Question about Whirlpool WTW6400SW Cabrio Washer
Getting message LF.. what dose that mean - Whirlpool WTW6400SW Cabrio Washer
    Brigadier General:
  • 8,619 Answers
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
What dose lf mean on the washer
Do you mean dosage? That is the amount of detergent to use for the amount of clothes in the load and how dirty they are.
Nov 06, 2014 | Washing Machines
Blue screen & A message pop-up on my ToshibaSatellite A105-S4011:
try removing some unwanted programs. run disk cleanup, then defrag
Apr 04, 2010 | Toshiba Satellite A105-S4011 Notebook
Calypso Washer is not washing clothes or spinning; getting LF error message. Water is going into the machine but no washing action.
Hi There
I'm Sending you the fault codes. Hope this helps you and get you in the right direction.
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display. Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
WHAT IS THE PROBLEM WHEN YOU GET THE LF ON THE
LF Long Fill
Oct 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
I have a maytag bravos and i keep getting LF WHAT Dose that mean
(Washer is taking too long to fill)
Check the following:
Are the hot and cold faucets turned on?
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press POWER/CANCEL to clear display.
Hope this helps.........................
Oct 03, 2009 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos top load gives LF code..not working ... any idea?
Have same problem. Service tech said LF code is caused by low water pressure coming into machine. Tech verified water flow looked fine, getting new controller installed tomorrow.
Jul 18, 2009 | Maytag Bravos MTW6600T Top Load Washer
The dreaded LF code
HI, there is not a defect notice or recall on this particular unit but, we get a lot of complaints about this specific issue concerning the LF code on a frequent basis. this issue dose concern the inlet valve.
The replacement will work better than the factory installed piece. This is basically a blind defect.(defective factory part).
Jun 19, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
What does this key do?
LF means line feed. This was a common key on typewriters. Now we just use the "Enter" or "Return" key.
Return meant the return of the carriage (the part on the typewriter that holds the paper and moves side to side as you type).
Basically, this just starts a new line for your text.
You can see this by typing a text message then add the LF and keep typing.
You can see the above text by scrolling with your finger.
Apr 08, 2009 | LG Dare VX9700 Cell Phone
Lf what does it mean?
Lf means long fill make sure your taps are on. or your filters in the hoses arn,t plugged in other words it is taking longer than 10 minutes to fill
Dec 11, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool WTW6400SW Cabrio Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
