Question about Cub Cadet Garden
The rear right wheel is locked up the brakes are not the problem it is a time saver 1046. i have disingadged the drive and it rolls fine but when i engage it locks up
SOURCE: Wheels do not freely roll backwards
SOUNDS LIKE THE PINONS ARE ON BACKWARDS. THE KEY SHOULD SLIDE OFF THE PINIONS WHEN PULLED BACK AND LOCK WHEN ENGAGED. YOU HAVE THE OPPOSITE PROBLEM OR ITS BACKWARDS!
Posted on Oct 16, 2008
  • 48 Answers
SOURCE: The front wheels on my lawn mower have locked
on yours you must replace the entire tranny unit - to make it roll you can remove the front wheels and remove the small gear on both sides - doing this of course will turn it into a push mower not self propel
Posted on Oct 21, 2008
SOURCE: wheels lock when self propel not engaged
Hi
a;; you need tp do is loosen the cable slightly to the self drive mechanism
Posted on Apr 05, 2009
  • 4 Answers
SOURCE: I have a power mower model cub cadet 997 when
cdr690rick sound like the rearend need's an overhall job i had one dond the same thing as that one dose. The geares in it are shot and it is not cheep to have it don
Posted on Apr 18, 2009
  • 4 Answers
I had this same issue. In my case, the sheild that keeps the dirt out of the gears in the wheel has gotten broke and the gears filled with junk and jammed the wheels. I just have to take the wheels off and blow the junk off the gears.
Posted on Jun 07, 2009
Got a 2012 ltx 1045 the wheels are all locked p I tried to pull the back lever to get it to move but all 4 wheels are locked help
this is rather odd as none I have seen are 4 wheel drive. only rear wheels drive and if the clutch/brake pedal is down and locked it will not roll when you releases the back lever
Mar 20, 2015 | Garden
Remove rear wheel from yamaha 650 v star
The final drive has a spline shaft. Raise the rear wheel off the ground , loosen the rear axle nut, take out the axle bolt, knock out the spacer , unbolt the rear brake caliper and hang it so you do not stress the brake hose ( unhook the brake rod and unbolt the stabilizer rod for drum brakes) , grab the wheel, and slide it sideways away from the final drive. The wheel should slide right off the spline of the final drive and roll out the back under the fender. If the wheel won't slide past the final drive let the air out of the tire. Be sure to coat the spline of the final drive with moly60 paste from your local Honda dealer when reassembling.
May 09, 2011 | 2007 Yamaha V Star Classic
What to look for as I remove the rear wheel. Shaft Drive
Center stand the bike or lift the rear wheel off the ground, loosen the rear axle nut, take out the axle bolt, knock out the spacer, unscrew the rear brake adjuster nut, unbolt the rear brake panel stop arm, grab the wheel, and slide it sideways away from the final drive. The wheel should slide right off the spline of the final drive and roll out the back under the fender. If the wheel won't slide past the final drive let the air out of the tire. Be sure to coat the spline of the final drive with moly60 paste from your local Honda dealer when reassembling.
Mar 02, 2011 | 2005 Honda VT 1100 C Shadow Spirit
E-brake is locking up tires
if rear e-brake locks up then get under car and pull on cable to rear wheels, this should un lock brakes, if the cable is not in a bad state and rusted. if to bad replace rear cables. if it comes loose then oil the cable good at the rear wheels. this may take care of problem.but you may have to take rear tire off to check on the condition of rear brakes also.
Apr 14, 2010 | 2005 Chrysler Town & Country
Trying to push riding lawnmower up ramps to take it to repair shop and the back wheels are locked. We can't get them to move even if in neutral. Help! Can't get it fixed if we can't get it to the shop. Too...
The brakes have locked up. Look under the right rear side of the mower, between the wheel and transmission. You should see a disc, similar to disc brake on your car but a smaller version, There is a nut you can turn to take the pressure off the brake pad. Should take a 1/2" wrench to do this.
Loosen it enough to get the mower to move back and forth then you should be able to load it up on your truck.
Sep 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
98 Chevy c2500 rear brake lock up
No axle gease at all on the shoes. Or brake fluid? Have you tried loosening the adjustment a turn.
Jun 14, 2009 | 1998 Chevrolet C1500
89 f150 4x4 right rear locked up
On older vehicles with drums brakes in the rear, the brake shoes on the inside are used for the emergency brake. However, the emergency brake only uses one pad per wheel instead of both, which is why the emergency brake does not work as well at keeping the vehicle from rolling backwards. You should check to see if the emergency brake is locked up. If that doesn't work, take the driveshaft off and try tow it forwards. If it rolls, then your transmission is not functioning properly.
Jun 10, 2009 | 1999 Ford F150 Regular Cab
Right rear wheel has rubbing and grinding noises, as on cast iron
My advise is to adjust the rear brakes. The drum should not move in a side to side fashion. adjusting the brakes will also more than likely take care of that anti lock brake light also. adjust the brakes up to where the rear wheel will spin but you should be able to hear the brake show dragging slightly on the drum.
Apr 06, 2009 | 2001 Mitsubishi Eclipse Spyder
Rear wheel lock up/driver side/2wheel drive
spider gears in rearend r broken and binding up on the ring gear
Dec 19, 2008 | 2003 Chevrolet Silverado 1500
Garden Logo
44 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
