Question about LG WM-2277HW Front Load Washer
We get error code OE and our washer will not drain
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. OE is a Drain Error which indicates that the water was not fully drained within 10 minutes. To start with check the drain pump filter for any clogs/foreign materials and try to clean the filter. Also if you have already checked the drain hose for any blockage then check the pump for any blockages, if still its not resolved then it seems to be the pump that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 07, 2010
What are the common fixes for OE Error Code?
OE error code is an Outlet Error.
That has to do with the drain itself. It can come up when the unit is draining slowly, it has nothing to do with water-level really. I would suggest makign sure that your drain hose is not crimped / crushed / or obstructed first before going onto other problems.
May 02, 2014 | Samsung DMR77LHS Tall Tub Dishwasher
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
WF328 AAG OE error code...how do reset this? or can I reset this?
The code OE is a draining error. The washer has sensed that the water has not completely drained all of the water within 10 minutes and will display this error code.
  1. Locate your drain pump access door on the front of the machine.
  2. Clean out the filter area.
If you are unable to resolve the issue by cleaning, I would recommend replacing the drain pump.
Jan 24, 2011 | Samsung WF328AA Front Load Washer
Won't drain during cycle, drain motor noise before stopping with OE drain error?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
LG Washing Machine OE Error Code
heatman101
Sep 03, 2010 | LG WM0642H Front Load
Oe error code
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludgeOR "OE"
- Water overflow error Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord.
· Check wiring harness
· Check water inlet valve
· Check pressure sensor switch
· Check circuit board
Feb 20, 2010 | Kenmore Elite 45986 Front Load Washer
My washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Jan 18, 2010 | LG WM-2277HW Front Load Washer
LG front load washer OE error. cleaned filter need
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!!!!!!
Jan 02, 2010 | LG WM-2277HW Front Load Washer
OE ERROR CODE APPEARS ON DISPLAY ON MY LG FRONT LOAD WASHER
Oct 14, 2009 | LG WM-2277HW Front Load Washer
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
Error code OE?
OE = drain hose blocked or clogged, or the drain filter is clogged
Dec 22, 2007 | LG WD-1080FD Front Load Washer
LG WM-2277HW Front Load Washer Logo
41 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
