There is no picture and a red light flashes 3 times in the front. I replaced the lamp and housing about 1 month ago. Now this. I took out the lamp, and everything seems to be intact.
  • valdezgreg Sep 06, 2010
    Heres the model number ....Sony KDF-E60A20 60-Inch LCD Rear Projection Television
  • 456 Answers
After replacing thelamp you need to reset the lamp use hours otherwise the unit will not recognize a newlamp has been put in.
The method to reset the lamp use hours is often model specific and the manufacturer's do not like sharing information like that with the consumer, for some odd reason, it's not like it's information that the customer would need (sarcasm directed at the manufacterer).
My advice is to contact either the authorised repair agent for your brand of TV and they will be able to talk you through the lamp use hour reset method. I hope this offers some assistance. Good luck.
Posted on Sep 06, 2010
Lamp blew, picture went then sound also. Replaced lamp, now will not turn on. Red light flashing on front switch panel.
If the red light flashing 3 times the pause and again flashing 3 times, check and make sure lamp cover is installed correctly back on tv.
Sep 05, 2011 | Sony KS 50R200A Replacement Rear...
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Have an 52HM95. Man.- 01-2006. Rent-a-center had the lamp (I believe) replaced when this happend the first time 3yrs ago. . It cost them around $200. Now 3 years later, its paid off, so, NEED HELP! (No...
The "LAMP" LED light indication on the front of the tv screen panel flashes or light up?The projection lamp was replaced 3 year ago u belive right?The average projection lamp life about 1 1/2 or 2 years.Withthin function in the tv and in used like 4 or 5 hours a day of tv viewing.Ur tv require a new projection lamp.
Sep 18, 2010 | Toshiba TheaterWide 62HM84 62" Rear...
We replaced the lamp about 6 months ago..but now it cuts off randomly..the red light and one green light will flash? Lamp replacement was when all 3 lights were flashing. Suggestion?
Is the picture quality good if it is then the lamp is ok try to reset the lamp timer if you haven't all ready. I think that the problem is coming from the ballast board this is the power source to the lamp, with time this part starts to ware out and starts to get weak. that is the reason your lamp does not stay on
Sep 07, 2010 | Samsung HL-S5686W 56" HDTV
Tv turns on and off 3 times before picture appears
Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
Dec 14, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Sony kf50wef610-television-replaced lamp about 4 months ago- now will not turn on - green light flashes 6 times- red light flashes 5 times once- then flashes 6 times with 4 second pause between --I am...
I believe the 5 flash error is for the lamp thermostat. It is located (I believe) on the right side of the lamp housing if you were looking from front. It is very small black square with white and gray wires covered in black sheeth. The only way to replace it is from the rear. you probobly need to do a thorough cleaning in there and thats why you've had the lamp, and thermo fail. Remember not to touch the lens of the lamp when working on it.
Jun 20, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have sound and no picture. Red light on in front of tv indicating lamp. Can be fixed w/o repairman?
Yes the Lamp can fail within that time frame. Much of it depends on how many hours the set is running. Most Lamps have a 3000 to 5000 hrs of life. But with any Halogen style Lamp, this is not written in stone.
Hope this helps,
Skyassoc
May 11, 2009 | Mitsubishi WD-65833 65" HDTV
Tv Shuts off occasionally 1min upon power up shows red lamp light
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
