If I understand you correctly water is running into your washer but it will not fill up. If this is correct check your drain hose from the washer where it goes into the house drain if the drain from the washer is going to far into the house drain it will SIPHON the water out faster than you can fill it Fix is to only have about 6 to 8 inches stuck dow into house drain and secure well so it can not go down or fall out,,,,Hope this helps
Posted on Sep 06, 2010
Good day,
Without a make or model I'm not sure, but that problem is usually due to the drain hose not being higher then the top of the washer, causing a siphoning problem.
That means it is running out somewhere. The outlet hose is probably too low down.
Nov 18, 2017 | Washing Machines
Dec 17, 2013 | Frigidaire GLWS1439F Top Load Washer
Mar 12, 2013 | 1999 Plymouth Breeze
Jan 27, 2013 | Washing Machines
May 16, 2011 | Washing Machines
May 02, 2011 | Washing Machines
Dec 26, 2009 | Roper RAS8445KQ Top Load Washer
Sep 30, 2009 | Washing Machines
May 29, 2009 | Bosch SHU43C05 Stainless Steel Built-in...
Jan 03, 2008 | Washing Machines
63 people viewed this question
