Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Hobart lx30 : rinse cycle
Rinse pump will not run in its cycle. Pump check out ok ?
  • 1 more comment
  • Anonymous Mar 13, 2014
    rinse temperature don't go above 79 degree
    rinse not heating
    rinse heating problem with hobart lx30
    Scholar:
  • 68 Answers
The rinse water in a LX30 is driven by water pressure. A solenoid valve, bottom front - gold body, opens up and allows the water to flow.
If you are referring to the rinse agent pump, there must be NO leaks in the tubing or the hose that runs through the pump. And if the unit has lost its prime, using your hand to "seal" it, and forcing water from the faucet into the line can prime it.
Good luck - Mike
Posted on May 13, 2008
Hobart glass wash machine AMX-GH wash with normal temperature but do not advance to rinse cycle
Can you describe the sequence of operation?
Fill ok?
Booster or tank heating ok?
wash pump running ok?
Sep 28, 2016 | Hobart Underbar Glass Washer
Causes of low rinse water pressure on a Hobart ft900-d washer
For a machine without a break-tank (a.k.a. cistern) and booster pump: check the inline debris strainer on the rinse water pipework; check you're not missing any rinse jets; check the inlet valve is fully opening.
For a boosted machine, check the pump impeller isn't disintegrating; check that the flexible hoses to the booster pump aren't collapsing internally.
For both machines: descale if you're in a hard water area.
Mar 15, 2015 | Hobart Dishwashers
I have Hobard LXIH dishwasher, it is working OK but during rinse cycle instead of taking in rinse agent it is actually fill rinse bottle back with water. Rinse pump is working, it was replaced in June
Check the rinse pump. The tubing needs to come from the supply into the bottom of the pump, and the pump should be running clockwise. If the pump tube is worn, the rinse pressure will blow through the pump filling the bottle
Dec 12, 2013 | Hobart Dishwashers
What type of detergent is used for a lx30c hobart undercounter dishwasher
What type of detergent is not necessarily important - anything intented for use in commercial dishwashers should be sufficient. A restaurant supply store should have something suitable for you.
Also, in case you don't already know, the LX30C is the non-booster-heater version of the LX30 (LX30H has a booster heater). Without a booster heater, you'll need to use chemical sanitizer. The LX30C should, hopefully, have a sanitizer pump installed to inject chemical sanitizer into the rinsewater stream. Most of these dishwashers also have a detergent pump to inject detergent into the wash tank and rinse aid pump for chemical rinse aid.
If present, these pumps are located in the bottom of the machine. Remove the lower front panel (2 screws) and look for the small, black plastic assemblies with 2 hoses connected to each.
Mar 13, 2012 | Hobart 24 in. LXIC-5 Built-in Dishwasher
Water wont come in the dishwasher. It is heating with out water and then smells like plastic burning. Hobart LX30
Check that your supply faucet is open, Check if there is a screen in the supply line, these can become blocked due to scale deposits from the mains. If there is no screen check that the inlet solenoid valve has not got blocked. If none of the above help, check that there is power getting to the solenoid valve when the machine is supposed to be on the fill cycle. If no power is getting to the valve, the timer might be faulty. (You can try hand filling the machine and see if it goes through a cycle, at least up to the rinse stage, this will tell you if the timer control is working).
Apr 18, 2011 | Hobart Dishwashers
Commmercial dishwasher has proper pressure when
same pump does both, are you certain there is nothing in front of the pump? I would pull the safety hood off and look inside
Jun 29, 2010 | Hobart AM14-253 Free-standing Dishwasher
Hobart dishwasher lxic detergent pump will not run
it supposed to work throgh the washing cycle,therefore you better trace,and inspect the line of the detergent,maybe it'stuck somewhere,and if it's ok check the panel board.does the pump receive voltage through the washing cycle.
Apr 15, 2009 | Hobart 24 in. LXIC-5 Built-in Dishwasher
No water going in to dishwasher when rinsing
the pump shouldn't turn on when the rinse cycle is on - it uses only fresh water straight from the water line - after the wash cycle is over - wait 5 seconds, then open the doors and see if there is any rinse coming out of the rinse arms.
If only a little is coming out - check the rinse arm spray jets to see if there is debris caught in them -
if no water is coming out - it could be a faulty rinse solenoid
Aug 05, 2008 | Hobart AM14-253 Free-standing Dishwasher
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
554 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
