Question about Garmin GPS
When I turn on my garmin fishfinder 240 I get 2 beeps and then 5 beeps and nothing shows on the screen. The unit has only approx. 26 hrs of use over 2.5 years. I received it for Christmas then did not use it for 9 months put it back in the box the way it came and did not use it for 2 yrs, The second day of use after approx. 3.5 hs the day before it came on and then the screen went blank. Thank you for the help. All I get from garmin is send us 150.00 dollars and the unit and we will look at it. Thomas P. Pinten Slidell La.
  • 10,865 Answers
Hello Thomas. Let's begin by resetting it to factory settings. To do this, turn it on and then gently pry off the thin frame around the screen with your your finger nail. Under that thin frame you will find a reset button. Push it and then try to start it up. It should work. If not, there is no more you can do at home. For 150., I recommend replacement as opposed to repair since your maps are also 2.5 yrs. old. J.
Posted on Sep 06, 2010
Garmin striker 7 sv manual needed
STRIKER™ 7sv ' Garmin
https://buy.garmin.com/en-CA/CA/p/528825
  1. Cached
7-inch CHIRP Fishfinder with ClearV?/SideV? Scanning Sonar. ... Finding fish is easier than ever with STRIKER 7sv fishfinder. ... STRIKER 7sv includes a Garmin high wide CHIRP transducer, which provides a visibly higher level of clarity and detail for fish and structure than traditional ...
Manuals for Striker 7sv, US w/o xdcr - Garmin Support
support.garmin.com/support/manuals/manuals.htm?partNo=010-01554-00...
  1. Cached
Manuals for Striker 7sv, US w/o xdcr. Manual Name, Revision, Revision Date, Part Number, Action. Installation Instructions, B, Mar 2016, 190-01950-92 ...
[PDF]STRIKER™ Series - Garmin
static.garmin.com/pumac/STRIKER_OM_EN.pdf
  1. Similar
Adding a New Layout to the Home Screen of the STRIKER 5 or 7. ..... have all of the options and features discussed in this manual. ... STRIKER 5 or 7. You can ...
garmin striker 7 sv manual Google Search
Apr 07, 2017 | Garmin Cameras
Wont power up, i replaced the power cable with a new one and still nothing, dose the transducer need to be connected for it to power on ?
The PWR button also adjust the backlight of unit. Press and quickly release to cycle through brightness settings. All else fails call Garmin www.garmin.com/support
Mar 25, 2016 | Garmin Echo 100 Fishfinder
No transducer
Make sure the plug that gives this unit power is secure. Also I think this device has a 2ft branch that goes to the ducer. Make sure that's right too
Apr 10, 2014 | Garmin FishFinder 240 with Transom Mount...
Unit shuts off at high speed,too high voltage? what can i do? Its ok at low speed.
try putting a regulator on your charging kit. it is probally putting out too many volts.
Apr 18, 2010 | Garmin FishFinder 240 GPS Receiver
Eagle Fisheasy No screen display and only beeps
You could have blown the transducer.....it is supposed to be in water before you turn it on. A 5 gal. bucket inside the boat would be fine for when out the water. Put the transducer in the 5gal bucket with water and try again. You may have to get another. sorry.
Dec 20, 2009 | Eagle Fisheasy 250ds Fishfinder
GPS operation freeze up
Upgrading the system software of your GPSMAP 545s will most likely fix your freezing up problem.
I hope that helps.
May 31, 2009 | Garmin GPSMAP 545s GPS Receiver
Navman 4500 FishFinder
Was there ever a solution to the Fishfinder 4500 going blank but still powered on????
Jul 19, 2008 | GPS
Help
i have the same model same problem. i rehooked it up and now when i slide the base onto the reciever it beeps once then 3 times and i press the power button and nothing happens.. did you ever get help ????????
Jul 01, 2008 | Humminbird 343c Fishfinder GPS Receiver
GPS Logo
65 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
