Question about Stinger Streamlight 75000
How do change the batterie on a ds led stinger
Where do i send my light to be repaired
Not to many places are around anymore that I know of that fix appliances whether it's a flashlight or whatever, unless you know somebody personally that fixes items on the side as a hobby. Maybe sometimes the company of the product offers a repair or replacement. But sometimes the cost of that process out ways the cost of a new one. That's partially the reason most places don't repair.
Feb 17, 2014 | Streamlight Stinger Led Flashlights Led...
I got my DS in 2009 april, then on september i lost my charger then on march 2010 i found my charger then i found out i could'nt find my DS anymore a few months later i found my DS i charged then it...
The red LED indicates low power. When the DS is charging an orange LED should be on and the DS can be switched on, giving a second green light. If you tried charging it but the orange LED did not come on or only came on for a few seconds then the battery has not charged. The charger may be faulty or the power connector on the DS may be faulty. You need to try another charger. If another charger does not work then the DS is faulty and needs repair. It could be the power connector or the battery or some other fault inside.
If the amber LED comes on to indicate that the battery is charging then the battery should be fully charged within 3 hours. If the DS does not switch on after charging then the battery may be faulty. It can be removed by opening the cover on the bottom of the DS.
You should try and find a friend with a DS who will let you try their charger and battery in your DS.
If the DS itself is faulty it will probably be uneconomical to repair. If this is the case then try selling it on ebay as a faulty DS.
Oct 30, 2010 | Nintendo DS Lite Console
My streamlight stinger xt flashlight won't charge in the holder, however, the second battery does charge in the "piggyback"
Could be a lamp holder or charger problem. I suggest going to Streamlight's website and find an authorized service center in your area or send it to the factory for repair.
Mar 28, 2010 | Stinger Streamlight XT Rechargeable...
Flashlight problems
streamlights have lifetime warranties. Contact them to find a dealer that can fix it. They might even let you send it in to get fixed.
Aug 15, 2009 | Streamlight Stinger XT DC, Black
Rechargable Stinger new bulb is dim orange
Could possibly be a bad switch, I would also get that battery tested out also. If you still have a receipt it should be covered under warranty. If not try sending it in anyway. Limited lifetime warranty does not include bulb, or batteries but, anything else on that Stinger should have a lifetime warranty. Of course that excludes abuse. Check out the website www.streamlight.com and go to FAQ for a nearest Authorized Service Center or send it directly to Streamlight. Address also listed on the website. Hope that helps ;)
Jul 03, 2009 | Stinger Streamlight XT Rechargeable...
LED ON CHARGER DOES NOT COME ON STREAMLIGHT POLY STINGER. PROBLEM IS ON BOTH WALL AND CAR CHARGER.
If your Polystinger is an old one could be the battery, if not could be the switch. The chargers rarely go bad. I suggest you send it in for warranty repairs. The switch has a lifetime warranty and batteries are covered within a year warranty accomodating proof of purchase. If you do not have warranty or proof of purchase, you can still send them in for Warranty. ;)
Jul 01, 2009 | Streamlight 76014 Polystinger Rechargeable...
Stinger Streamlight 75000 Logo
100 people viewed this question
Top Stinger Camping, Backpacking & Hiking Experts
richie46
Are you a Stinger Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
