Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
How do I replace the starter rope on the Troy-Bilt TB415CS trimmer
  • 2,382 Answers
Hi, you must first remove the shaft assembly by removing the Torx/Flathead screws that hold on the trigger. Then you remove 3 screws that hold the engine to the shaft. Next you can remove the shaft assembly and you will see 4 or so screws holding the black surround around the clutch. You need to remove this to get to the pullstarter. Once you get to the pullstarter make sure not to release the coiled spring or you'll have a hell of a time putting it back in. Typically that are behind the pullstarter assembly.
Posted on Sep 06, 2010
Starter rope is loose on lawn edger
remove the recoil housing and wrap the chord round the spool more to take up the slack
Feb 11, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Motor starts and runs fine but trimmer heads only spins slowly
replace the centrifugal clutch at the motor end of the unit shaft
Jul 18, 2015 | Troy-Bilt Troybilt Mtd String Trimmer...
When pulling rope it clicks
This is a problem with either the starter pulley ( rope pulley) if the corners are worn it will not engage with the pawls, or the pawl/pawls them selves have worn
Jun 19, 2012 | Troy-Bilt 29cc 4-Cycle Curved-Shaft Gas...
Replacing starter recoil rope on troy bilt 4-cycle cultivator
Either contact the company or Google the model number for a service manual.
Jun 14, 2012 | Garden
Replace starter rope on a tb70ss troy bilt trimmer. everything is off but the red plastic casing
you will need to flip the casing upside down and wind the pulley counter clockwise, it should be pressure on the pulley if not then it is clockwise, once you have wound it six or seven times, you will need to feed the pull rope from the outside in, there is a hole on the pulley where the rope comes through, while keeping the tension on the pulley, once the rope is through you will need to knot the end and burn the end of the knot, let go of the pulley it will wind the rope, pull on the rope a few times to make sure the knot is holding, then reassembly the unit. Hope this helps Tim
May 07, 2011 | Troy Bilt Tb70ss Gas Trimmer
How do I fix/replace the starter rope on a TB20CS (Tuffy Troy Bilt String Trimmer) that's broken? Do I need any special tools?
Probably no special tools needed. Take the starter assy off. Turn the recoil in the direction it will turn if you are pulling the rope. When it gets tight, hold it there and install the new rope. When it is installed, let go of the recoil and it will draw the rope in.
http://www.mylawnmowerforum.com/forum/
Aug 09, 2010 | Troy Garden
Tb415cs,not getting spark? Cleaned the plug and filter, new gas & oil.
it may just be the switch playing up on you give it a good swilling with WD40 if that dont work look at the spark plug coile
Oct 30, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy bilt string trimmer starter rope
you need to rotate the starter pulley up first to tension the spring.... then feed in your rope tie a not and let it retract the rope into the starter pulley
Aug 06, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
1,174 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
