Question about Kenmore Dryers
Dryer starts with the burner coming on then its wont fire again durning the rest of the cycle
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
I have a Kenmore Elite older model dryer that will fire the burner up when started, but when the burner shuts down and then tries to cycle on again, the glow igniter starts but no gas is released and the...
most likely its gonna be your coil kit, but it could also be ur gas valve,but the gas valve is not common. I would go with the silinoid coil kit first, its much cheaper too
Oct 11, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
We have an LGR8648 gas dryer. When you start the dryer, it heats up just fine. At some point (after 15-20 minutes, it seems) the burner goes out and never comes back on. Is there a thermal sensor or...
The most common cause for your problem is the gas valve coils. There are 2 and should be replaced in pairs. Over time, they will fire when you first start the dryer but fail to fire again once in mid cycle. A link for a typical set of coils is listed below:
Whirlpool Gas Valve Coil Set of 2
Jul 24, 2011 | Whirlpool LGR8648 Gas Dryer
Gas Dryer only runs burner once after starting, why
Lets see, you have power to the gas assembly so the fuse is good and the ignitor will fire up. But she won't fire off again. The flame sensor is working because the ignitor is coming on and off. That means the control thermostat is working so everything is working. So what's the problem. Simple.933a1bb.jpg The solenoid coils heat up and quit on these machines with a little age. Very difficult to diagnose unless you know the trick.
Cheap parts link, your part sir: AP3094251,
May 14, 2010 | Maytag MDG2706A Gas Dryer
When I start my dryer, I have heat at first, but it shuts off after a short time for the rest if the cycle.
It sounds like you have a gas dryer . The coils on the burner valve need to be replaced . They get hot from the electricity going thru them , and one opens (shorts ) until the dryer cools down . It should then heat again for a few minuted , then stop heating but still run . Your timer will not advance either , if set on auto , unless dryer heats . Without the model number , cannot give you the part number , so take it with you to get the part . It comes with both coils in a pkg .
Oct 11, 2009 | Whirlpool Dryers
No heat in Dryer
Hi, this Maytag dryer has a set of malfunctioning coils that will need to be replaced. This coil assembly is located on the actual burner assembly.
Please rate and god bless:)
Apr 14, 2009 | Maytag Dryers
Dryer heating problems
If this is a gas dryer, this is commonly caused by bad gas valve solenoids. Please post back with your make and model so I can verify your configuration and assist you further.
Jan 25, 2009 | Dryers
Dryer will ignite and get hot briefly then go cold
More likely problem is your gas valve coils are bad. Very common problem. As you described, burner will fire up initially and then will no fire again the rest of the cycle. Testing the coils with a meter will not help you here. The wire inside them is as thin as a human hair and they will check"good" with a meter.
FWIW, that radiant sensor rarely fails.
Dec 13, 2008 | Dryers
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryers Logo
49 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
