Question about Samsung Refrigerators
Have a samsung 10 ton condenser, model RVMH100FAM5 as well as evaporators model AVMBH032CAO. Where can I find parts for them ???
  • jasantos Sep 06, 2010
    PartSelect does not recognize the model numbers
  • 10,865 Answers
Hello. I use Samsung.PartStore.com
Also, www.samsungparts.com
J.
Posted on Sep 08, 2010
    Guru:
  • 382 Answers
Im not sure what part you are looking for, but I found a place That might be if interest to you. Please check Samsung Parts here
Posted on Sep 06, 2010
  • Jtemelcoff Sep 06, 2010
    Make sure you click Button for ENTIRE PARTS
  • 2,382 Answers
Hi, get in touch with Part Select on 1-888-895-1535......
What is the problem with running a 10 SEER condenser with a 13 SEER air handler other than efficiency? I had a 2 ton 13 SEER air handler installed last August to replace one about 27 years old. The...
as most ac units are capillary tube control not tx valve having matched units is critical. as for cost the condensing unit is much more complex and expensive than the evaporator.
Feb 14, 2015 | Amana Goodman R-410A Heat Pump Condenser 2...
Samsung model#rs2577bb freezerworking good refridgerator not maintaining temperature
Not really a permanent solution for Samsung refrigerators with a evaporator inside the fresh food section. You will need to remove the shroud housing the evaporator and clean out the drain opening along with removal of any ice buildup. User Manual HERE
Here is a link to a troubleshooting page that covers your model=> HERE You need to clean and make sure the sensors at base of evaporator are clean and function properly. Also insure condensate drain below evaporator remain clear of blockages ice/gunk. Parts breakdown can be found HERE. I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 12, 2014 | Samsung RS2534 Side by Side Refrigerator
2 ton unit
6719f81e-d5d1-47c4-b80f-e11712a6cac5.pngNo oversizing the condenser will not work well, however oversizing the evaporator coil by 1/2 a ton actually increases the units efficiency and is recommended to do by most utilities on units they finance.
Jul 07, 2013 | Goodman CKL36AR36 Air Conditioner
What evap coil can be efficiently used with a 10 seer rheem raka-024jaz condenser
Hello, if the outside condenser is 2 ton than the inside evap coil should be 2 ton aswell. There are 12,000 btu's per ton and the number 024 in the model # represents btu's per ton so you have a 2 ton unit.
Jun 25, 2012 | Heating & Cooling
Trying to get info (tonnage seer rating) on a weatherking mod# 10ajb48a01 condencing unit to find a matching evaporator coil and cannot find anything on internet
This is a 4 ton model condensing unit. You can go up 1/2 ton for the evaporator, meaning a 4 1/2 (A) coil will work just fine and allow a bit more cooling capacity.
Sep 10, 2011 | Weather King 12AJA4801AH Air Conditioner
I have a Ruud Model # UACC-036JAS. Any idea on
Hi, yes the number you are showing me 036 indicates its a 3 ton unit. For every ton of cooling, you will have 12,000 btu's of cooling. 36 divided by 12=3 ton unit. Its showing me also its a Ruud Handler 2.0 ton which would be a Model# UACC-024JAS? If your mobel number is the one you gave me, UACC-036JAS, this is a 3 ton unit, absolutely no questions. I hope I have been of help to you. I am a licensed air conditioning / Refrigeration /Heating Contractor. Let me know if I have been of help.
Sincerely,
Shastalaker7
PS If this is a split system with the indoor air handler and condenser outdoors, both coils must be the same tonnage for it to work for you properly. You can't have a 2 ton indoor evaporator coil with a 3 ton condensing unit.
Jun 28, 2010 | Ruud Handler Air Conditioner
We have a brand new 5 ton ac unit the part that goes outside how we got it is a long story but a good one but we need to but the other half that goes in the celing and idea how much this should cost me and...
This is called an "A" coil. You need a 5 ton "A" coil to match your outside unit, give or take 1/2 ton. The cost will vary greatly depending on the make of your unit.
Sep 29, 2009 | Heating & Cooling
I have a bryant 24-567c condenser. need replacement
you have a 3.5 ton unit.The evap will work with a new unit but it will not have the 13 seer performance that the new condencer with matching coil will give you.It is getting and harder to find the old 10 seer units check ebay and craigslist.
Aug 18, 2009 | Carrier 38CKC042 Air Conditioner
Will it cause a big problem If I install a 2 ton condenser
If is 2ton it'll work fine only it will take a little longer to take out the humidity ,but dont put bigger than that Two ton is 24000 BTU you see in the model number a 24 between all the numbers and letters.
Aug 02, 2009 | Goodman CKL36AR36 Air Conditioner
Compressor freezes up at night and some during day.
You are being ripped off. The ambient (outdoor) temperature at night is low and therefore proper condensing does not take place causing the refrigerant to pool in the condenser and starving the evaporator. This causes a lower temperature in the evaporator resulting in "freeze up" which is often mistaken for a loss of refrigerant.
The proper thing to be done is to block off the condenser air causing the high side pressure to rise until the eqivillant of 110*F condensing temperature.
You can also install a low ambient kit which will cycle the compressor off when the temperatures fall
Jun 07, 2009 | Weather King 12AJA4801AH Air Conditioner
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
