Question about Honda Karcher G2400HH-R Pressure Washer
I have a honda excel 2500 psi , where would the pressure relief valve be located?
    Scholar:
  • 100 Answers
Many of the excel units don't come with a pressure relief valve but instead a thermal relief valve, it really depends on the model number of the pressure washer. You should only replace the thermal relief valve if it is leaking.
Posted on Oct 25, 2010
I HAVE A 2600 SIMONIZ GAS PRESSURE WASHER AND I HAVE LOST PRESSURE. CANT FIND THE PROBLEM.
Hi Trevor
You have one of two problems
1. Pressure relief valve is stuck and needs cleaning or replacement
2. Pistons that pressurize the water need new sealing rings or seals
Bud
Sep 28, 2013 | Karcher 2500 PSI Pressure Washer
Where to install thermal relief valve
It should be the last threaded hole right before the water enters the pump itself, on the low pressure ( inlet) side, most pumps have 2 different size holes 90 degrees from each other, commonly 1/4 and 1/8 in.
Dec 13, 2012 | Honda Karcher G2400HH-R Pressure Washer
Power washer stalls after spraying
Your pressure relief valve may not be working. If that happens when you shut off your spray gun, then pump is dead heading, stopping the motor. If this is the case it stops dead, not coasting. Either replace the pressure adjusting relief valve or remove it, and disassemble it and clean it.
Jul 18, 2010 | Honda Pressure Washer PSI 3000
Honda GVC 160 lost pressure - noticed small black valve (back - rear) after pressure builds up , short spray then nothing - hot water comes shooting out the black valve - did something pop off?
The small black valve is called a thermal relief valve. If it is open you will have no pressure. If the water is getting hot enough to pop that valve, there might be internal problems with the pump.
Nov 22, 2009 | Karcher 2500 PSI Pressure Washer
My Karcher vert shaft Honda powered washer cuts out when your washing kinda like when you release the trigger (except you haven't) like the relife is opening early what's wrong?
They USUALLY don't have aa true relief valve, but instead when pressure is up, it prevents any more water from enetering the pump.
REBUILD the valve as usually the O-rings in it are worn.
Oct 30, 2009 | Karcher 2500 PSI Pressure Washer
I have a Honda 2000 pwr. No pressure
check the o-ring in the pressure relief valve.
Sep 10, 2009 | Karcher 2500 PSI Pressure Washer
Fuel mix for a excell VR2522
should be a honda gcv 160 5,5 horsepower engine.
do a search for honda engine carburretor adjustment, plenty of pages on the internet detailing how to adjust carbs, mixture etc.
Excell Pressure Washer Model VR2522 Replacement Parts repair kits ...
lok at this site , parts breakdown of engine etc
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
Pressure setting of series 90 pumps
Yes 90 series pumps will run pretty close to 6000 psi. there are cross port reliefs built into the endcap of the pump and usually a POR valve as well. so the POR should be set at 3000, the cross ports in the pump should be set higher than this. There may also be a "transmission block" which is a seperate block with hot oil shuttle and cross port reliefs. Make sure these reliefs are also set higher than the POR valve in the pump. There may also be cross port reliefs in the motor. These too must be set higher than the POR valve in the pump. If you system overheats after increasing the pressure setting of the POR valve, you are probably loosing oil across one of the cross port relief valves.
Please visit http://hansonhydraulics.blogspot.com for more information. I** If am electric motor is being used to drive this pump, be sure you have sufficient horse power for this increased load. **
Jan 29, 2009 | Danfoss Sundstrand-sauer-danfoss...
No pressure to handle
sounds as if pressure relief valve is stuck open. you will have to disassemble relief valve and clean or replace.
Jun 22, 2008 | Karcher 2500 PSI Pressure Washer
Honda Karcher G2400HH-R Pressure Washer Logo
1,093 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
