Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
When my machine stops during a cycle what does F1 mean?
  • 347 Answers
Long and short of it is you are going to need a new machine control unit (computer) the pressure sensor that reads the water level is failing. This is a known problem with these units,this problem will only get worse, The one thing I will tell you is make sure you are using HE detergent. One of the things that cause these computers to go bad is to much or wrong detergent used and it fills up the pressure sensor hose with soapy water that goes right into the computer and electronics and suds dont mix.....
Posted on Sep 06, 2010
I am getting a F1 code in my washer which causes it to stop several times during a wash cycle, what do I need to do?
Hello;
My name is Peter. I am a retired field service appliance technician.
If you own a Whirlpool Cabrio and are experiencing an F1 error, you're unable to finish or start a load of clothes. When the Whirlpool Cabrio displays an F1 error, this means the the control board is having difficulty communicating with the motor.
To fix your F1 error, you can first try to unplug your washing machine for 15 minutes and then plug it back in. If this doesn't work, you will need to replace the control board. The only tools that you need to replace the control board is a Phillips screw driver and a 1/4" hex head driver. Be sure to unplug the machine from the electrical outlet before performing any repairs.
After unplugging your Whirlpool Cabrio washer, carefully pull the washer away from the wall (Watch your drain hose and the two inlet hoses.) Next unscrew the 3 screws located on the back of the Whirlpool Cabrio. Next, take a picture or make note of where each plug connects to the control board. Next, unplug each plug and the pressure tube. Lastly, unscrew the 1/4 screw then remove control board. Replace with new control board and reverse your steps to install. The new board will fix the Whirlpool Cabrio F1 error.
Dec 08, 2014 | Washing Machines
F1 error appears just right after I turned the machine.. I had to stop and tstart 3-4 times before it gets on to cycle. Then at 23 minutes F! error error comes back and I had to do the same thing (stop and...
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
Aug 28, 2011 | Kenmore Washing Machines
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Stop during any cycle followed by an f-1 code
Hello & Welcome to FixYa
Error Code F1 means that the control is either bad or the wiring harness to the control has some issues. Please check the control board for any bad components as you might need complete replacement of the control. Please get back to me if you have any other questions.
Kevin
Mar 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE shuts off during wash cycle and gives F1 error
F1 error means the main control computer board. see other posts in this section as there are many who are complaining about the same problem. buying the new board (revised) will solve the F1 problem, but other problems will soon crop up on this POS washer. if you have the chance to return it to sears, return it immediately!!!!
Mar 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite Oasis HE F1 Error
Im sorry to tell you but you have a bad control board. This was a faulty board from the factory. There is a class action lawsuit agianst whirlpool (whirlpool made the oasis). Try calling to get whirlpool to fix it. Maybe try joining the lawsuit. They have remanufactured the part so the new one wont do that again. Its a great machine when it works right.
Nov 18, 2008 | Kenmore Oasis HE 27087
Washer stops immediately into cycle
f1 is the code for primary control failure cod be a bad connection at the primary control under the control console or a faulty primary control if its still under warranty id have a tech look at it
Jan 12, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
