Question about Refrigerators
Bosch refrigerator model kiv 2832
Please Help...I have a bosch inbuilt fridge that is about 15 years old. It has hardly been used, but now, the fridge compartment temp.is not cold enough circa 15°,but the freezer compartment works OK.I can hear motors working etc.
  • 1462 Answers
SOURCE: Bosch KGU44120 frost free fridge
drain is blocked in freezer. take back panel off inside the freezer and you will probably find that the bottom is covered with ice. melt off with a hairdryer and hot water till water flows freely down the drain. needs a bit of patience
Posted on Jul 05, 2008
SOURCE: Bosch Fridge freezer will not work
This is a Solution posted by a guy called Sandy Small in october 2005 and believe or not it works
Repair to Bosch fridge freezer KGV3104GB
This MIGHT be the same as yours!
Detach top panel above fridge door and "hinge" it down towards you attached to its connecting wires. See if the connector on the right has a thick black wire (nearest the fridge) and two brown wires. The faulty fridge temp. sensor can be shorted out by connecting the black wire to the brown wire next to it. I managed this by bridging the corresponding points on the PCB with a blob of solder. My fridge freezer works OK now on the freezer sensor. Hope this works with yours!
Sandy
Posted on Sep 29, 2008
  • 1462 Answers
SOURCE: FRIDGE NOT VERY COLD - ABOUT 15 DEG C, FREEZER OK
relies on air flow between fridge and freezer but is regulated.
fault is probably ice build up on top of evaporator in freezer. remove back panel inside freezer and check. also check the air ducts are not iced up
Posted on Nov 20, 2008
  • 3 Answers
SOURCE: Bosch intelligent frost free 44
there is a drain hole in the freezer dept in the fridge that is blocked This requires removing all the panels etc within the freezer until you get to the main grill at the back This will be iced up so you might have to wait a while or you might be able to chip away at it. You will then see the drain hole concerned at thre bottom Try pocking a thin wire down it or poor hot water over it Its a bit of fiddling around but is not hard to clear Problem solved
Posted on Feb 28, 2009
Illeagle
  • 525 Answers
SOURCE: How to use temperature settings on Bosch Classixx fridge freezer
You can find most user manauls at, www.managemyhome.com, on the right side of the page. You will need the model number off the product information label affixed to the unit.
Posted on Jul 05, 2009
I need a new door seal
Im afraid without the model number, which is located inside or outside on the back of your refrigerator, unless the model number tag/sticker/plate was removed or is not readable, finding the correct part would be extremely difficult.
Jun 28, 2010 | Bosch KUL1444 Compact Refrigerator
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Formation of ice in freezer compartment
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Sep 05, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Door on my integrated Bosch fridge keeps opening
Seals rarely fail most likely needs hinges replaced,parts quite cheap
Jun 16, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Fan not working
I have a bosch fridge freezer, I bought it only 13 months ago and the fan has stopped working. How do I go about fixing this problem?
Nov 03, 2008 | Bosch KGU32124 Bottom Freezer Refrigerator
Refrigerators Logo
145 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
