Question about Cell Phones
When i power on it displays contact service - Cell Phones
  • 352 Answers
Hello
The phone need to be flashed,its got software problem.
Flashing the phone will erase all the information you have on the phone and it is the easiest way to solve the problem.
Thanks.
Posted on Sep 06, 2010
Clear contact service display on nokia c2-00
How can i resolve this problem? Contact service
Dec 10, 2017 | Nokia mobile C2-00 Dual SIMbiosis
Acer espire 7551G...power is on but the screen is blank. How can I get the screen to come up?
Hi
may your screen is dead please go the Acer service center and give to repair,
May 13, 2011 | Acer Computers & Internet
Its powering on,but no display in LCD,i can listened music on it through head set.all display in LCD totally white.it is Nokia 5310 china phone
It is the problem in LCD display.Most probably Display is not usable any more.Anyway Contact the service centre and check there is any problem in LCD connection if not replace LCD display
Aug 18, 2010 | Nokia 5310 Cellular Phone
Contact service is being displayed on screen nokia 5130 any solution
Sep 10, 2009 | Nokia 5130 Cellular Phone
I have exactly this problem. Powers up, black screen
The focus is stuck - could be sand etc. You will have to contact yout local Sony service center or if they ask too much, you can contact me at toms.safranovs@gmail.com
I work in a Sony service center and repair these every day.
Tom
Jul 26, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
COMPAQ screen fails to light up
Here issue is not clear, like if the issue is
1. There is no display on the notebook even though power LEDs are glowing?
2. There is display but very dimm/dark to see the display?
I will explain both the senarious, if the issue is something diff other than the above mentioned two, then you should get back to us by elaborating on the issue.
Solutions:
Sol: If this is the case, then try power drain:
Try doing power drain by taking out the battery & keep holding down the power button for complete one minute to drain out the power from the computer components. Restart the computer after putting the battery in.
Try restarting the computer only with the AC power, without the battery & vice-versa.
If the issue persists, then the issue would be with the motherboard components, you need to contact service center
sol: If this is the case, then connect the external monitor to the notebook andcheck for the issue.
If the display is fine on the external monitor, and if you can see the display on the notebook screen by using the flashlight, then the issue will be with the back light of the notebook screen. Here also you have to contact service center.
Please reply if you need any further information on this issue.
Aug 09, 2008 | HP Compaq Presario V6000T Notebook
HP dv1000 monitor just stopped working.
Description During the startup or boot process of the notebook, the display is very dim and barely readable. It remains dim when it reaches the Windows desktop. Restart the notebook with AC power Perform the following steps to determine if the dim display is due to a hardware failure:
  1. Connect the AC adapter to the notebook and a working electrical outlet.
  2. Power down the notebook PC by pressing and holding the Power button for 5 seconds.
  3. Press the Power button again to start the computer.
If the display is still dim after restarting with the AC adapter connected try changing the LCD brightness. Change the LCD brightness From the Windows desktop, hold the Fn key and press the F7 and F8 keys to increase or decrease the brightness of the display. If using the function keys does not resolve the problem, determine whether the Lid Actuator switch is stuck. NOTE: The key number may vary depending on the notebook PC. The image on the key should resemble the following images: Figure 1: Brightness Level Down c00776225.jpg Figure 2: Brightness Level Up c00776226.jpg NOTE: During battery power operation, the notebook display will dim to reserve battery power. Adjust brightness control using the control panel Some notebook PCs have the ability to adjust the brightness through video drivers. If the notebook PC has video drivers with this capability, perform the following steps:
  1. Click Start , Control Panel and then double click Display .
  2. Select the Settings tab and click Advanced .
  3. If the feature is available, a tab with the video card name will be present. If it is, select that tab.
  4. Adjust the desired brightness.
Finding the Lid Actuator switch The Lid Actuator switch is a small button or switch located above the keyboard and LEDs on the right or left side of the notebook. It may also be located near the display hinges. Pressing this switch when the computer is on may turn the notebook display off or cause the notebook to enter a different power state. Press the switch 2-3 times while observing the display. If the display is no longer dim the switch may need to be repaired. Contact HP service and support for further assistance. Contact HP service and support If the display remains dim after the troubleshooting in this document it may be possible that the backlight is damaged. Please Contact HP service and support to schedule a repair
Jun 05, 2008 | HP Pavilion dv1000 Notebook
Don't power on
I suspect Motherboard Failed. Contact a qualified service person to assess it.
Regards
Rafique
Feb 18, 2008 | Dell OptiPlex GX260 PC Desktop
Nokia 2626 contact service
SOLUTION NOKIA 2626 CONTACTE SERVICE
Jan 27, 2008 | Cell Phones
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
