Question about Frigidaire GLMV169D Microwave Oven
Door Disassembly Somehow a spider got in between the two glass panels in the door. I see from the parts manual that the door does come apart, but how do you do it without breaking it?
  • Frigidaire Master
  • 9,086 Answers
Do you have a can of compressed air (duster) or an air compressor? That would be SO much easier...
Otherwise, you normally have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Please write back with your brand and model number if you need further help.
Posted on May 22, 2008
Replace inner door glass in a Maytag CWE900 built-in oven?
There is a poor diagram on Searspartsdirect.com, but no instructions. A diagram might help.
Feb 18, 2015 | Maytag Microwave Ovens
DGE Microwave door disassembly for a JVM1790SK01
Normally you have to separate the door panels as shown in the below.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Jan 17, 2014 | Microwave Ovens
LG door panel separating
DO NOT use this microwave in the current condition it is in- please! Although microwaves do not emit ionizing radiation, it does emit non-ionizing radiation and electromagnetic fields- and there is a lot of research studies being done possibly linking microwave exposure to cancer.
If your microwave is in that bad a shape, bring it to an authorized microwave repair shop or junk it and buy a new one.
For replacement parts, repair videos, and manuals: http://www.lg.com/us/support/parts-accessories
Jan 03, 2014 | LG Microwave Ovens
How do you remove Whirlpool microwave mh7140x door to replace white plastic door face?
If you are referring to the disassembly and replacement of the door, just follow these steps:
1. Open the door all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
2. On MOST microwave ovens, all you have to do is remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel to release the clips that hold it in place so you can pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
3. With the inner panel removed, locate the door handle screws and remove with a screwdriver.
4. The panel glass should be "sandwiched" in place (double layer on most ovens) and should either lift out, or have retaining clips holding in place. Remove and set aside.
5. The remaining piece(s) comprise the door frame. Replace as necessary.
REASSEMBLY: Re-insert the panel glass, followed by the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
There are several parts sources available that you can use to purchase replacement parts:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer helpful exploded view parts listings to aid in parts identification and location. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this advice is helpful.
Nov 03, 2010 | Whirlpool MH7140XF Microwave Oven
How do i remove a out door frame of a GE profile spacemaker 1800?
1. On MOST microwave ovens, all you have to do is remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel to release the clips that hold it in place so you can pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
2. With the inner panel removed, locate the door handle screws and remove with a screwdriver.
3. The panel glass should be "sandwiched" in place (double layer on most ovens) and should either lift out, or have retaining clips holding in place. Remove and set aside.
4. The remaining piece(s) comprise the door frame. Replace as necessary.
NOTE: This repair should be done with the door REMOVED from the oven for easier access. To remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
repairclinic.com
Oct 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Own Whirlpool Microwave oven Model MH6141XKQ. How does one clean the "inside" glass of the door. By inside, I mean between the two glasses on the door.
You will need to remove the door and take the door apart to clean between the glass. This process is not that difficult. Just follow these steps:
1. Open the door all the way and lift straight up at the hinges to remove from oven.
2. Place the door, face down on a soft surface to protect the door and glass. A layer of towels on a countertop or table is recommended.
3. Remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel. Work your way slowly around the perimeter of the glass to release the clips that hold it in place so you can pry the plastic up and pop the panel loose. Use care not to pry against the glass.
4. With the inner panel removed, the glass should be easily accessible and can be carefully lifted out and cleaned. Clean with a good non-streaking glass cleaner.
Make sure you remember how the door is assembled as you take it apart. If you forget, the following webistes have illustrated parts listings to show how your door is assembled:
If you have any questions, please post back and let me know. I hope this helps you.
Aug 12, 2010 | Whirlpool Microwave Ovens
There is a whirlpool Microwave (model:MH1150XMB4) in our apartment. Unfortunately, there is a crack in the door. Although the crack is only in the plastic frame of the door, the landlord asked us to...
Got the same problem. Still inquiring but I might have found a solution here : http://midwestapplianceparts.com/microwave-parts-537/whirlpool-microwave-parts-648/microwave-door-panel-663/whirlpool-microwave-door-panel-w-glass-4212.html
$79 for the panel only
Jul 01, 2010 | Whirlpool MH1150XMQ Microwave Oven
Need to get into latch head area on door.
We have the service / repair manual for this model and have uploaded it to our site here to help you.
It will give you safety info, step by step help in disassembly, troubleshooting tips, and part numbers.
Most computers will open this document automatically, but you may need the free Adobe Reader
You can order parts from Encompass here or you can call them toll-free at 866-779-5835.
May 11, 2009 | Microwave Ovens
Shattered inside door glass on Sharp model R1870
It must be tempered glass and I would suggest using only the correct replacement.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
You will need the
free Adobe Reader to view or print them.
The manuals have exploded views, part numbers, and disassembly info.
The best place to order parts for this brand is Encompass (formerly Tritronics).
Or you can call them toll-free at 866-779-5835.
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Dec 30, 2008 | Sharp R-1480 Microwave Oven
Microwave door has burn spots on the glass of the door...
The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
Jun 25, 2007 | Goldstar MV-1501 Microwave Oven
Frigidaire GLMV169D Microwave Oven Logo
80 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
