Question about Mitsubishi VS-6043 60" Rear Projection Television
I have no idea so if you can help thanks
A vs-6043 was given to me because they said it did not work. The first time I
pluged it up and turned it on I got snow, so I hooked cable to it and I got a black screan w/ sound. I took off the screan and had it on and what I could tell
the bulbs were not on. I just don't know where to start.
Thanks,
Mike
  • 1 more comment
  • Tenn28 May 13, 2008
    What board on the left, left of what.
    I am having a hard time seeing that but I was do some reading on similar problems and it made mention of a tuner in front of the tv with six dials three say screen and the other say focus I turned the
    screen dials and each one brought up a colored smile on the screen I not sure if this means anything but I still need some help. And thanks for patience.
    Thanks man I'm sorry about the ignorance.
  • Mitsubishi Master
  • 8,617 Answers
The board on the left will have a series of small aluminum heatsinks with black ICs attached to them one of them will be the vertical output IC with about 7 pins on it. try resoldering those ICs and you should get the picture back as the vertical ICs will make the tubes cut off. The vertical IC should be marked on the board but solder all the ICs mounted to heat sinks on that board to be safe.
Posted on May 13, 2008
  • 1 more comment
  • Sonny Berry
    Sonny Berry May 13, 2008
    when you remove the back and look into the rear of the TV you will notice a board on the left with the power cord going to it. Thats the board that has the vertical output IC on it
  • Sonny Berry
    when you turn those dials you are turning up the voltages to the CRTs which can cause problems with the CRTs. Thats not your problem If you locate the vertical IC just resolder it and the set should come back up unless the vertical IC is defective
  • Sonny Berry
    everybody has to start somewhere. Thats an old chassis so I dont have the service info, but if you look at the board where the power cord enters the set you will see 3 or 4 small aluminum haeatsinks the vertical output IC should be on one of those heat sinks and the board should have VERT stamped on the board near that heatsink. Try resoldering that and your picture may come bacl if it doesnt you will need to replace that IC
When I turn it on no picture just a clicking sound
prionsias55,
See my tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which should help solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Feb 18, 2011 | Mitsubishi VS-6043 60" Rear Projection...
Mitsubishi VS 6043 Convergence Help
You can also access the convergence menu from the front panel, but it can be a pain to do so. If the convergence will not adjust, please respond to this post and I can help you further.
If you want a new remote you may want to check out www.remotes.com and see if they have the remote or a similar remote for you.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Sep 17, 2009 | Mitsubishi VS-6043 60" Rear Projection...
How to adjust aspect ratio on Mitsubishi VS-6043 TV?
I have the same problem and the only thing I could do was to change the name of the input on your tv to pc on the menu screen and it should set it to 1080p reduced this will fit the whole picture and set your screen res on your computer to 1920x1080
hope this helps
Aug 01, 2009 | Mitsubishi VS-6043 60" Rear Projection...
Will vs-6043 parts interchange with vs-6061
What specifically are you looking to interchange?
May 20, 2008 | Mitsubishi VS-6043 60" Rear Projection...
No picture or sound
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed along with the horizontal amplifier (they are slaved to each other). The sound comes from the flyback unit.
Well, the only way to solve this is to get a technician take a look at the set, I'm afraid. Repairs could cost upto $100 or more, depending upon the number of components that need to be replaced,
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
HOW TO RESET MY TV LOCK CODE
OPTION MENU "MENU 1370" SERVICE MENU "MENU 2357" CONVERGENCE MENU "MENU 2359"
Sep 20, 2007 | Mitsubishi VS-6043 60" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
