Question about Kenmore 62832 / 62834 / 62839 Bottom Freezer Refrigerator
Our model is freezer on bottom...model 596.P66032 and the freezer is frosting up and our top regridgerator is not cold
  • 2,382 Answers
Hi, these are the possible cause of the problem, you have to check one after the other to proffer the solution.
  • Vents between fridge and freezer sections are clogged with ice. Warranty guy told me to unplug 24 hours, replug and everything should work out.
  • Fautly thermostat.
  • Clogged/dirty evaporator coils (underneath in newer models, on back in older models).
  • Bad "Adaptive Defrost Control Board", Google it, it's an easy fix, about $35 on ebay, just make sure you
Posted on Sep 06, 2010
Does the control thermastat have anything to do with the freezer on my refrigerator getting cold but not freezing
If you remove the evaporator cover and look at the frost on the evaporator is it fairly even frost from top to bottom? If you don't have frost on the bottom half of your evaporator then you have a freon leak. Do you have a model number for your unit?
Mar 15, 2013 | Whirlpool Refrigerators
Freezer cold and fan running. Refrigerator side not cold, no cold air circulation. Wife says sound of refrigerator is lower pitch like something that used to be running is no longer running. Is there...
Hello Otis,
Thier is only one fan in the freezer that circulates the air throughout both ref/freezer. I dont know if ya have a side by side or if freezer on top..but if side by side one possible cause would be the damper in the upper left corner of the refrig. compartment is stuck closed so no air can enter ref.compartment(no damper if freezer on top or even if older model side by side) on either model also even if freezer on the bottom, another possible thing is frost has built up in the freezer and the coil in freezer is a huge block of frost and no air can poass through it because its totally frozen.
Let me know which might be the problem and i will help ya check that EI..is the damper stuck..is it all frosted up and ya can see frost on back plate of freezer wall ect ect..
Gene
Aug 23, 2011 | Refrigerators
Ref is cool not cold, tried vaccum the front underneath, I hear is running on top, even clean out the freezer, any suggestion?? mode # 596.638222.00 and how old is this???
Look and see if you have frost on the back side of the freezer. If you do then the defrost heater and thermostat need to be replaced. 596 prefix on your model number tells me that is an Amana Bottom mount ice box. Service Manual
Video which shows how to use your control to check for faults in the ice box
May 03, 2011 | Kenmore Refrigerators
Top freezer of whirlpool frosting up bottom notgetting cold
If your fan motor is blowing then I would say you have a defrost problem. How about a good old apartment top mount ice box manual from whirlypool?
TOP MOUNT REFRIGERATORS
Nov 06, 2009 | Whirlpool (ET8FTEXSQ) Top Freezer...
Kenmore Freezer works, but refridgerator is warm
Either there is a refrigerant leakage or if it is a no frost refrigerator air ducts to the refrigerator is closed due to frosting. Switch off the refrigerator for 3 hours and restart again.
Aug 15, 2009 | Refrigerators
What would cause my freezer to frost up with ice on the top. it is a bottom freezer,, pull out drawer and we have only had it for a little over a year.. it is a Kenmore "elite". model no. 596 7626*
If it is very humid in your area and the freezer is opened and closed often it can cause ice to build up. Try to minimize opening the freezer for 24 hours and see if the automatic defrost will eliminate some (or all) of the buildup.
Jul 29, 2009 | Freezers
KENMORE MODEL 596 BOTTOM FREEZER, FRIDGE NOT COOLING
The freezer will stay cold because a small amount of cold air will be forced through the frost but that will not be enough to make it up to the refrigerator portion. You can defrost the unit by removing the metal panel and allowing the frost to melt. Careful use of a hairdryer can speed up this process. This will likely be a temporary fix. The root cause of excessive frost can be caused by a bad door seal or a defective defrost circuit.
First check that the door seal is good by closing the door on a dollar bill at several points around the door, both on the freezer and refidgerator door. If you can pull the bill out with no resistance, the door is not making a good seal. Inspect the seal and make sure there isn't anything stopping the door from closing such as food, or a shelf not pushed in all the way.
If the door seal is good, the defrost system is likely defective. The defrost system has three main parts, the defrost heater, thermostat, and timer. None of these parts are particularly expensive, or difficult to replace you feel comfortable with repairing it yourself. If you can troubleshoot this by manually starting the defrost cycle. Let me know if you would like this procedure.
Jan 06, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frost on back wall of freezer, side by side, wont freeze
It's most likely a defrost issue. One or more of your defrost components have failed. Defrost components are defrost thermostat, defrost heater, and defrost timer or board depending on model
Nov 21, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge wont stay cold in the bottom.
Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
Jun 28, 2008 | GE Refrigerators
Not cold enough
posible defrost not happening, air is not sirculating down to bottom compartment due to frost buil up
Oct 18, 2007 | Maytag MBF2256H Bottom Freezer...
Kenmore 62832 / 62834 / 62839 Bottom Freezer Refrigerator Logo
212 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
