Question about Canon PIXMA MX320 Color USB InkJet Printer
Mi impresora canon mx 320 no quiere escannear
Mi impresora canon mx 320 no quiere escannear pero si saca copias y imprime bien q podra ser ¿?¿
    Top Expert:
  • Canon Master
  • 14,161 Answers
Posted on Jun 14, 2015
4 Suggested Answers
  • 295 Answers
SOURCE: mi impresora kodak sale error 6202 y en la pantalla sale error
,Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
Posted on Jan 01, 2010
domotek
  • 591 Answers
SOURCE: mi impresora es una canon mx 300 multifuncional
Pardone jo ablo frencais o anglais y un pecito espangol, but what I undrestand is that the printer make a noise when printing??? if that is the case, you should look for debri stuck in the mechanisme (peace of paper) it could also be a worne sway plate gear
hasta la proxima amigo!
Posted on Mar 10, 2011
SOURCE: Tengo una impresora cannon mx
tengo canon mx320 y no imprime correctamente si es una linea recta sale torcida las letras tambien que puedo hacer
Posted on Sep 05, 2012
Que es la t c
There is no problem if the printer is still printing . The cartridges have a special chip which is special to the printer and only the manufacturer can put a new one in. It knows how much ink is in the cartridge and will inform you when it is empty. When you refill it, however, and do not replace the chip, the printer may still print normally but will give a message that the ink cartridge is empty. Just use it until the printing is bad and refill it again.
Mar 17, 2014 | Canon PIXMA Office Equipment & Supplies
Tengo una impresora cannon mx 320 La impresora no imprime y me da el siguiente aviso en pantalla; ERROR DE IMPRESORA 5200
Feb 22, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Imprime las facturas pero no los albaranes
Esto parece ser un problema de software mas que de la impresora. Si el documento a imprimir contiene graficos (Codigo de barras u otros), es posible que no tenga la configuracion correcta. Recomiendo proporcionar mas informacion al respecto (Que programa usa, tiene el manual de la impresora? Trabaja en Windows o msdos, etc)
Nov 23, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Funciona CUANDO Quiere solitario Pero en cd en un dvd empieza dar vueltas Pero No Se lee
Yo he tratado de hacer de la siguiente manera; lentes deben limpiarse con un disco especial de limpieza. Si no funciona bien, un poco mojada con saliva en la lectura de disco y el lugar del reproductor de discos. la saliva, pero debe ser limpiado.
para m?, funcion? bien durante mucho tiempo. pero luego tuvo que cambiar el reproductor de discos.
probar esto, pero es una recomendaci?n a la historia.
¡Buena suerte
Nov 23, 2010 | Computers & Internet
TENGO UNA COPIADORA XEROX 1012, CUANDO TRATO DE SACAR UNA COPIA TARDA EN CALENTARSE Y NO HACE LA IMPRESION Y ASI UNA SEGUNDA OCACION, HASTA LA TERCERA VEZ QUE TRATO DE SACAR LA COPIA SALE, CUANDO INTENTO...
Esta maquina es viejo, pero si la quiere usar, buenos.
Hay algunos alambres en centro de abajo, limpa los. Tiene cuidado porque los alambres se cebran faci.
Otra cosa es la tinta. La tinta tiene una cosa que media la tinta en el roldono palo. Si esta cabado, no va poner tinta muy bien. Se puede acer copias malas.
Otra cosa tambien es si el papel se tora.
Las jantas pueden ser mal. O otra cosa es si la maquina esta cebrara. Cuando abre la machina, mira adetro donde los dos partes se pegan. Si estran cebranan, el cloche en la atras puede pegra la ariba del metale de ariba de la machina. Usa unas pinsa a planar el metala de el clotche.
Buen suerte! Ojala que entiende esta mensaje.
Aug 12, 2010 | Xerox FaxCentre 1012 Plain Paper Laser
ERROR DE IMPRESORA , TEMPERATURA FUSOR
que debo hacer ya es la segunda vez que sucede
Jul 24, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Mi impresora kiocera fs-720 esta bloqueada.. se queda encendido el bombillo rojo y no imprime...
Es posible que tenga papel atrapado, Cuidadosamente mire si ve algun objeto esta obstruyendo los rieles del papel. Le aconsejo que si puedes compres una lata de aire comprimido y le dispares aire en tu maquina para ayudar a desbloquear cualquierr objeto en el sistema. Asegurase que la impresora este desconectada. Puede ser que necesite introducir la impresora otra vez a tu computadora.
Jun 30, 2010 | Office Equipment & Supplies
Mi 95 civic se ahoga en gas y no quiere prender
revisa si las bujias estan tirando la chispa con un "spark tester" o quita una bujia y dejala conectada al alambre, luego pon a alguien mas a qe le de marcha sin prender el carro mientras tu ponle atencion a la bujia, fijate si tira chispa haz lo mismo de una por una(solo de una a la vez, saca una y regresala cuando ya revisaste si tira la chispa) si ninguna tira chispa entonses es tu distribuidor, te recomiendo el "spark tester" por que ba entre el alambre y la bujia y si la bujia no sirve en la bujia no bas a tener chispa pero en el "Spark tester" si. si si es el distribuidor revisa la cubierta y la pastilla pero a ese punto es mejor cambiar todo el distribuidor. espero que esto te ayude. o y recuerda lo principal para que ensienda Gas, Aire y chispa revisa esos tres si todos estan vien va ha prender.
Dec 24, 2009 | 1995 Honda Civic
NEED DRIVER EPSON LX-300 FOR WINDOWS VISTA
ayundenme porfavor nesesito el driver para una epson lx 300 pero para windows 7, el en SO solo encuentro el driver para epson lx 300+ II y no imprime correctamente por favor ayudenme
mi correo es jdiego.mdz@gmail.com
Mar 03, 2009 | Epson LX-300 Matrix Printer
Como configuro la copiadora impresora canon ir 1023
tiene que ser una 1023 con habilidad para imprimir. aunque no lo creas no todas las 1023 imprimen. si la tuya si imprime no debes tener mayor problema al conectarla via usb debe detectarla windows y se instala como una impresora cualquiera. ojo, el hecho que tenga puerto usb no quiere decir que sea impresora.
Sep 10, 2008 | Office Equipment & Supplies
Canon PIXMA MX320 Color USB InkJet Printer Logo
113 people viewed this question
old marine
old marine
