Question about Sharp AL-1655CS Copier
I have a sharp AL 1655cs printer copier and I have replaced the drum cartiage but it still says that it needs a new one is there a way to reset so it knows there is an new cartage in it?
  • 1,110 Answers
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
Posted on Sep 06, 2010
I have a Sharp AL-1655CS and when i make copies, the copies are really dark. For example, the white areas come out gray and dark. How can I fix this problem?
I would try a different toner cartridge or possibly a drum cartridge. Have you had the machine serviced at all? When?
Feb 14, 2011 | Sharp AL-1655CS Laser Printer
What is the drum number for copier AL-1655CS
AL100DR
Here is where I get mine:
http://www.precisionroller.com/search.php?q=al1655+drum
Or if your copies are fine then you can reset the drum indicator by using this procedure I have posted here at Fixya:
http://www.fixya.com/support/r3798552-sharp_al_series_copier_drum_light
If you use it, please remember to retun here and leave feedback.
Thank You for using Fixya.
Wheatland Services
Dec 22, 2010 | Sharp AL-1655CS Copier
Sharp AL-1655CS ''Replace the drum cartridge'' error message
Have you replaced with a new drum cartridge? If so, does it still display error message? You have to simulate 24 sub 7 to reset drum .
Nov 04, 2009 | Sharp Office Equipment & Supplies
My Sharp AL-1655CS copier has new drum and toner. Leaves blank banding lines verticaly down the page in at least three areas.
This is a good one you may need to get it serviced.
The toner is held to the drum by static which rolls the toner onto the paper and seals the deal you may have a bunk drum, Validate your warranty and check for a service center.
Oct 19, 2009 | Sharp AL-1655CS Laser Printer
System error L1-00 Sharp AL 1655cs
hi maryanne,delete all the sharp AL 1655cs programme and reinstall the printer software (INSTALL PRINTER) if need more help please log on to sharp copier web site for the manual instruction..before that make sure your printer is compatible for your PC.
Dec 08, 2008 | Sharp AL-1655CS Copier
Sharp 1655cs- replace the drum cartridge
There is a set of gears in the front of that drum cartridge with a flag on one of the gears, It has to be in the up position to swipe the drum replacement sensor. Most likely the flag had dropped in shipping.
You can take the green front off the drum and try and get that flag up and to the right. Or take the drum cartridge for a return and a new cartridge.
If that flag has dropped in shipping, it will not reset the drum count.
Apr 04, 2008 | Sharp AL-1655CS Copier
Replace td warning
I went into the user menu and RESET FACTORY setting and the error went away
Dec 11, 2007 | Sharp AL-1655CS Laser Printer
Sharp AL-1655CS Copier Logo
144 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
