posted by Scoey1 on May 13, 2008
After following all feedback, I still continue to have the problem. My son's laptop is windows xp. His laptop was connected to the external Envision screen. When I hooked up my laptop, after ree booting the Envisoon screen, the screen boots up and says Windows XP. After the message disappears it states NO SIGNAL. I click the F5 key which shows display. Three boxes pop up. I need to check the middle box when it shoes a laptop screen to an external screen. I clikc on it but it doesn't change.
Solution #1
posted on May 14, 2008
Hi again,
Have you tried lowering down the Screen Resolution and the Screen Refresh Rate in your Acer Aspire 5000's Display Properties?
If you are not able to do that, pls post back that I may walk you through the procedures.
Cheers.
Cheers.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
HP Compaq FS7600 17 in.CRT Conventional Monitor
HP 2025 (Carbon, Silver) 20.1 in. Flat Panel LCD Monitor
HP L1702 (Carbonite, Silver) 17" LCD Monitor
Philips 105S51, 15 in. (White) 15" CRT Monitor
Philips 190V6FB (Black, Silver) 19 inch LCD Monitor
Philips 170S5FS (Silver) 17" LCD Monitor
Philips 170S7FS (Silver) 17 inch LCD Monitor
Can you Help with these Monitors problems?
Gateway FPD2275W (Black) LCD Monitor
Gateway FPD1975W TFT LCD...
Due to my involvement with... Answer This...
Microsoft HannsG HU171D (Black) 17" LCD...
help with calibrate
help with calibrate
I have a monitor I just bought... Answer This...
Repair Service
Find Monitor Repairman Near You:
