Question about Whirlpool LER3624JQ Electric Dryer
My dryer was working fine this morning i tried to dtart it anddid nothing no sound nothing is just not starting i already check the breakers
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 10, 2010
Dryer Won't Start
Cam,
One thing you can check on if the circuit breaker is okay is to see if the drum turns freely. If the belt is still intact, you should have some resistance to turning the drum by hand. Many dryers have a safety in them that if the belt breaks the dryer will stop and not restart until the belt has been replaced. Hope this helps!
Nov 10, 2014 | Dryers
GE gas dryer won't start
you need a new motor
Apr 11, 2012 | Dryers
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 | Dryers
Will not turn on
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 05, 2010 | Dryers
Dryer will not turn on
Normal 0 Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 30, 2009 | Dryers
Dryer wont turn on
it sounds like the door switch or main fuse has blown,check the door switch,click it in and out to see if it has the clicking sound,if not replace,you can check the main fuse by removing the back panel,it is located on the blower box,let me know-mike
Mar 02, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Jan 02, 2009 | Whirlpool LEQ9858P Electric Dryer
LER8858EQ2 electric dryer will not come on.
Thermal fuse on the blower housing is open. Take back off and the thermal fuse is near the blower outlet. It is white and about 2 inches long. Part number is 3392519
Dec 12, 2008 | Whirlpool LGV4634JQ Gas Dryer
DRYER WON'T RUN
Just want to post the solution. After completely disassembled the dryer down to the motor, I did all component tests as instructed from the service manual and all passed. I narrow down to the motor and gave it a straight 110V external source and it did run ok. So, I checked the hardness terminal at the motor to see if it give the motor the power and it does not. I pulled out the terminal wire (brown) and plugged it back making sure that it has good contact and voila... the motor run as normal.
So the problem is: electrical wire contacts getting loose due to long time motor vibration.
Aug 18, 2008 | Dryers
Dryer won't turn on
the heater element on the drier has gone short circuit.without a model no. its impossible to give more info.contact me on dazzie@blueyonder for more assistance.
Dec 29, 2007 | Dryers
Whirlpool LER3624JQ Electric Dryer Logo
44 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
