Question about Sony Cyber-shot DSC-W50 Digital Camera
My cams mess up
All my cameras dose is say power off and back on again, i did this so many times i'm dizzy, some people said hit it one or two times, i have hit it and hit it, i'm all short of hitting it off a moving bus, at lest then i'll know it really broken, please help i have spent a lot of money, and can't get a new one, thanks
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey otooler,
I don't know what else you have tried other that hitting the camera, which of course is never a good idea with digital cameras. I would first try taking the battery out for at least 1 minute and then reinserting it. If that doesn't work and you can access the menu at all I would initialize the camera back to factory settings. I don't know when you purchased the camera but if it was in the last year this camera comes with a 1 year manufacturers warranty, and I would bring it to an authorized service center to have it looked at.
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 13, 2008
How many degree is one tooth on distributer
degrees of cam or crank????? NO YEAR< NO ENGINE STATED WOW.
answer, is a circle is 360 so if the dizzy gear is 13 teeth.
so 27.7 degrees cam and 55 degrees crank.
the crank turns 2 times for 1 cam turn. 2:1 ratio.
said another why, cam turns at 1/2 speed of crank.
no context of post.,,,, zero
bad that too.
so what are you doing???
did you PULL the dizzy?
i bet you did and no not now how to time a dizzy, many dont today
because newer cars have no such thing.
did my first in 1964
rules of dizzy 101
never remove spark wires, unless done 1 by 1,
never pull a dizzy until you learn how.
never pull a dizzy unless you put the engine at #1 cylinder, FIRING at TDC. or you will go , quite mad, hair pulled out, and cussing Tesla, endlessly.. LOL
if you post the car spec, engine size and year.
we can fix this. 100 % more easy too.
and better if context what you did. first.
Oct 17, 2014 | Jeep Grand Cherokee Cars & Trucks
Where is the timing mark and what is the firing order for a 1995 Geo Tracker 1.6 5 speed manal transmission?
timing of what, cam or spark,..... why not say the JOB, so we can be on the same page...>???????
ILL GUESS DIZZY timing,
but we use the #4 firing to set the cam..so........??????
DIZZY answer.
8v or 16v , there are 2 engines, for sure.
and both are different. see why here.
1,3,4,2 is both but not the rotor
see here.
the DIZZY rotor
8v is CW
16v is CCW.
not knowing that is doom
and never read the GM book, it lies.
here is the index to all trackers.
http://www.fixkick.com/IGN_timing/index.html
May 04, 2014 | 1995 Geo Tracker
Will not start
double posted.
which engine, the 3 or 4cyl.
bad timing belt. signs.
no power
no start
cam dont spin
rotor (dizzy) dont spin
or the belt slipped (all do after 60kmiles)
if spark timing is way off, cranking? the belt slipped, (cam)
all G suzuki engines, with belt.
btw , google does work try using google seaches for easy questions.
http://geometroforum.com/single/?p=270148&t=3272606
btw, 1st hit !
back up one post, i did a full metro no spark for you, every tests.
btw 2 this test works on all cars, only in 1996 we switched to scan tools. but the tests are all the same the makers only change
the DTC numbers to fool us, (not)
Mar 04, 2014 | 1994 Geo Metro
Engine knocks
no engine option stated, so , impossible.
the dizzy timing is way off, if in fact its a dizzy car. (distributor)
if not dizzy the cam CMP sensor is loose or some one fiddled it blind.
timing way to far advanced
so use a stroble light and set the timing to spec reading how to do that
in the FSM. (open hood lookup there is the static timiing spec, right there on all usa cars 1998.
to set timing the book shows the timing freeze jumper.
EFI needs that.
dont drive an pinging engine, or the pistons will shatter.
i warned you !-
Jul 08, 2013 | 1998 Honda Accord
Suzuki wagon r+gl check engine light keeps flashing and wont start after battery change
the engine (there are more than one engine)
has a distributor.
"have spark at coil down to dizzy but no spark at plugs"
this can mean only 2 things.
1: spark wires are dead. all 4, kinda hard to believe huh?
2: the dizzy is way off time. so time the dizzy and now spark
lands on each wire term.
if not a dizzy engine, post exact version of engine and country.
Apr 14, 2013 | Suzuki SX4 Cars & Trucks
I have an ed falcon i have recently taken dizzy out to clean. now im having troble figuring out timming . Am i at tdc or 180 out????? Is there a mark on cam gear and dose the rotor point directly to number...
Find the end of the plug wire for cylinder 1. Place the plug wire into the distributor cap. Rotate the Crankshaft until Cylinder #1 is TDC. align the rotor in the distributor cap with plug wire number 1.
Oct 12, 2012 | Cars & Trucks
I NEED THE TIMING SPECS FOR A 1971-73 340 ENGINE, BOTH STOCK AND WITH A MILD CAM... THANK YOU
mild cam is to generic, set the timing like this for a high lift cam, advance it untiol the engine pings lightly, then back the timing of 2-3 degrees's
Nov 03, 2009 | Dodge Charger Cars & Trucks
1997 Mazda 626 timing belt problem
IT SOUNDS AS THOUGH EITHER THE BELT IS A TOOTH OUT, OR HAVE YOU MOVED THE DIZZY WHEN CHANGING THE ROTOR ARM? IF YOU KNOW SOMEONE WITH A TIMING LIGHT, THEN YOU CAN CHECK ALL THE TIMING WITHOUT STRIPPING IT AGAIN. BUT IF YOU CHECK THAT THE DIZZY IS TIGHT THEN IT IS A VERY GOOD CHANCE THAT THE BELT IS A TOOTH OUT
Mar 15, 2009 | 1996 Mazda 626
Took cams off, and think i rotated them when i re installed them, will that mess up my timing?
Yes. Absolutely. Not only will it mess up your timing but on some engines if the timing is off far enough, the pistons will hit the valves as the engine is turning. The result will be bent valves. At that point, depending on the engine, you can kiss the heads goodbye. Buy a book and make sure you have the cams set to the appropriate timing marks before you go through all the trouble of putting this thing back together just to have to tear it apart again.
Mar 05, 2009 | 2000 Cadillac Catera
Camera problem
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Feb 10, 2008 | Pentax Optio M20 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
19 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
