Question about Epson LQ-2090 Matrix Printer
Epson LQ 2090 paper issue
We are using four part paper on this printer. Lately we are having the problem that it is printing so heavily on the paper, that the first copy shreds apart when you pull the copies apart. How do I fix this please? Our customers are getting packing slips that are falling to pieces.
  • 1 more comment
  • Joanie311 May 13, 2008
    I have tried that. When I put it to 5, which is the setting it recommends above for 4-part paper, it cuts it even more than when it is on level 0!!!
    Ummmm now what?!?
  • Anonymous May 19, 2008
    the printer will not print wide prints
  • Anonymous May 20, 2008
    I have problems with the wide carrage printer LQ 2090 dot matrix it only prints letter size in wight.
    Genius:
  • 1,447 Answers
Try this
Posted on May 13, 2008
  • Edgar Allan Pagayona
    Edgar Allan Pagayona May 13, 2008
    chances are the platten gap needs to be adjusted on the printer itself, call manufacturer for warranty
My epson lq 2090 paper load problem occurred find the solution about that
It's very cold in your place? And the paper is tick? I noticed problem with tick paper in the cold season, but i'mnot very sure about this.
Dec 20, 2010 | Epson LQ-2090 Matrix Printer
It printing but with black forms on paper
black form because of ribbon is touching to the paper for this solution is adjust head gap of the printer or put the leaver in 3+1 setting ...and try ....
replace the ribbon mask ..........
Dec 10, 2009 | Epson LQ-2090 Matrix Printer
Sir, I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for...
have you created same paper size as per windows 98 custom paper size ..... if not create as same please create the same and select the printing area also in the server properties ...... in the printing preference change page size to your created page size in layout tab advance option and in paper/quality tab advance option ... and check it ....
Nov 20, 2009 | Epson LQ-2090 Matrix Printer
Printer Epson LQ 2090 ask to insert paper for every pages
Please take note of the paper used. Letter Size A4 or custom. This can be set on the PC (Mac or Window). If not you may just reset the hardware by holding the 1st and 3rd button and then power on. You may hear a beep sound after resetting. Good luck
Sep 02, 2009 | Epson LQ-2090 Matrix Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
How to define a custom paper
Sir,
I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for WindowsXp using printer Epson-LQ-2090. immediately
May 19, 2009 | Epson LQ-2090 Matrix Printer
Printer Epson LQ 2090 out order
Light Pattern Beep Pattern Problem
Solution
________________________________________________________
* Paper Out light An unknown or serious
* Pause serious error has occurred
** Tear Off/Bin ..... ______________________
*** Font Light Turn off printer and leave it
*** Pitch Light off for several
seconds; then turn
on the printer again
Jun 11, 2008 | Epson LQ-2090 Matrix Printer
Epson lq 2090 matrix printer
This may be a mechanical problem- perhaps the belt which pulls the printhead back and forth is slipping a cog tooth in the drive mechanism. Check this belt for proper tension, and that the cogs are in good condition.
There is also a home sensor located at the left-hand side of the printhead movement area which sets the home position of the head, and from this, the start of printing is determined. If this home position sensor is defective, this will cause problems. One certain Epsons, this sensor was a switch, and this would become erratic.
These are possibilities to check...
Jan 31, 2008 | Epson LQ-2090 Matrix Printer
Epson LQ-2090 Matrix Printer Logo
144 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
