Question about Xerox Office Equipment & Supplies
I have a Xerox XC 1255 copier. The light indicating problem or relace cartridge is on . I replaced the cartrige and light remains on and copier will not function.
  • 17,970 Answers
Any error code there? Press CLEAR, EXPOSURE MODE, CLEAR, EXPOSURE MODE. The display should go blank. Then enter 14 with the copy count keys and press START. If the machine does not turn off and back on by itself - then turn it Off and back on. See if the H code comes back. Sounds like the doc feed needs to be cleaned; clean with alcohol or windex.
Tell us news.
Posted on Sep 06, 2010
Can I use xerox phaser 3200 cartrige for xerox phase 3124 printer
No, check this first :
On the front edge of the cartridge, there are two screws, remove them.
Replace it in toner cartridge Ph3200 and done.
Mar 11, 2011 | Xerox Phaser 3124 Printer
The fuser error light is on and my Xerox XC 1040 copier will not work. There is no error codes displayed
The drum light can be reset via the control panel. Especially if your copies were good before the light came on. The drum unit is the cartridge that is located right next to the toner cartridge. Reset the light using the following reset procedure:
To reset the drum light on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
You can usually reset this counter at least once to get twice the life out of your drum unit.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 12, 2010 | Xerox Office Equipment & Supplies
How do I set my Xerox Docuprint 3290FS colour printer to work without colour cartrige
unfortunately this cannot be done - best you can do is source a replacement chip for the
cartridge - worst, replace the cartridge with either a compatible or genuine one
Aug 13, 2010 | Xerox DocuPrint C3290 Printer
I HAVE A XEROX XC-830 COPIER AND THE FIRST INDICATOR LIGHT ON MY LEFT IS ON. THE COPIES ARE COMING OUT WITH BLACK LINE IN THE MIDDLE.
Sounds like copy cartridge is bad or old. Probably drum. If there's round symbol that's on, that's it....Drum.
Apr 03, 2010 | Xerox 8830 Copier
I have replaced both the color and black ink cartriges, however the printer is giving me the "color ink low" indication and a check ink u163 blk alarm. We have reset the cartriges to no avail.
Per the Canon.com troubleshooting guide found on THIS WEBSITE, it would be recommended to ensure that you have the proper cartridge for your printer. Also, double check that you have fully seated in the cartridges and that they align as they should. Lastly, it is important that you are using Genuine Canon ink cartridges to ensure longer printer life, not void any warranty you may have remaining on the printer, and most importantly to ensure proper communication with the actual cartridges.
Nov 12, 2009 | Canon PIXMA MX310 All-In-One Printer
My xc 1040 the little triangle keep flashing red and wont let me do anything else
Hello sir; The red triangle indicator light on, it means need toner, just replace toner cartridge shpuld be fine.
Nov 04, 2009 | Xerox Office Equipment & Supplies
My xerox 5201 copier is making black copies. I
Xerox Copy Drum Cartridge 13R83 / 6R737 (20000 Page Yield)
Xerox brand - works in Xerox XC 355 XC 356 5201 5203 5205 5210 5220 5222 5305 5306 PRice is 135.00.. Post response if you want link to site. This will cure your grounding problem. You Cannot fix it, It is a consumable item and has no serviceable parts
Apr 03, 2009 | Xerox Office Equipment & Supplies
Xerox XC820 Copy Machine
three lights are for paper jam, replace toner cartridge and replace dru, cartridge. If there is zigzag line it is paper jam if there are six small dots it is for toner cartridge and if it is one circle it is for copy cartdisge. You can contact me for mfurther support at jagpal_65@yahoo.com
Dec 25, 2008 | Xerox XDL-33D Black and White Copier
Xerox xc520
That indicates you need to replace the drum cartridge. It's been a while since I supported those products, but I believe the cartridge is in the bottom of the device. Make sure you remove the toner cartridge before tipping it over or you'll have a mess to clean up and won't be able to remove the drum. Once you replace the drum, you need to reset the copier.
Aug 22, 2008 | Office Equipment & Supplies
Xerox copy machine
The lamp is n/g Replace it. Lawrence
Oct 22, 2007 | Office Equipment & Supplies
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
