Question about Samsung LN-T4665F 46 in. LCD Television
I have a Samsung LN46C650 and sometimes the picture goes black and the audio cuts out for a second or two. It occurs at least once a day but it happens at random so I cannot duplicate the situation. I'm worried it's a sign of worse things to come. Is this a known problem with this model?
I have the same problem. At first the tv would just blink occassionaly and the sound would cut out just like yours. We realized if we turned the tv off then back on, it would be fine. Well, that's not working anymore, and as opposed to a blink, the tv picture is cutting off all together, can't imagine it will do anything but get worse. I called Samsung about another problem I had with the tv, the autofit screen size selectioon was great, however over time, on some channels there got to be a progressivley larger white line at the top of the screen. At first we could adjust the picture up to completely close the line. Now it is too large to cover up. Samsung said, "that's normal."....progressively worse performance?
Posted on Oct 08, 2010
Samsung un65js9000 cable single cut out at times
get a warranty service in to check it out it is 1 day old so don't touch it yourself or the warranty is void
Nov 18, 2015 | Samsung Televison & Video
Picture goes out in less than a minute but sound keeps going
Typical problem in some video/audio board. However, if this only occurs on a particular video input ie: dvd or vcr, it may just be your wire connection.
Mar 27, 2014 | Samsung Hp-s4253 42-inch Plasma Hdtv
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV display is black; audio works fine. If I turn TV off and then back on the picture does display for a few seconds but then...
The backlight inverter which is also part of the power supply needs to be replaced. If you feel comfortable you can replace the blown capacitors on it.
Feb 10, 2018 | Televison & Video
While watching tv on my 2 day old Samsung 46c650 the picture went black. Audio was still playing.
If it's only 2 days old then take it back to the store where you got it while it's still under warranty.
It is most likely a loose connection inside the tv, or a bad component on the power supply or inverter circuit board.
But, if you take it apart to check, then you will void your warranty.
Return it right away and get a new one.
Good luck and please comment back if this was helpful.
Feb 03, 2011 | Samsung LN46C650 TV
Motorola DCH3200 cable box: sound and sometimes video cutting out
Sounds like your SNR is getting too high and causing the signal to overload. A few things can cause this a bad splitter that causes the signal to bleed and introduces noise, or a more common issue is having a weak signal coming from the cable provider and once it goes through a splitter it causes the signal to become to weak to be stable.
Since it sounds like your cable has been working up until recently, you may have had a cable or splitter go bad.
Call comcast and have a technician come out and test the line.
Sep 11, 2009 | Motorola Televison & Video
Samsung HLR5067W
Faulty lamp could be, there is also a little blue switch behind the lamp door that needs to be in the down position.
Nov 16, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung LN-T4665F 46 in. LCD Television Logo
343 people viewed this question
Jerry Greenberg
Jerry Greenberg
