Question about Samsung X820 Cellular Phone
Unable to activate the bluetooth in samsungX820 ceel phone
Whenever iam trying to activate my bluetooth..iam getting a error>>>blue tooth Failed<<<......so i wud really appreciate if u can provide wid m ethe answer ASAP
thnx nd rgds,
Ron
  • Burdian Jun 10, 2008
    i cant activate my blue tooth. it says blue tooth failed
  • 3 Answers
Hi i am abid pls solution me hand set mobile samsung x820 bluetooth. my email abid3322@yahoo.com
Posted on Apr 03, 2009
Hai my bluetooth not working please solve the problem
Posted on Mar 01, 2009
Im trying to turn on blutooth on my nokia 5800 it is coming unable to perform bluetooth operation
Hi,when trying to use a blue tooth and it shows (unable to perform blue tooth operation, Is because the blue tooth is corrupted.
You will need to format phone to restore blue tooth .
First: better use kasperaskey anti virus.
If your desktop pc or laptop has antivirus,
have your pc scan your fon memory through bluetooth, or usb cable
OR:
If you have Virus On mobile
1 - remove memory card.
2 - dial *#7780# or *#7073*
3 - It format your Phone
4 - Format memory card.
and enjoyyyyyyyyyyyyyyyyyyyyyy
OR
FORMATTING PHONE
Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this links.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Aug 20, 2010 | Cell Phones
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
Blue tooth can't activate
try first to RESTORE TO FACTORY SETTING or default setting your cellular phone before doing that, if you bring it for flashing then all licensed software data installed will be gone. if still not work then try it for flashing your last option
Oct 31, 2009 | Cell Phones
I cannot turn on my nokia 6630 bluetooth on
I have reformatted my nokia 6630 but still bluetooth is not working please Please help me!!!
May 15, 2009 | Nokia 6630 Handheld
Problem
reformat your phone.
Unable to connect voice dial
Hi marrick,
Voice Dial:
Important: Be sure your phone supports the voice dialing function andthat it is activated. Record at least one voice tag. (Please refer tothe instructions in your phone’s user manual.) Note: Voice dialingentries must be stored in the phone’s memory, not on the SIM card!
1. Press the Accept Button (1) for 1 second.
2. A voice dial beep will be heard on the kit to prompt the user to say the voice
tag of the contact to call.
3. Say the voice tag exactly as how you recorded it.
4. The voice will be played back to you, and then the phone will dial the number automatically.
Her's a .pdf file of the user manual, which you can save to your computer:
http://www.blueantwireless.com/downloads/supertooth_light/supertooth_light_manual.pdf
Hope this helps :)
Season's Greetings!
Chris (ziraffa)
Nov 21, 2008 | Blueant Supertooth Light Bluetooth Speaker...
Samsung SGH-D820 bluetooth static problem
find somebody else with blue tooth on their phone or get a device that is blue tooth ie hands free kit then on your phone select search for bluetooth devices if it finds any then select the item you want ie a friends phone or blue tooth if it says it is active then your blue tooth is working but to use the item with bluetooth you have to select the item it should come up as a list of items select the one you want then this should pick it up and this should solve your problem if not post back and i will try again hope this is some help.........................
Nov 01, 2007 | Samsung SGH-D820 Cellular Phone
D900 Bluetooth
try a hard reset *2767*3855# then try again
Sep 02, 2007 | Samsung SGH-D900 Cellular Phone
Samsung X820 Cellular Phone Logo
339 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
