use this very carefully...
While on the main Menu Bar at "System Settings", tap the left corner twice, right corner twice, left corner once, and finally, right corner once. You will see a 'Hidden' menu with a "Reset for first use". Press that option and the unit will perform a hard reset. Hopefully, you can continue all you setups from this point.
Also you can download a complete manual from this link:
http://www.magellangps.com/assets/manuals/Magellan_RoadMate_1440_EN.pdf
The manual won't tell you all these little tricks, so it might be a good idea to make a hard copy of these notes (in case you ever need them again...lol). I hope this helps. Please let me know how it turns out, and contact me if you need further help.
Regards, Bill
Posted on Sep 17, 2010
  • 184 Answers
SOURCE: Magellan Roadmate 1440 certainly dead
Hi onestrategy,
These are tips I have used and given others about this series Magellan units. Make sure you have external power hooked up for best results.
Regards, Bill
My magellan roadmate 3030 LM is stuck on usb conect to computer screen. will not do anything
You will need to send the unit in for repair. There is nothing you can do at home to repair this problem.
Aug 29, 2012 | Magellan GPS
Magellan RoadMate 1440 files
sorry but you have requested from the wrong web site
Jun 26, 2012 | Magellan RoadMate 1440 Car GPS Receiver
Magellan roadmate 1440 froze in the first window , with the little clock at the bottom
Most of these devices have a reset button on the unit base. It looks no bigger than a pin head and is usually recessed.
Turn on and take a straightened paper clip or cocktail stick, press into and keep pressed the reset button for a slow count to 15. Release and then let the unit go through its reset procedure before pressing anything else.
Apr 10, 2012 | Magellan RoadMate 1440 Car GPS Receiver
I have the Magellan 1440, all I get is where it
  1. Get a clear view of the sky and then turn off the unit and then power on again.
  2. Once the unit is on and you see the street display tap on the signal icon on the screen.
  3. You will see a half globe with horizontal signal color orange and wait for at least 5 full green signal and then close that page.
  4. Once your in the sreet display you will see tsignal strength on the screen.
Feb 12, 2010 | Magellan RoadMate 1440 Car GPS Receiver
My magellan roadmate 1440 will not turn on? Is
Dec 18, 2009 | Magellan RoadMate 1440 Car GPS Receiver
Cannot operate it
I spent 10 seconds doing a google search. http://www.magellangps.com/assets/manuals/Magellan_RoadMate_1440_EN.pdf
Aug 08, 2009 | Magellan RoadMate 1440 Car GPS Receiver
How do i change the language to spanish on my magellan roadmate 1200?
Maggie
Now, based on what you told me I understand that:
· You want feature information.
· You want to know how to change the system language
Maggie
RoadMate 1210, 1220, 1340, 1440, 1470
  1. From the main menu screen select the Settings icon (has a wrench and a screwdriver in an X formation)
  2. Select the option labeled "Sistema"(Spanish)/"Systeme"(French)
  3. Select the optino labeled "Lenguajes"Spanish)/"Langues"(French)
  4. Select your preferred language setting
  5. Confirm your selection by selecting the Back Arrow on the bottom left hand corner of the screen
  6. Unit will restart to make the language change
Jul 13, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Magellan roadmate 3000t
I have the same issue. The device just powers up and shows the Magellan logo and does not continue past that.
Dec 14, 2007 | Magellan RoadMate 3000T GPS Receiver
Magellan RoadMate 1440 Car GPS Receiver Logo
124 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
