Question about Cell Phones
My magic jack is like makeing a buzzing sound wen i talk to some one
SOURCE: Magic Jack Sound Issue (talking, not receiving)
my camera on Hp dv9500 not working when we play msn
Posted on Aug 07, 2009
SOURCE: Magic Jack Sound breaks up and you can not make or receive calls.
I had this problem and started doing every hack that I could find on the internet. I have a neighbor across the hall whose Magicjack worked fine, and so I plugged my Magicjack into his computer, and it worked fine. So, I knew my computer had the problem. After a month of hacks and fixes, to include reinstalling the operating system, I found something that worked! It has to do with the paging file on your computer. I partitioned my hard-drive and put the paging file on its own partition. I also installed a second hard-drive and gave the paging file a second partition to go to. After doing this, my computer runs much better and the Magicjack works like a charm. In the last 3 months of using it, I haven't had any problems. This solution also reduces the problems with fragmentation of your paging file and the overall memory.
Posted on Nov 08, 2009
SOURCE: calls cutting out with magic jack
Your ISP connection speed may be inadequate. Typically, the upload speed (outgoing voice) is much slower than the incoming speed. To check majicjack recommends that you test your system on http://www.speakeasy.net/speedtest/ .
It's also possible that your internet provider is purposely delaying the outgoing latency in order to discourage VoIP that THEY don't provide. I think this is (or at least should be illegal) but in any case a complaint to the FCC might be in order.
Posted on Feb 04, 2010
theodoreande
  • 4 Answers
SOURCE: FAX MACHINE WILL NOT WORK WITH MAGIC JACK
Magic Jack will work with fax machines. You may have to experiment by slowing down the fax machines modem transmits speed. This is done in the machines menu.
The Magic Jack manual is quite clear, it can handle faxing.
Posted on Apr 06, 2010
fordey08
  • 155 Answers
SOURCE: my magic jack is not
I received the same error; when I visit the Majic Jack forum, it says that basically this error is due to a windows Firewall. I disabled my firewall, so that does not seem to be the problem; I also have several monitors, which may be interfering with my interrupt settings and ports.
I am sure if I put my computer back to an earlier date, it would correct everything, but I may lose data I have, as I have not backed up everything, nor do I feel like it. =)
So what I am saying is try to disable your firewall and see if that works. Meanwhile, I am trying to find an answer myself.
Posted on Jan 24, 2011
Tip
A fax machine is just a big ol' telephone answering machine
There is no mystery, seriously. You send a fax exactly the same way as you make a phone call; instead of talking to a person, your fax machine talks to another fax machine. Clicks, squeals, buzz sounds.
If it says it's busy, well, it's busy
If it doesn't answer, it's not set to AUTO RECEIVE
If it says OFF HOOK another device is using YOUR phone line.
If you don't hear a dial tone when you press the HOOK or MONITOR key, the phone line is dead. Check the line with a regular phone.
If a dial tone sounds weird, it is a DIGITAL phone line. You need an ANALOG or regular phone line.
ALL FAX MACHINES ARE ANALOG DEVICES AND WILL NOT WORK RELIABLY ON A DIGITAL SYSTEM OR A COMPUTER....Magic Jack, Vonage, etc. are DIGITAL PHONE SYSTEMS. Don't believe what the Vendor tells you. They are for designed for VOICE GRADE PHONE CALLS ONLY.
The settings in your fax machine were designed by people who are a lot smarter and make more money than us. DON"T MESS WITH THE PARAMETERS.
It's all that SIMPLE !!
on Mar 09, 2010 | Office Equipment & Supplies
Magic jack cutting on and off
make sure the device is fully seated and not moving around. make sure there isn't anything putting pressure on the USB connection.
Apr 08, 2017 | Magic Computers & Internet
The voice of the person talking to me over Magic Jack breaks up. It is as though the sound fades in and out making it impossible to understand what the person is saying.
magic jack can be a funny beast....on my quad core 10GHz AMD box under Windows 7 or XP, it 'll break up like crazy, but I built a 1.5GHz single core P4 under XP and it works flawlessly on it...so that box does nothing but the magic jack now. Yup, got a BIG phone box under the desk...lol...
Mar 02, 2011 | Computers & Internet
When i use my magic jack when i am talking it fads in and out and it crackles a lot and the other person on the other end and it also is mombales the voice.
Magic Jack uses your bandwidth for data transfers on calls. If you are downloading or uploading data while placing a call there can be significant disruptions while you are making the call. If you want the clearest call possible, make sure nothing is downloading (online gaming included.) Hope this helps!
Mar 01, 2011 | Magic Computers & Internet
Aug 07, 2009 | Acer Aspire 3680 Laptop
Magic Jack- Other person hears beeping every few seconds
You can use Magic Jack customer care at http://www.magicjack.com/2/customercare.asp
I talked to 3 operators. The long and the short of it is that they had me:
1. remove a Majic Jack related folder from an applications folder
2. insert MJ1 and MJ2 in the Windows Firewall exceptions
3. format the Majic Jack software "drive"....and then install an upgrade.
Based on this, I think the problem crops up in the Majic Jack software. So far, it has fixed my problem, though I've not made a long call yet.
I found the Majic Jack operators very helpful. Be sure to have them step you through this.
Good Luck!
Amy
Jun 17, 2009 | Computers & Internet
Magic jack problem
I have a magic jack and I can talk for 10 minutes only or less and then i hangs up , this problem is happening in three majic jacks with other friends
please advise
Jan 15, 2009 | Lands Phones
Cell Phones Logo
533 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
