Question about Dynex DX-L42-10A 42 in. LCD TV
Dynex DX--L40-10A, less than 7 months old. When TV is turned on the screen is black with no sound, blue light is on, only able to turn TV on with remote control, manual inputs on side of TV are inoperable. Unable to turn TV off, only way is to unplug. Intermittently (approx 1 out of 6 times) when TV is turned on there are loud static/crackling sounds.
  • 3 Answers
SOURCE: Dynex dx-l40-10a remote code for COX
Not sure if you figured it out yet, but I bought the same set, about the same time you did, and had a heck of a time finding the code that worked on the Dish Network 5.4 IR remote.
I *FINALLY* figured out today that it uses the 3rd one listed for Sansui, which in the case of Dish Network, is 721.
Posted on Feb 23, 2010
SOURCE: My Dynex DX-L40-10A cannot connect via HDMI with
I had the same issue when connecting through HDMI 1. I tried one of the other three and it works.
Posted on Apr 05, 2010
hmerchant110
  • 7191 Answers
SOURCE: need owners manual for dynex dx-l19-10a
You can download the owner's manual by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
Posted on Jun 04, 2010
  • 5478 Answers
SOURCE: Dynex dx-l40-10a flat-screen hdtv turns on and the
It's a backlight or backlight inverter issue. (The backlight itself usually fades or makes the on-screen image change to pink/red.) For an out-of-warranty TV, open up the back of the TV and remove the shielding. Look for any scorch marks or bulging or damaged capacitors. (Sometimes other parts will fail on this part but these can be spotted easily. Capacitors look like cylinders on a tripod.)
If you borrow (or have a) high-end multimeter (able to measure high frequencies - 50 kHz) or an oscilloscope, hold the multimeter probes a fraction of an inch apart about an inch above the board and power up the TV. If you see a 1 or an actual value, you have a good inverter. If you see a reading near 0, the board is bad or the multimeter can't resolve the frequency.
In either case, you can buy a replacement inverter for $50-150 and just do a simple swap. Disconnect all of the wires (connections are similar to molex and ribbon cables in a computer) and remove board (a few screws usually). Connect the cables to the new inverter. (If you google backlight inverter replacement, you'll find videos and text descriptions.) Note the part number on the board, including the Rev number, and order the exact one (shopjimmy.com or lcdparts.net are good starting points). Universal inverters do exist but can result in reversed controls (up to lower the brightness). Replacing individual parts on the board is cheaper but more prone to not tracking down all of the bad parts.
If the inverter is good, then it's probably backlights themselves (several in most TVs). These are sandwiched on the perimeter of the TV (usually under some tape that holds the lamp, reflector and other parts together. You need to order by length and width and get ones for your TV size. Remove the tape, and separate the reflector (make a note of how things are put together) then you have to Dremel (or use another rotary tool) to remove the plastic to get the backlight out. (They are often molded into the frame.) Then put in the new backlight and reassemble everything. (http://www.lcdparts.net/howto/default.aspx) but for an overview: http://www.inventgeek.com/Projects/BacklightFix/overview.aspx
With a good spare backlight, you can test an inverter for condition (plug together and turn on the tv while the box is open). Similarly a good inverter can test the backlight. With a bad backlight, you'll usually see a very dim image if you look at the TV from an inch from the screen. Block the room light from overwhelming this image (sometimes a carefully positioned flashlight will help you see something). If the inverter or video board is bad, you will see nothing
I hope this helps.
Posted on Jul 21, 2010
Testimonial: "thanks"
  • 88 Answers
SOURCE: Our Dynex dx l40 10a
Turn the TV off, unplug it from the wall. Hold down the power button on the TV for about 20 seconds. Reconnect it and try to turn the TV on again. If the problem persists the TV is in need of some service by an authorized service center if under warranty. If not, look around for someone that can take a look at it in your area.
Posted on Jun 15, 2011
Tv powers up to green,but just lights up dark blue screen,nopicture,sound,etc.
I just answered that a while ago, why do you people ask the same thing several times?
Sep 30, 2012 | Dynex DX-LCD32-09 LCD TV
I have a 42 inch Dynex tv have had it for about 2 years now its starting to just cut off by its self. HELP!!
Try changing the input device to something you are sure works. Look for any loose contacts in RC jacks/sockets/Cable. If problem persists, please refer it to a qualified service technician.
Jul 30, 2012 | Dynex DX-L42-10A 42 in. LCD TV
Dynex DX-24L150A11 won't turn on LED light is not on either
Sounds like you are missing your 5VDC standby voltage from the power supply. You either have a blown fuse or a defective power supply. Did this happen out of the blue or after a T-storm???
May 11, 2012 | Dynex DX-L42-10A 42 in. LCD TV
Dynex 22 tv has sound no picture
Power supply caps or backlight inverter! Common issues with LCD flat screens for some reason.
Dec 28, 2011 | Dynex DX-L22-10A 22 in. LCD TV
The tv keeps randomly turning off, now i cant even turn it on, the light goes blue but the screen stays black
Sounds as if your back lights are not lighting, and that points to the high voltage power board. You may have the dreaded capacitor failure. Start with http://www.youtube.com/watch?v=YfO-KCQIYXQ&feature=related and look around.
Jan 27, 2011 | Dynex DX-L42-10A 42 in. LCD TV
I have a DX-LCD32-09 LCD TV that is less than 2 years old. When you turn the TV on the sound is great but no pic. It is black. What could be the problem
More than likely it uses florescent bulbs for illumination. I first would try replacing the power supply for the bulbs
Nov 02, 2010 | Dynex DX-LCD32-09 LCD TV
I have a 32" Dynex flat screen DX-L32-10A and I turned it off and later tried to turn it on, ther is no sound or picture, I only have a blue light on some one please tell me what to do0
It could be either bad capacitors which are noticable or bad transitor not noticable. It is in short protect mode to stop it from possibly burning.
Jul 04, 2010 | Dynex DX-L19-10A LCD TV
Dynex dx-pdp42-09 screen went black; won't turn on or off
dont really know,would you be interested in selling it lik that?
Feb 08, 2010 | Televison & Video
The TV (Dynex DX-LCD32) will not come on. The
I have a DX LVD33 power light is red and no picture or sound screen is black. Please advise.
Dec 25, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex DX-L42-10A 42 in. LCD TV Logo
174 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
