I have no cold air coming from vents but cold air coming from where the filter is in my hallway celing. The unit was installed brand new a few years ago
  • 43,501 Answers
The indoor blower motor has probably gone bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 07, 2010
Proper vents for a mobile home
The amount of air that flows to each room is determined by the size of the ducts. Once pressurized all rooms should already be balanced. The diffuser may alter the direction of the air but the hot air will quickly rise and the cold air return from the furnace will such the colder air from all rooms at once down the hallway. Hence the diffuser is doing it's job, It does not need to be replaced. Trailer sized diffusers are difficult to get and match. If you cut the hole size larger to allow a house diffuser you may have unbalanced the amount of heat for each room... if you cut them all larger then it is back in balance again. Weather the air goes up or sideways is just personal preference. You can get magnetic shield to divert the air if you please for far less money.
Nov 13, 2013 | Heating & Cooling
New a/c goodman unit last year air coming out of vents not cold but everything seems to be running fine
Hello, this could be due to a lack of airlow or a low regrigerant charge. First check the air filter and make sure it is clean, make sure the blower motor wheel is clean and not dirty, also it would be a good idea to check tne evaporator coil and make sure it is clean. If the unit does not have any airflow problems most likely it is low on refrigerant due to a leak, in this case you will need a hvac tech to come out and repair the leak and charge the unit back up with refrigerant.
Jun 01, 2011 | Goodman CLJ36AR42 Air Conditioner
Where are the air filters on a Rheem Model # RRKA-AO36J10E
Hello Try inside the hallway or in the large intake vent.If not try the blower unit itself in the attic or basement.
Sep 09, 2010 | Heating & Cooling
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Apartment Central A/C Unit Not Working Properly
Sounds to me you are low on freon and the evap coil in icing up
Jun 25, 2009 | White Rodgers 0754-1 Electric Water Heater...
Goodman CACF048B2A Air. need to know the location of the replacement filter
The disposable filter is always in the return air of an a/c unit. If your unit has a furnace attached in an upright position then the filter is under the furance blower wheel. You will have to remove the bottom access panel to see and replace it. If your unit is horizontally installed in an attic then the filter will most likely be up in that return air duct or possibly in the return air grille possibly mounted in a hallway or someplace like that.
May 30, 2009 | Goodman CACF048B2A Air Conditioner
A/C issue with 99 Grand Prix
Check the ac filter, it might be dirty and thats why it is not blowing out enought cold air. The filter is located under the wiper cover but behind the firewall on the passengers side. You access this by lifting the hood and removing the rubber type gasket that holds both together, right on top of the blower unit.
Apr 24, 2009 | 1999 Pontiac Grand Prix
WHEN THE HEATER COMES ON THE FAN STARTS INSTANTLY AND BLOWS COLD
Do you have a heat pump? If so this is normal. You are probably used to a gas furnace. There are heat pumps that do have a delay though. Look on the circuit board in the air handler. There may be a set of pins that say 0-30-60-90 yours may be at 0. Also some digital T-stats offer that function for delay off to get the extra heat or cold from the system. Find out what the model number of the air handler and call the Goodman supplier in your area to see if you have these options.
If you have a gas furnace and it's not delaying the blower there is definately something wrong.
Mar 17, 2009 | Goodman Heating & Cooling
Replacing Jenn-air down draft with new unit
Since Jenn-Air has been acquired by Whirlpool, there have been an explosion of problems with their appliances.
Please research your intended purchase before deciding on a replacement:
Jenn-Air info
Considering the array of early failures everyone seems to be having with appliances (US made and foreign) bought in the last few years, I couldn't even recommend a manufacturer any more.
Jan 25, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
