Question about Vtech V Tech Kidizoom Camera
We changed the batteries on our kidizoom camera and now we have a usb picture on the screen with no other functions including on/off, we have tried several different sets of batteries but no change.
  • 5 more comments
  • sarah590 Sep 06, 2010
    i have plugged the usb in to the computer and it recognises a removable hardware attached but i dont know what you mean by safely remove in windows as nothing happens and i cannot find it anywhere on the computer. Please give more detail, do i just plug in and unplug 10 times??? or is there something else i should be doing?
    Thank you, we have tried removing 10 times as suggested but nothing has happened. I will now try removing batteries for the night and try again in the morning and contact you if doesnt work.
  • sarah590 Sep 07, 2010
    no luck for restarting the camera overnight or by pressing the reset button. When we switched on this morning it looked as though it was going to work but then the camera started switching between normal menu screen and the usb screen in a flashing motion, it then went back to usb mode. nothing changes when you press reset.
    Hello
    Please advise if there is any further help you can give me. Thank you
  • sarah590 Sep 08, 2010
    I am getting no reply from the first expert and we still have not solved the problem on the camera although it does work intermitently when switched on and then goes back to the usb picture. please can you advise what i should do next. Thank you
  • sarah590 Sep 09, 2010
    The problem is nothing to do with the SD card or the storage of photos or the transfer of pictures to the PC, we have some kind of software issue which is malfunctioning in the camera as immediately you switch on the camera it goes to this USB image and no function is possible including switching on/off, we have to remove batteries to switch off as it does nothing and will not work, this is the same with or without the SD card.
  • sarah590 Sep 12, 2010
    i still have no answer to my original query on the usb picture which appears on the camera rendering it usless, it now keeps flicking between the usb picture and to normal camera screen before then stopping again.
    Guru:
  • 642 Answers
The camera needs to be reset. Remove the USB or A/V cable. Press the reset button on the bottom of the unit with a paper clip or similar. If this does not help, turn the unit off, remove all 4 batteries for at least 5 minutes. Re-insert the batteries. Power up the unit and press reset again. If the problem persists, repeat the process but replace the battries with new ones. If this still does not work, check the USB connecting port for damage. The little tab in the middle can be damaged and/or loose or there may be something inside causing a shortcircuit on the USB port which will cause the camera to cycle to USB mode. If there is nothing inside the USB port then there is nothing further that you can do other than sending the unit in for repair. I do not recommend opening the unit as this will negate the warranty and there are no user serviceable parts inside unless you have electronices training.
Posted on Sep 12, 2010
  • 17,970 Answers
Keep in mind that, this camera it includes 16MB of internal flash memory, which, with such small resolutions, can store over 200 photos or 5 minutes of video, plus an SD card slot can expand that capacity to practically limitless levels. The SD slot is in the battery compartment, which requires a screwdriver to open, thus preventing children from losing the batteries or card. Check if the SD is inside or in right position.
The camera includes 2 cords, a standard USB cord like any other camera and a monaural A/V cord with a proprietary mini-jack. When connecting the camera to a Windows PC, the PC instantly recognizes the camera and offers to import the media. Mac OS X will recognize the camera as a removable drive, allowing photos and movies to be accessed from the Finder, but iPhoto doesn't recognize the camera as such, so any images you want to save will need to be added via drag and drop or other manual methods. Also, since the camera has no internal clock, you'll need to adjust the creation date of the files if you like to sort them by date or event.
Its possible that, with the PC connection you need format the SD card.
Tell us news.
Posted on Sep 08, 2010
    Guru:
  • 194 Answers
Hello Sarah
Normally when you connect a device to a usb port , the two devices do something called a handshake in which each device tells the other it is on and ready to receive data. This handshake is again broken when the device is safely removed in windows/your operating system.
Sometimes the problem can also be caused by power failure (like a low battery or unexpected ejection of the battery) as the dip in power affects the usb circuit into thinking it got a handshake.
The first thing I would like you to try is connecting the USB cable and then safely removing it in windows. Repeat this about 10 times and check to see if it sends a stop signal to the camera so that it goes of USB mode.
If that does not work , try removing the camera's batteries for the night and try it again tomorrow. This is in hope that the camera will reset as you are not able to access the reset in the software at this time.
Let me know by tomorrow if neither options worked and I will look for an alternative to sending it in for repairs.
Kind Regards
StephanSA
Posted on Sep 06, 2010
  • 3 more comments
  • Stephan Reichert
    Stephan Reichert Sep 06, 2010
    Okay , to safely remove a USB device , please do the following
    Click on the arrow in your taskbar
    This will bring up the following box (the icons may differ)
    Now RIGHT click on the icon with the usb and the green check mark.
    This will bring up a list of devices attached to the USB port.
    Now left click on the name corresponding to the camera and the computer will give you a message that it is safe to remove you hardware.
    This should always be done with any USB device to prevent damage.
    Stephan
  • Stephan Reichert
    I'm holding my thumbs!
  • Stephan Reichert
    I was just researching the camera a bit more and found that it has hard reset button. It is located on the bottom of the camera and you can press the tiny little button with a ball point pen or something small and blunt. This should reset the camera to default settings and should theoretically solve the problem.
    Kind Regards
    StephanSA
  • Stephan Reichert
    Stephan Reichert Sep 07, 2010
    That is unfortunate. This means that something inside the camera is actively changing the camera into USB mode and this will probably be a circuitry problem inside the camera and not something you can fix at home.
    You will unfortunately have to send it in for repiars as there is nothing left to try. These camera's go for about $60 and I doubt that it will cost less than that to repair as these were designed to be thrown away when broken.
    If your child is more than 10 years old , I would suggest you rather buy a entry level normal camera as the image quality on the kids camera is only 0.3Mp as opposed to about 8-10Mp you can expect from a cheap entry level camera and the cost will only be slightly more.
    Something with a low optical zoom and an internal lens would be better for a child.
    Kind Regards
    StephanSA
  • Stephan Reichert
    Sorry Sarah , but no further steps are possible. You will either have to replace the camera or send it for a repair which will surely cost more than the replacement value of the camera.
    Kind Regards
    StephanSA
How do I work this?
Hello Shannie,
I don't know what is wrong with the camera, but you should be able to charge it with a usb charger. I don't think you should be going after the batteries. Unless people are saying to replace the battery that charges inside. If its that battery I would just try writing a letter to the company complaining and asking for a replacement. VTech Kidizoom USB Cable
Feb 12, 2014 | Vtech Kidizoom Digital Camera
I have changed the batteries on my vtech kidizoom camera pressed reset button it turns on fter a while but freezes
suggestions. Different type of battery? Two different brands of battery? check the internal contacts to see that they do not have corrosion from the old ones/
Nov 09, 2013 | Vtech Kidizoom Digital Camera
Not sure how to charge the vtech kidizoom camera
The Kidizoom uses four standard AA batteries. The manual recommends disposable alkaline batteries. If you wish to use rechargeable batteries, they must be charged in a separate battery charger; the camera does not include charging circuitry.
You should be able to find rechargeable batteries and battery chargers at just about any department, electronics, or office-supply store.
Jan 17, 2011 | Vtech Kidizoom Digital Camera
Changed battery won't turn on
Try inserting a tooth pick into the reset hole found just below on-off button and slightly to the left. Apparently the camera requires a reset after batteries have been changed. Our problem after resolving this problem is now the camera doesn't always stay on, i.e., turns off by itself.
Jul 19, 2010 | Vtech Kidizoom Digital Camera
Vtech Kidizoom camera. Have changed batteries but unit is not even switching on. Son has had for just over a year and it has been dropped several times.
Try cleaning the battery contacts inside the battery compartment. Do this with a cotton swab "dampened" in rubbing alcohol. You may also want to clean the battery contacts and the charging station if so equipt. Thanks, Dana
Jan 06, 2010 | Vtech Kidizoom Digital Camera
Pix lost from Kidizoom Camera
The instructions say that you will lose your pictures stored on the internal memory when you remove the batteries. Use a SD card instead of the internal memory, or download the pics from the internal memory before changing the batteries.
Mar 19, 2009 | Vtech Kidizoom Digital Camera
Can't download photos to computer
I figured it out and boy do I feel dumb. If you have an SD card installed in the camera, there are actually two drives when you open "My Computer" - one is "VTech773", which is the internal memory and the other is "Removable Disk", which is the SD card. If your camera has an SD card and it is set up as the default storage option, then the pictures and videos are located in the "Removable Disk" drive. Here's the text from the owner's manual...
You can connect Kidizoom Camera™ to a PC using the included USB cable. Once connected, you can upload and download files to Kidizoom Camera™ by accessing your camera as a removable storage device. When Kidizoom Camera™ is connected to the PC, a new drive called “VTech 773” will appear on the PC. If there is also an SD memory card (not included) inserted into the camera when it is connected, two new drives will appear. One will be the “VTech 773” drive and the other will be a removable disk drive for the SD memory card.
http://www.vtechkids.com/_f/_pw/_manual/80-077300%20Kidizoom%20Camera.pdf
Jan 28, 2009 | Vtech Kidizoom Digital Camera
Vtech kidizoom camera
We had the same issue. After turning on, nothing on the view screen and the buttons didn't work. The camera could turn on, the turn on screen and sound happened and we cold turn off (show off screen and sound)...even after changing batteries. It was like that for a week.
I found it had to do with TV connector slot. Thinking back, my daughter had been playing with the TV connector right before it stopped working. I took a small hair pin and put it in the TV connector slot, lightly wiggled it and the camera sprung back to life. I'm guessing the camera hardware was acting like it was still plugged in...hence turning off the view screen.
Anyways, hope that helps someone.
Jul 25, 2008 | Vtech Kidizoom Digital Camera
Vtech V Tech Kidizoom Camera Logo
83 people viewed this question
Top Vtech Toys Experts
relojmesa
cloudranger
Level 1 Expert
Are you a Vtech Toy Expert? Answer questions, earn points and help others
