Question about Fisher and Paykel GWL11 Top Load Washer
Hi fuse has blown on wash machine but plug looks completly sealed.can you help please
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Are you talking about the fuse in the motor controller?Is your model the US model and has a fuse in the plug?If it is the fused plug type did you test for power at the control module and found the fuse on the plug was blown.Please reply with additional information and I can help you rectify this fault.Looking forward to your reply.
Posted on Sep 07, 2010
My ewf1073 stopped suddenly while washing halfway. The cld is blank too. Check fuse and it is ok. Please help.
check whether the machine wall plug fuse and the house fusebox has blown/tripped
Jun 08, 2015 | Washing Machines
Simpson espirit 750 won't turn on
Hi, This may sound obvious, but have you checked the fuse? if the machine is completly dead this may be the problem or the ON/OFF switch is faulty. If there is life in the machine the problem could be the door switch. If the fuse has blown then there could be a fault such as heater element blown, is the most common to blow a fuse.
May 04, 2012 | Simpson Esprit 750 Top Load 7.5kg
Ariston a1600wd wont turn on
Before you change fuses, do you have an internal fuse board or RCD system in your home? Sometimes, an individual RCD can trip out, locking off sockets. Some sockets are individually set up for up and downstairs in a house, or different rooms. If you have a board or RCDs, check them out :)
Nov 18, 2017 | Ariston Technologies Washing Machines
Loaded machine and it has stopped half way(?) through the wash cycle. ~ Found fuse blown in plug. New fuse, washer started turned maybe once amde a few unusual clicks and stopped - fuse has blown...
From your description it could be the main motor but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could also be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as suspects. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 04, 2011 | Washing Machines
Had a thunderstorm last night. The Fisher Paykel washer won't come on at all, even after unplugging as in the manual. Is there a fuse that could have blown ?
Hi Bruce.Just read your posting.Yes your machine has a control fuse in the main control module.I need to know the model number of the machine to guide you in how to replace it if it is blown.The model number is on a sticker that is located at the back of the machine up top.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Washing Machines
Power light is off. won't turn on.my washing machine completed a load of washing then i put another load in and it won't do nothing
hello you would have checked the fuse in the plug if ok then check the glass fuse inside the washers power supply if it's blown the make sure you use the same rated fuse. beware if it blows again then you have a dead short hope it helps
regards
shaun
Jan 23, 2011 | Washing Machines
I also have an NEC NW-452 Washing Machine,it has stopped working completely,doesn't power-up at all,the User Manual troubleshooting guide is no help at all,I tested it it with a Digital Multimeter to see...
take the top off and follow the mains cable to where the cable is connected in the terminal block it could have come loose or the cable itself is at fault check the wire from the plug terminals to the terminal block eric
Dec 27, 2017 | Washing Machines
Washer won't turn on, do I need a new door switch?
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 27, 2010 | Washing Machines
Washing machine wont spin
Your machine may not be receiving adequate voltage to start. Make sure your machine is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your machine. Also, refrain from using an extension cord to plug your machine in.
Dec 03, 2008 | Indesit W 123 Front Load Washer
Hotpoint WD51 fuse issue
is it the motor that got hot?, if so then check the motor carbons for wear, as these heat up when worn, also if the carbons are fine check the pump and filters for blockages, this makes the motor spin while water is still in the machine causing the motor to overheat, and subsequently tripping and blowing the fuses etc hope i have helped a little
Sep 25, 2007 | Hotpoint WD52 Front Load Washer / Dryer
Fisher and Paykel GWL11 Top Load Washer Logo
136 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
